Andrewkb Neutral Newbie September 28, 2002 Share September 28, 2002 How to ? Need to slap on the Gavinizer leh ... ↡ Advertisement Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 28, 2002 Author Share September 28, 2002 Attached is a picture of my engine ... The golden metallic rail, I guess is the injector rail right ? The white object to the right I guess is the fuel regulator ? By right, the fuel regulator should be connected to the outlet fuel line, but in my case, there is only 1 fuel hose connected to the fuel regulator.... cannot find the inlet fuel line ... Can someone help ? Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie September 28, 2002 Share September 28, 2002 Hi! there, Andrewkb, Your car manual should have the diagram of the fuel inlet line. It should show you from the fuel tank - fuel pump - fuel regulator - injector rail - return line. Another way to determine, remove the hose that you think is the inlet, switch on the ignition key, which will activate the fuel pump to squirt fuel out of the inlet line. Do it with a cold engine, an assistant to turn the key, not start the engine. Rgds Paul Yong Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 28, 2002 Author Share September 28, 2002 Sadly, I don't have the manual, previous owner lost it ! 2ndly, I doubt the manual will mention to such detail rite ? Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie September 28, 2002 Share September 28, 2002 Hi! there, Andrewkb, Check with the other owners and borrow theirs to photo-copy. BTW, what are you driving? Rgds Paul Yong Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 28, 2002 Author Share September 28, 2002 Stream 2.0 Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 28, 2002 Share September 28, 2002 Paul, the Honda car manual do not have the diagram lar! I look into my manual for my civic, 'boh' diagram 'lay'! Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie September 28, 2002 Share September 28, 2002 "'boh' diagram 'lay'" Hi! there, Vtim, Mine has, so does the car manual CD. It also has the diagram for the 3.0L V6. Rgds Paul Yong Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie September 28, 2002 Share September 28, 2002 Hi! there, Andrewkb, I'll see if I can take a look at the parts manual for your car. Rgds Paul Yong Link to post Share on other sites More sharing options...
Slowpoke 3rd Gear September 28, 2002 Share September 28, 2002 if I'm not wrong, the new Honda K-series engines do not have a fuel return line, that is why you can only find one fuel hose connected to the fuel rail. I don't think that white plastic object you circled can even be called a fuel regulator. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie September 30, 2002 Share September 30, 2002 Bro difficult to see leh....see if U can take a few close-ups from different angles or get on of our experienced brudder here to check it out for U during meetups. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie September 30, 2002 Share September 30, 2002 Hi! there, Andrewkb, I went to take a look at the parts manual for your car today. It seems like the fuel line from the fuel filter goes to a fuel canister, then to the fuel regulator, but it's not named as such. The diagram's abit difficult to understand, as scale is too small, and it's separated from the intake fuel rail, with many parts that I haven't come across. I got a big headache standing over it, looking at the diagram and can't decide on how it's suppose to end up on the fuel rail. Rgds Paul Yong Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie October 1, 2002 Author Share October 1, 2002 WOW ! Where did you find the parts manual ? Anyway, I can't seems to identify the fuel filter too. Probably gotta let you guys see the car in person .... Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie October 1, 2002 Author Share October 1, 2002 I will try to take close up picture of the area... but a bit tough, coz the hoses are mostly concealed, or hidden below other hoses. As such, I doubt the photo will show up clearly. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie October 1, 2002 Share October 1, 2002 "let you guys see the car" Hi! there, Andrewkb, I went to Tanly Motor to borrow the parts manual for the Stream. Rgds Paul Yong Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie October 1, 2002 Author Share October 1, 2002 wow ... you sure have kangtao .... anyway .... I think I got the line correct ... managed to find a Japanese website where they place magnet on the "fuel line" ... However, they are really amaturer ! They actually use those magnet for sticking to the wall ! Which make me also wonder if they got the fuel line right ! Look at this: http://st2451.tripod.co.jp/mug.htm Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie October 1, 2002 Author Share October 1, 2002 Hmm .. can I just borrow from the guy (Loo??) when I am there ? Or becoz U know him that's why can borrow ? Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie October 1, 2002 Share October 1, 2002 "I just borrow from the guy" Hi! there, Andrewkb, They're my customers, so I can borrow whenever I'm there, as I couldn't get it at Leong Kai, over at Syed Alwi Rd. Rgds Paul Yong ↡ Advertisement Link to post Share on other sites More sharing options...
Where to mod fuel needle?
Singtel line down?
Singtel line down?
Wads the fine for parking opposite continuos white line?
Kia Cerato GT Line Owners Check In
