Torquey Neutral Newbie August 25, 2004 Share August 25, 2004 i have read quite a fair bit abt close ratio gearbox, all claim to be able to hit optimum RPM faster and stay within optimum RPM for respective powerbands of each gear. other than higher fuel consumption, i havent found out other disadvantages. anyone can enlighten me? thks. ↡ Advertisement Link to post Share on other sites More sharing options...
Acemundo Supercharged August 25, 2004 Share August 25, 2004 i think it makes sense. but to have that range of power, i thik if the ratios of gearbox are close, they should have more gears. Link to post Share on other sites More sharing options...
Maddriver 4th Gear August 25, 2004 Share August 25, 2004 will lost yr top end Link to post Share on other sites More sharing options...
Acemundo Supercharged August 25, 2004 Share August 25, 2004 can be compensated if have more gears? Link to post Share on other sites More sharing options...
Maddriver 4th Gear August 25, 2004 Share August 25, 2004 That wat happen to my car now.Low & mid shiok but top end sucks Link to post Share on other sites More sharing options...
Acemundo Supercharged August 25, 2004 Share August 25, 2004 urs is 5 gear? wat abt 7 gear? Link to post Share on other sites More sharing options...
Schneider79 Clutched August 25, 2004 Share August 25, 2004 clutch will also wear faster cause you tend to dump clutch... Link to post Share on other sites More sharing options...
Ahliew Neutral Newbie August 25, 2004 Share August 25, 2004 (edited) on the city vtec when in 7 speed auto. the gears change at pretty low revs and speed. Edited August 25, 2004 by Ahliew Link to post Share on other sites More sharing options...
Acemundo Supercharged August 25, 2004 Share August 25, 2004 but the power range bigger rite? Link to post Share on other sites More sharing options...
Torquey Neutral Newbie August 26, 2004 Author Share August 26, 2004 i think it actually shortens the powerband. i also read tht the low end becomes more torquey at the expense of the top end. ok seems like the disadvantages of close ratio gear box arent that serious. any idea wats the significance of the specs of the final drive? Link to post Share on other sites More sharing options...
Acemundo Supercharged August 26, 2004 Share August 26, 2004 hmm...very surprising leh... if the powerband is shorten what's the use of having so much low end torque? i tot more gears is suppose to address the lost of range at the higher end? hmm, let's wait for other experts to comment ↡ Advertisement Link to post Share on other sites More sharing options...
Honda civic FD4 gearbox issue
car hard to start after a week of unused
Changing Auto transmission filter
Gearbox issue on Renault Megane DCI 1.5
