Streetman Neutral Newbie August 22, 2004 Share August 22, 2004 Quote Hv any bros here used the E Power voltage stabilizer, think the brand is silvers ? How's the feedback ? Recommended ? Tks Just installed silver's e-power volt stabilizer one week.....must say that immediately can feel engine very much smoother and driving more relaxed. Still monitoring FC hopefully will get good results. Also noted FM radio reception clearer. However gadget more expensive though..... ↡ Advertisement Link to post Share on other sites More sharing options...
Civices8 Neutral Newbie August 22, 2004 Author Share August 22, 2004 Bro Streetman, wat's yr ride ? I've also just installed the e power voltage stabilizer on my Civic ES08, will monitor and feedback later this week.. Link to post Share on other sites More sharing options...
Esky Neutral Newbie August 23, 2004 Share August 23, 2004 There're cheaper ones like the cloned "Apex'i" one (with 4-pt grounding). I've also seen one which looks like the Pivot one (with blue transparent basing) but branded as Hot Inazuma instead! Link to post Share on other sites More sharing options...
Mello Neutral Newbie August 23, 2004 Share August 23, 2004 I think u can consider Hot Inzumi if budget allows, follow by Pivot or Silver's HVS. More branded lah. If budget then go for local made Z-stab lor. I am happy with Silver's E-power so far. Link to post Share on other sites More sharing options...
Biccat Neutral Newbie August 23, 2004 Share August 23, 2004 Just to share some feedback with you:- 4 persons in my company incl myself have installed this device and none of us has felt an noticeable difference in performance. It there is, it could be so small that we didn't notice it. But what we generally agreed was that the ICE improved. Link to post Share on other sites More sharing options...
Zombie Neutral Newbie August 23, 2004 Share August 23, 2004 Hot Inzumi = HVS rite??? Which one in your opinion is better value for $$$??? Link to post Share on other sites More sharing options...
Mello Neutral Newbie August 23, 2004 Share August 23, 2004 Personally i think Pivot or E-power good enough liao. They all work the same. Link to post Share on other sites More sharing options...
Streetman Neutral Newbie August 23, 2004 Share August 23, 2004 One month old matrix 1.6A Bro. Initially quite sceptical ..... impressed with the classy housing in blue or red and had it installed. Really can feel the change in attitude of ride.Mine no other mods ....... think E voltage stabilizer enough for now. Will report on FC later. Link to post Share on other sites More sharing options...
Civices8 Neutral Newbie August 23, 2004 Author Share August 23, 2004 O.K the verdict is out, with the E Power voltage stabilizer installed on my 3 yr old civic es08 for 2 days, the ice sounds better, torque seems to have gain slightly uphill/slope and surprisingly the F.C seems to have also improve, will monitor and confirm in a weeks time. Pls note that no after market grounding is installed on my ride. Verdict: Worth to consider for optimum electrical efficiency with less strain on stock battery. Cheers Link to post Share on other sites More sharing options...
Titanium 4th Gear September 4, 2004 Share September 4, 2004 Quote There're cheaper ones like the cloned "Apex'i" one (with 4-pt grounding). I've also seen one which looks like the Pivot one (with blue transparent basing) but branded as Hot Inazuma instead! "INAZUMA Voltage Stabilizer + 5 pieces Ground Cable. Stabilizes the entire car's electrical voltage. Improves engine performance and all electrical components such as car audio system, lighting system, air-con system, etc... Additional grounding cable to enhance the performance. All the above benefits for only $105/set. " http://www.pro-rv.com.sg/ Look like Pivot, but brand as ""INAZUMA"... Link to post Share on other sites More sharing options...
Esky Neutral Newbie September 6, 2004 Share September 6, 2004 Oh I see, Hot Inazma clone! Link to post Share on other sites More sharing options...
Simonleng Neutral Newbie September 17, 2005 Share September 17, 2005 (edited) hello all, my frd just got a E-POWER 2... but he doesn't know how to install it. need help from u guys who know abt the installation, pls help. problem 1 - the wirings not label, so dunno which is which, schematic as follows 1 (Black) ---------------|....|---------------- 3 Black 2 (Red) ---------------|....| I presume 1 connect to -, 2 connect to +, 3 connect to ground, can any1 confirm with me if correct??? after installation, which 2 led lights(red, green) will light up huh... pls help help Regards Edited September 17, 2005 by Simonleng Link to post Share on other sites More sharing options...
Alant 1st Gear November 23, 2006 Share November 23, 2006 Hi, pai seh to revive a old thread. Me also got the E-power version 1...yesterday found that the blue light is not working. Anyone using this VS or other brands of VS has this problem? Does it means that the VS has come to the end of its lifespan? The set was used over a year. Thanks. Link to post Share on other sites More sharing options...
Eemin Neutral Newbie November 23, 2006 Share November 23, 2006 Quote Hv any bros here used the E Power voltage stabilizer, think the brand is silvers ? How's the feedback ? Recommended ? Tks hi, i've got one e-Power 2 to let go. details here in http://www.mycarforum.com/classifieds/classifieds.pl?id=4904 if interested in more mod, can see http://www.mycarforum.com/classifieds/classifieds.pl?id=4905 PM for quickie deal! Link to post Share on other sites More sharing options...
Alant 1st Gear November 23, 2006 Share November 23, 2006 Eemin, is your E-Power VS from Silver's Racing? Don't recall they have E-Power2 Pro leh. Thanks. Link to post Share on other sites More sharing options...
Eemin Neutral Newbie November 24, 2006 Share November 24, 2006 oh.. i got mine from this workshop in JB a while back. not from silvers racing Link to post Share on other sites More sharing options...
Derek_phua Neutral Newbie November 26, 2006 Share November 26, 2006 Hi EEMIN and all e-power 2 brothers here, I have E-Power2 but the I do not understand what the 2 x LED lights on it means? Could you or anyone here enlightened me of what are they and what colour means something is not right? Thank you. Derek Link to post Share on other sites More sharing options...
Derek_phua Neutral Newbie November 26, 2006 Share November 26, 2006 Sorry, Anyone can help me with regards to the LED lights on my E-power 2? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
Home power back up
Home power back up
Honda Stream 2009 No Power and High fuel Consumption
Alcades power optimizer
Microsoft to buy solar power in Singapore
Cordless power tool system - which one ?
Not all heroes wear capes! Liverpool taxi driver prevents terrorist attack!
