Engine sump drain plug
Adrianli
  On 9/4/2016 at 1:50 PM, Phang said:
Mytivac MV7201
This oil evacuator use a simple venturi and compressed air to create vacuum , this is the cheapest and simple form of design, thereforeone should not  have high expectation even the oil is very hot.
Professional workshop version used air diaphragm pump or electric vacuum pump , these sophicated and expensive versions that can evacuate oil extremely fast and channel them to common pipping and finally dump into a collection waste thank.
  On 9/4/2016 at 3:52 PM, Kangadrool said:
Characteristics of MY mechanics, always tighten until....
I had my oil filter studs stripped and broke before. Thanks to their brute strength.
Frankly,  I have hardly come across twisted or stripped studs or bolts ( on condition there is no surface or internal hair crack line) cause by using standard socket  extension. The damage is usually cause by using long extension and inexperience mechanics.
mine is the hand pump version, not the pneumatic type that need compressed air to operate.
it can suck out 5.5l of warm oil in less than 2 minutes, good enough for home use.
  On 9/4/2016 at 4:24 PM, Phang said:
my current car oil filter also accessible from the top of the engine bay, oil change and filter change can be done more gracefully and fast now, no need to raise the car and lie on the floor anymore.
Cars with easy  top down reach oil filter are popular with DIYers - such as BMW N40, N42, N45, N46, N52, & etc
I believe yr set can either used compressed air or create vaccum via the attached hand pump
Edited by Yeobh
  On 9/4/2016 at 1:42 PM, Mkl22 said:
Can you share what brand of extractor you are using?
Off topic, but 12 years ago adrianli was driving an old 89 civic. Now is an Audi A6 avant. Congrats.
Thanks. Didnt know this thread came alive after so many years!!!
  On 9/5/2016 at 2:05 PM, Yeobh said:
Just curious, have you come across this type of plastic sump plug used on VAG vehicles in Singapore ?
My Avant not yet due for servicing, so I dont know. And nowadays, the underside is fully covered up. My Fumoto drain valve is in the storage box since I sold off my Axio.
Avante ?
Very easy to service.
Oil plug is accessible from the front. Loosen it and it spills oil forward.
Oil filter is easily reached from below the car.
  On 9/6/2016 at 2:50 AM, Kb27 said:
Avante ?
Its a Avant, not Avante.
Photos here : http://www.mycarforum.com/topic/2684724-audi-a6-avant-1087m-whats-the-catch/?p=5922921
Oil filter is on top, oil plug should be below, havent have the chance to look under her yet.
To prevent oil spilling when removing the oil filter casing, most of the VAG and Audi oil filters have a plug-in-drain to  a special design drain attachment.
Even now new Toyota and Lexus cars oil filter cartridge have such similar drain attachment.
Edited by Yeobh
