Presea 3rd Gear September 26, 2002 Share September 26, 2002 (edited) Hi all, I realised that I have not asked this question here. I drive a 92 Presea (M). In my car, there is a "csshh" sound that comes from the engine bay when ever I change gears above 3000rpm (which is 95% of the time). It sounds like air being released through a valve. It is quite loud, and can be heard with the windows up. With windows down, I've heard it when in a building, and it would sound rather loud to a pedestrian next to the car. I do drive the car hard, and at every gear change up from 1st to 5th, it is always there. I've asked my mechanic a few times, he's even driven it to hear the sound, and he says that he doesn't know what it is. My engine is definitely stock (my mechanic vouches that), and I've never ever heard the same sound from another car. It is not like a blow of valve or waste gate, that I know. I have driven my car for a year, and never really cared, as I've grown accustomed to it. Please help Thanks Edited September 26, 2002 by Presea ↡ Advertisement Link to post Share on other sites More sharing options...
RadX Moderator September 26, 2002 Share September 26, 2002 Hmmmm...Do you think it could be the secondary fan??? In the E46, there were instances of a few of my pallies who had this loud kinda 'hummmmmmmm' sound, esp b4 warm-up. It was found to be the fan. Well, have to hear it to get closer to identify what it is.. Just my .02! Link to post Share on other sites More sharing options...
Presea 3rd Gear September 26, 2002 Author Share September 26, 2002 It's not a humming sound, but a rather short burst of air gushing out. It's almost like the car was sneezing Link to post Share on other sites More sharing options...
Eric Neutral Newbie September 26, 2002 Share September 26, 2002 (edited) You sure no one secretly lup turbo for you ? Edited September 26, 2002 by Eric Link to post Share on other sites More sharing options...
Super7 Turbocharged September 26, 2002 Share September 26, 2002 maybe it's a leak from the radiator?... does the radiator need top up often? juz guessing abit cheers (ps: any online racing tonite? i will log on between now and 12am, call me if you are also coming in ....) Link to post Share on other sites More sharing options...
Presea 3rd Gear September 26, 2002 Author Share September 26, 2002 Damn....my car really sprung a leak! I was driving some of my relatives home (9pm), and along the PIE, my car started to overheat. There was a leakage NOT at the radiator, but on a rubber hose above and behind the engine block. It's one of those thick black hoses. The entire radiator became empty, and obviously the car overheated. I have a question....the radiator is not leaking. And when I turn off the air con, the leakage stops! Does the air con take in water from the radiator? Is it linked somehow? Had to leave my car at the workshop an hour ago. Tomorrow will go down to see what's wrong. Link to post Share on other sites More sharing options...
Super7 Turbocharged September 26, 2002 Share September 26, 2002 the thick black hoses could well be the hoses that eventually connect the radiator to your engine, they channel the water to/from the engine from/to the radiator.... so if any on these hoses leaks, it empties the water in the radiator mah hope the workshop can fix it for you properly.... i think when the a/c is running, it requires more cooling at the radiator, and therefore higher water pressure in these hoses, when there's a gap/torn in the hoses, there will be a leak due to water pressure, or something like that..... cheers Link to post Share on other sites More sharing options...
Presea 3rd Gear September 26, 2002 Author Share September 26, 2002 I guess so, after all, the smell was like "radiator water". But its wierd, as the leakage stops altogether when the aircon is off. I expected some leakage if the hose was connected to the radiator. Maybe the water was all gone by the time I switched it off. Hope my engine is still okay after running at high temp for around a minute. Thought you were playing LFS? I will be watching the show "24" tonight, so no gaming for me. Link to post Share on other sites More sharing options...
Presea 3rd Gear September 26, 2002 Author Share September 26, 2002 I think the sound from my intial posting is linked to this leakage problem. Must be a small cut in the hose that created the initial sound, and tonight, the hole became bigger Link to post Share on other sites More sharing options...
Super7 Turbocharged September 26, 2002 Share September 26, 2002 was in LFS online for about 30 mins,.... saw no one from MCF, so logged off and come to MCF talk kock lor.... may go back for another 20 mins or so later... btw, what's '24'? me curious leh? cheers Link to post Share on other sites More sharing options...
Zrun Neutral Newbie September 26, 2002 Share September 26, 2002 My car had similar problem.. I hear hissing sound after my engine is turned off.. I opened the hood and found water stains near one of the radiator pipes... After I tighten up the brace, it is ok again.. Link to post Share on other sites More sharing options...
Presea 3rd Gear September 26, 2002 Author Share September 26, 2002 Hi Zrun. That's why I'm rather perplexed. I heard the hissing sound, and I opened the hood....radiator was fine, not leaking there. Then I realised the source was behind the engine. Took a torch (underground carpark), shone it there, and saw a mist coming downwards, with steam created as it fell on the engine block itself. I didn't think it was necessarily related to the radiator then. (No coolant coloured water) The reservoir was still full, so I didn't think it could have been that. I was driving home and the hissing started midway during my journey. For 2-3 mins, the airconditioner was quite warm, no cold air. I took it that is was related to the above problem, .....carried on driving Then the temp started to rise..... as I pulled out onto the expressway (PIE) And suddenly, as I was thinking about pulling over, the airconditioner kicked in, cold air came flowing out. After about 5 mins of everything being fine, the temp started to rise again... airconditioner was not working again (only fan) Switched off the airconditioner (button) and the hissing stopped when the aircon was switched off. But the temp started to get too close to MAX, so I pulled over, Switched off the engine, and the temp started to keep going UP. So I popped the hood, which by the way wasn't that warm.... started to touch various objects to see if they were hot (Engine was hot obviously) and then I found the radiator empty. So as I asked before....how's the aircon related to the radiator. I've seen many radiator leaks throughout my life, and never has one leaked so far up the engine bay. I'm not a mechanic, only a wannabe-racer. Link to post Share on other sites More sharing options...
Presea 3rd Gear September 26, 2002 Author Share September 26, 2002 I was not in the mood for playing LFS last night My baby's at the workshop Anyway, 24 is a action/thriller series starring the affable Kiefer Sutherland. About CIA - Presedential Primary - Assasination - Terrorism Fiasco. The coolest parts about the show is that it is actually like real-time, with 24 hours spread out over 24 (hour long) episodes, with many subplots running against each other concurrently, and the filming direction is so good that you can concentrate on all the various happenings on the several main characters, even though its complicated. The reason why I can't stop watching..... I've watched almost all (20) out of the previous 22 episodes, and last night was the 23rd episode. Next week, unless I'm lying dead somewhere, I'll definitely catch the last episode. It's like doing those 5000piece jigsaws. When you get to the end, there's no way you won't finish it. If you're just started, it's easy to put aside and forget, but once all the pieces are laid in place....there's a sense of accomplishment or something like that. cheers. Link to post Share on other sites More sharing options...
Super7 Turbocharged September 26, 2002 Share September 26, 2002 (edited) definitely sounds very interesting ......... is '24' shown on HBO? my basic SCV doesn't seem to show it Edited September 26, 2002 by Ysfoo Link to post Share on other sites More sharing options...
Presea 3rd Gear September 26, 2002 Author Share September 26, 2002 It's on Channel 5 every thursday at 12mn (sometimes earlier 11, 11.30) Link to post Share on other sites More sharing options...
Super7 Turbocharged September 27, 2002 Share September 27, 2002 Channel 5?.... very good, will not miss it next thurs... i heard some hsst hsst yesterday on the way to work, it came from the next lane, so i took a glance,..... wa, this Audi TT was juz next to my car abit behind, somewhere near the C-pillar (driver side).... Hsst Hsst Hsst again and it overtook me in a flash ..... you think it's trubo kicked in while overtaking me??.... i also wish my celica got Hsst Hsst to overtake it back.... day dreaming only cheers Link to post Share on other sites More sharing options...
Presea 3rd Gear September 27, 2002 Author Share September 27, 2002 TT has turbo....so it must be the blow off valve. I'm sure a 4A-GEU from a Toyota Levin (an Intial D car) will fit in your engine bay then you can hiss everywhere! Link to post Share on other sites More sharing options...
Super7 Turbocharged September 27, 2002 Share September 27, 2002 yup, if the present engine konks out one day, i will definitely put a 4AGE series engine in it, then you will hear hsst hsst next to your ears in your Presea.... maybe by then your Presea already got a monster in the engine bay??? cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Old WW2 Relic disposals
