Yeobh 4th Gear July 4, 2004 Share July 4, 2004 (edited) You can modify any thing unless you know the reason behind the design - if not don't do it. If you want to do, check how deep is yr pocket and how much time you can waste. Edited July 4, 2004 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
Kardachia Neutral Newbie July 4, 2004 Author Share July 4, 2004 (edited) >> You can modify any thing unless you know the reason behind the design - if not don't do it. If you want to do, check how deep is yr pocket and how much time you can waste. << Yup. Thanks. This coolant bypass mod will only cost a hefty $2.50 (for the brass barb fitting). Hehe. A lot of debate on its effectiveness. Some say got effect, some say no. Any way, I was wondering in this thread if doing any mod to a car will void BM's warranty. This is a simple DIY mod only. Brothers out there who change intake lah, add this, add that, wouldn't those void warranty as they are more major? Edited July 4, 2004 by Kardachia Link to post Share on other sites More sharing options...
Spindecker Neutral Newbie July 5, 2004 Share July 5, 2004 Does this mod "Poly-U Motor Mounts Inserts" works on your Matrix? Link to post Share on other sites More sharing options...
Zrun Neutral Newbie July 5, 2004 Share July 5, 2004 Yeah.. I installed mine already... http://matrix.newobject.org/tech/esinstall/ ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
Coolant question
Coolant question
What is the purpose of coolant
Coolant overflowing from expansion tank
Anti-Freeze or Coolant?
Need medical advice for heart blockage
VW Sharan 'drinks coolant.?
