Difference between Honda fit and jazz
Enilyks
Can anyone enlighten me wats the difference between honda fit and honda jazz? nothing important, jus to ease my curiosity... [confused]
same. Jazz=Fit
Fit is the JDM while Jazz is for export.
Fits running in SG are imported by PI while Jazz is distributed by the authorised dealer.
notice the red/ blue dot on the car? Red is 1.4L and blue is 1.5L... or is it the other way round? haahhaha tongue.gif
Posted: Sat May 15, 2004 4:30 pm Post subject: Differences between Fit1.3 and Jazz1.4
Which to get huh?? Jazz or Fit huh?? If this is something bugging you, listed here are the contributions from all bros in identifying the differences between FIT 1.3 and JAZZ 1.4. No similiarities is reflected here.
Jazz - Export purpose (EU)
Fit - Domestic (Both made from Japan)
Jazz - 83bhp
Fit - 86bhp (different ecu programming)
Jazz - side signal indicator
Fit - no side signal indicator
Jazz - rear seats only 1 angle
Fit - rear seats 2 angles
Jazz -to shift the seat forward lever at bottom of seat
Fit - lever at shoulder to shift the seat forward
Jazz - max speed on speedo is 220km/h
Fit - max speed on speedo is 180km/h
Jazz - master control for all door lock at the driver door
Fit - to lock all door, need to push the lock down
Jazz - air con is fitted locally
Fit - air con fitted in japan
Jazz - antenna at centre of roof
Fit - at right side, need to extract manually
Jazz - no factory fitted insulator for bonnet & firewall
Fit - factory fitted insulator for bonnet & firewall
Jazz - immobiliser key
Jit - no such function
Jazz - both sunvisor comes wif mirror
Fit - only driver's side has
Jazz - bigger front brake calipers
Fit - smaller
Jazz - aftermarket radio given
Fit - integrated sound system, freq not tuned to local station, needs to install FM modulator
Jazz - comes wif 4 speakers
Fit - only front 2
Jazz - comes wif mug like ash tray/container
Fit - doesnt have
Jazz - when reverse gear engaged, no sound
Fit - beeping sound when reverse gear is engaged
Jazz - front seats cannot fold all the way down and flush wif the rear
Fit - can bring down the front seats (w/o headrest) and flush wif the rear
Jazz - horns are at the left side
Fit - horns in the centre
Jazz - factory fitted rear wheel arc inner fender cover(lower portion)
Fit - dosen't come wif it
Jazz - manual transmission option
Fit - doesn't have
Jazz - fuel lid is not locked, but fuel cap is locked.
Fit - fuel lid is locked by cable operated
Jazz - Boot cover & Boot light in Jazz
Fit - doesnt have
Jazz - comes wif 2 pin to secure floormat in place
Fit - doesnt comes wif it
Jazz - has MPH reading on speedometer
Fit - only KMH
Jazz - Slight tinting on all windows for EU specs
Fit - JDM has rear heavy tinting which fails LTA specs.
Jazz - 3 yrs warranty
Fit - 1yr
extracted from Fit/Jazz Forum
Jazz - 83bhp
Fit - no side signal indicator (New Fit now has)
Fit - at right side, need to extract manually (New Fit also centre)
Fit - smaller
Jazz - aftermarket radio given (New Jazz also integrated radio)
Fit - only front 2
Fit - doesnt have
Fit - doesn't have
Fit - doesnt have
Fit - only KMH
Fit - 1yr
  Quote
same. Jazz=Fit
Thought Jazz is from Thailand while Fit is from Japan?
There is a huge factory in Thailand that manufactures Jazz. But some say its only for their domestic market. But it is also seen regularly that truck loads of such Jazz being transported to the port. [confused]
