Turbobrick Neutral Newbie December 31, 2001 Share December 31, 2001 (edited) Learn more about the life saving ABS and it's functions here! http://www.geocities.com/nosro/abs_faq/ Edited January 25, 2002 by Admin ↡ Advertisement Link to post Share on other sites More sharing options...
Seven11 Neutral Newbie May 2, 2002 Share May 2, 2002 Got after market ABS? Heard from an unreliable source that there were someone selling and installing , now close shop liao! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 2, 2002 Author Share May 2, 2002 I think it was called ABS Trak, no sure how it worked though......like TV Media product IMHO Link to post Share on other sites More sharing options...
Magfocus 5th Gear May 3, 2002 Share May 3, 2002 I think it was called ABS Trak, no sure how it worked though......like TV Media product IMHO ABS Trak was on alot of Protons and Mitsubishis, maybe some owners can testify to them?? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 3, 2002 Author Share May 3, 2002 Wondering is the ABS Trak done up by C&C for the owners? Link to post Share on other sites More sharing options...
Magfocus 5th Gear May 3, 2002 Share May 3, 2002 Its probably subcontracted out by C&C before the customer gets his car, lots of mits and protons didnt come with standard ABS that time. You know its there when there is a little sticker on the bootlid or at the side of the car... Link to post Share on other sites More sharing options...
Seven11 Neutral Newbie May 5, 2002 Share May 5, 2002 So where can we get ABS Trak installed if our cars do not come factory fitted? If C&C fix it up on the cars they import, I guess it must be quite reliable. Link to post Share on other sites More sharing options...
Magfocus 5th Gear May 5, 2002 Share May 5, 2002 So where can we get ABS Trak installed if our cars do not come factory fitted? If C&C fix it up on the cars they import, I guess it must be quite reliable. Hmm...that i am not so sure.. Anyone?? Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 5, 2002 Share May 5, 2002 So where can we get ABS Trak installed if our cars do not come factory fitted? If C&C fix it up on the cars they import, I guess it must be quite reliable. Used to see lots of car with ABS Trax a couple of years back, when ABS was not the standard safety equipment.... But now since most (or ALL) new cars are ABS equipped, not sure whether there are still 3rd party ABS around... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 6, 2002 Author Share May 6, 2002 Point to note that ABS Trak may not be a "real" ABS which is modulated by electronic ECU plus hydraulic pump. I'll dig deeper and see whether I can find any info on aftermarket ABS Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 6, 2002 Share May 6, 2002 Point to note that ABS Trak may not be a "real" ABS which is modulated by electronic ECU plus hydraulic pump. I'll dig deeper and see whether I can find any info on aftermarket ABS Could be true...But I know nuts about them... Link to post Share on other sites More sharing options...
Guyver 1st Gear May 6, 2002 Share May 6, 2002 So where can we get ABS Trak installed if our cars do not come factory fitted? If C&C fix it up on the cars they import, I guess it must be quite reliable. U can do what i do.... M-ABS.... Manual ABS.... the mechanism.... your right leg... point of contact... your foot.... advantages is that u can choose to have ABS or not... but good ABS comes with some practise.... LOL!! Link to post Share on other sites More sharing options...
Davey Neutral Newbie May 6, 2002 Share May 6, 2002 (edited) ABS Trax? Heh heh ... Read the last article in this link -> http://www.lawpublish.com/march_1.html Edited May 6, 2002 by Davey Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 6, 2002 Author Share May 6, 2002 "An FTC Administrative Law Judge has found that the "ABS/Trax" add-on braking system marketed by Automotive Breakthrough Sciences, Inc. and ABS Tech Sciences, Inc., and purported to function just like factory-installed antilock brakes (ABS), does not, in fact, sense the rate of rotation of the car's wheels or the degree of wheel slip to correct such slippage" Think about the dangers those who "think" they have ABS might have been in! Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 6, 2002 Share May 6, 2002 "An FTC Administrative Law Judge has found that the "ABS/Trax" add-on braking system marketed by Automotive Breakthrough Sciences, Inc. and ABS Tech Sciences, Inc., and purported to function just like factory-installed antilock brakes (ABS), does not, in fact, sense the rate of rotation of the car's wheels or the degree of wheel slip to correct such slippage" Think about the dangers those who "think" they have ABS might have been in! I think Guyver's M-ABS is better...... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 6, 2002 Author Share May 6, 2002 Guyver probably can open door and stick out his Nike Air and do M-ABS much better! Link to post Share on other sites More sharing options...
Fabiaman 1st Gear May 6, 2002 Share May 6, 2002 Tks Davey.. that means the ABS Trak is a road hazard more than a help in emergency and "low margin of error" situations. *yurks!* Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 6, 2002 Share May 6, 2002 Guyver probably can open door and stick out his Nike Air and do M-ABS much better! Where is he??? So quiet without him around.... ↡ Advertisement Link to post Share on other sites More sharing options...
How Much Do You Know About ABS?
Mazda 5 ABS error
Mazda 5 ABS error
Understanding Anti-lock Braking System (ABS)
ABS warning lamp
ABS warning lamp
Honda Sensing
Honda Sensing
What is cheapest passenger car with auto gear & ABS
WRX intermittent ABS light & loss of power
Does 2006 Hyundai Verna 1.4A have ABS?
