Andy Neutral Newbie July 9, 2004 Share July 9, 2004 hey all bros,can anyone help me??how to check if the head gasket is up the lorry?? ↡ Advertisement Link to post Share on other sites More sharing options...
Milky33 Neutral Newbie July 9, 2004 Share July 9, 2004 you try open up the water coolant and see the water inside whether have a layer of oil on top ornot...and if the temp keeps on going up,thatz mean its gone... god bless you...as it will cost quite alot... Link to post Share on other sites More sharing options...
Andy Neutral Newbie July 9, 2004 Author Share July 9, 2004 hey bro wat u mean a layer of oil?the temp reamains the same.slightly below the half mark.but there is some bubbles coming out!! Link to post Share on other sites More sharing options...
Milky33 Neutral Newbie July 9, 2004 Share July 9, 2004 oh...you mean that when you start engine,there is bubbles coming out from the water? if yes,better get it fixed soon,the gasket is gone already,better change a new one...don't wait untill the temp to rise...cuz it may hurt the block... Link to post Share on other sites More sharing options...
Milky33 Neutral Newbie July 9, 2004 Share July 9, 2004 well...you just ask the mechanic to do a top overhual for you,and you ask him whether they charge how much for top overhual 1st...before you do it... Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 13, 2004 Share July 13, 2004 Visual check is possible if the head gasket combusion leak is already in advance stage of damage. Early stage of combustion leak can only be detected by using a leak-down tester where compressed air is introducted into the cylinder. Air escape is then monitored by observation and listening with a mechanic sethoscope at various locations such as radiator opening, intake manifold, oil dip stick opnening etc. Hope this helps Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 17, 2004 Share July 17, 2004 And I tot the easiest way is to open your radiator cap...and rev your engine ? If see "fountain" i.e. water shoots up from the hole...head gasket is gone ? Link to post Share on other sites More sharing options...
Milky33 Neutral Newbie July 17, 2004 Share July 17, 2004 yup...and if the radiator water is oily that means that it is gone... Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 17, 2004 Share July 17, 2004 For early stage cylinder head gasket leak - the leak is very very minute and it is very difficult to detect visually via radiator coolant. If the water start to should out, then it is already a gone case. Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 14, 2006 Share March 14, 2006 sorry to dig out the thread...but if after engine on, radiator cap out and coolant boils out after some time...iszit okie? Link to post Share on other sites More sharing options...
Tanjkp Clutched March 14, 2006 Share March 14, 2006 Gasket problem not necessary mean must leak into radiator. Some case will show oil sipping out around the cylinder head -- so by looking around the cylinder head can tell. Overheating or drop in radiator water level at times is due to leak by radiator. Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 15, 2006 Share March 15, 2006 (edited) If the temp gauge indicates normal reading, the coolant should not over flow. The overflow can be due to clogged radiator tubes, lower radiator hose internal layer has collapse or the water pump is not functioning properly. Edited March 15, 2006 by Yeobh Link to post Share on other sites More sharing options...
Silver_z 1st Gear March 15, 2006 Share March 15, 2006 Cost a lot meh? I change my head gasket like 3 times in 2 years. Sianz! Link to post Share on other sites More sharing options...
Thug Clutched March 15, 2006 Share March 15, 2006 3 times in 2 years??? Man..... I jus did my full overhual like 6 mths ago....now i'm having problem water in radiator and reservoir keep drying up...did a simple test myself. Engine on...radiator cap open....bubbles came out...not alot <<<=== is this a case of gasket leak or leak in radiator? Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 17, 2006 Share March 17, 2006 wao...think each time cost abt 350-400 bucks...boy... Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 18, 2006 Share March 18, 2006 (edited) The premature failure of a top ovehaul work can be due to - mehanics may not have use the right method and skill in replacing the head gaskets. Chances he may have use cheap after market head gasket, the cylinder head contact surface is warp/ uneven wear that must be machined flate before setting.Without correctly torquing the cylinder head bolts to the right specifications, the chances of oil and coolant leakage is very likely due to undeven expansion the of head - overtime the head will develop internal cracks. Edited March 18, 2006 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
16 yr old detained by ISA for planning attacks
Man who removed bus stop bench to check its dimensions for f
Kia Cerato GT Line Owners Check In
KIA K3 Owners check-in!
Ferrari Portofino, and gone is the California
