Help needed urgently!!!!
Andy
to all bros,i have a problem i cant solve,pls help me if you can.thanks.
when the a/c is on,when i release the accerator the rpm will drop to ard 500 plus
sometimes the engine will cut off aso.but when the a/c is not on,this problem does
not happen.i have change the a/c compressor to a recon one but it does not help.
pls advice..i am driving eg9.thanks
Sorry, me not familiar with your model EG9.
But it looks to me like......your ECU got problem liao. Usually, when you switch on a/c, it should compensate it. Apparently, it's not happening.....
But what about if there's no a/c? How much is the normal idle rpm?
[sunny]
hey bro,how to check if is dirty??any recommend place to clean??
you can DIY if you want to, else just bring to your regular mech to ask he to clean for you wink.gifwink.gifwink.gif if you need to DIY, I have lobang for the STP can spray cleaner sly.gifsly.gifsly.gif
well, unless he come to meetup to let us see the "patient", we can only speculate....tongue.giflaugh.gif
