Rustycar Neutral Newbie August 5, 2004 Share August 5, 2004 Quote .... Same thing for the Twister ducted cone filter I'm using, I seriously doubt the swirl effect induced can be maintained after the airflow passes through the cone filter. What do you think? I think the swirl is meant for better flow through the filter element rather than for the swirl to continue after the filter element. Quote the other thing to think about it: it's so easy to implement a twister system to have a swirl effect going into the engine bay, so why do car manufacturers not incorporate it in the first place? It doesn't increase noise or have other negative effects, and it's cheap to manufacture (they prob have more then enough technology to be able to design fan blades). The thing is such technology, be it Twister, Cyclone or Surbo, will only be felt when you rev past 3K rpm. Dun think the general driving community does that kind of driving. Most change gears around 2.5K, while some even think that revving past 2K will spoil the engine! So car manufacturers will seldom adopt this type of approach. Why do you think your stock car don't come with high flow filter? ↡ Advertisement Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie August 5, 2004 Share August 5, 2004 Oh yes I heard from a friend that it works too That's effectively forced induction leow.. Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie August 5, 2004 Share August 5, 2004 It does give better performance, a compromise between the stock airbox and an open pod filter because it is shielded. Low end torque is maintained while high end is improved but not to the extent of an open pod. However, I wouldn't attribute it to the so called swirling effect that's supposed to be produced, but to the less restrictive airflow as compared to a stock airbox. I honestly do not think the twisty thingy works though it's nice to look at. Link to post Share on other sites More sharing options...
Cyrix Neutral Newbie August 5, 2004 Author Share August 5, 2004 bro...just one question....if u fit a SRI...remove the resonator box....can????....any effect if just remove the reosnator box??? Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie August 5, 2004 Share August 5, 2004 (edited) If you're fitting an SRI with a cone filter.. You wouldn't need the resonator anymore. Not sure what your engine bay looks like, but if the resonator doesn't get in the way you can leave it where it is. Edited August 5, 2004 by Yttrium Link to post Share on other sites More sharing options...
Cyrix Neutral Newbie August 5, 2004 Author Share August 5, 2004 bro...but through the messages in this thread..tot the resonator box affects the air flow into the engine bay by curving the air flow??? thus to the air filter????...btw..me riding a SIR... Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie August 5, 2004 Share August 5, 2004 But with an SRI you are no longer restricted to the air flowing thru the resonator. Your engine will suck in air from the surroundings of the cone... right? Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear August 5, 2004 Share August 5, 2004 Not really forced induction lah....its either here nor there. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie August 6, 2004 Share August 6, 2004 oic. thanks man for all ur advice. Link to post Share on other sites More sharing options...
Cyrix Neutral Newbie August 28, 2004 Author Share August 28, 2004 Quote Yo! Wanna join me and my friends? Most of us are DOHC VTEC. PM me if you interested, and i will pass u my contact. hi bro...hope u still remember me...me done up my car a bit liao... prepared to mit up wif u guys.....hahahahha....if u guys dun mind a newbie like me... maybe can get some pointers from u guys on further mod on my babe..heheheh...care 2 provide contacts???...do u guys go pasir gudang ???...been wanting to go....just to see see....me reply u here just in case u dunno who i am liao....n ignore me...hehehhehe Link to post Share on other sites More sharing options...
Neecoh Neutral Newbie January 9, 2011 Share January 9, 2011 Hi..good evening!!.. anyone here driving HONDA SIR??..im from Phil. looking for parts (spoon).. or something that i will add to my car.. thanks!!... I love my HONDA [code] [angel] [/code] ↡ Advertisement Link to post Share on other sites More sharing options...
Battery for Honda Vezel
Green fingers anyone?
