Dookie Neutral Newbie May 30, 2004 Share May 30, 2004 Anyone out there knows where to get a good solid strut bar for Civic 03? any undercarriage strut bars for front and back axles also? ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie May 30, 2004 Share May 30, 2004 Plenty in JB and very cheap too...abt rm 120-150... Link to post Share on other sites More sharing options...
Wiredchaos Neutral Newbie May 31, 2004 Share May 31, 2004 Plenty in JB and very cheap too...abt rm 120-150... hmmm .... hope u guys dun mind but wat do u look for when u gettting a strutbar?? weight? material ?? Hope u guys could help.. thnks Link to post Share on other sites More sharing options...
Redeel Neutral Newbie May 31, 2004 Share May 31, 2004 Have you lowered your suspension? Changed the springs? Strut bar would be useless if your springs are not changed to lower the car... It will make you feel different, yes... But more to the inseure sense. eddie Link to post Share on other sites More sharing options...
Vidz 6th Gear May 31, 2004 Share May 31, 2004 Have you lowered your suspension? Changed the springs? Strut bar would be useless if your springs are not changed to lower the car... It will make you feel different, yes... But more to the inseure sense. not exactly true... while lowering does increase stability, struct bar increase body rigidity... thus in overall handling, although struct bar effectivenees is not as great as lowering, it still improves the ride. And you are talking about tens of dollars verse hundreds/thousands for lowering setup... best if have both!! Link to post Share on other sites More sharing options...
Redeel Neutral Newbie May 31, 2004 Share May 31, 2004 I tried having a strut bar with no other modifications to my lancer... The corners felt scarier than before!!! Anti-roll bar is more effective lah. eddie Link to post Share on other sites More sharing options...
Vidz 6th Gear May 31, 2004 Share May 31, 2004 i did felt much better with struct bar on... my old sunny comes with stock roll bars tho... not sure of the reason for your case... Link to post Share on other sites More sharing options...
Redeel Neutral Newbie May 31, 2004 Share May 31, 2004 Maybe it's just the Lancer? eddie Link to post Share on other sites More sharing options...
Morgan01 Neutral Newbie June 21, 2004 Share June 21, 2004 Anyone out there knows where to get a good solid strut bar for Civic 03? any undercarriage strut bars for front and back axles also? alutec strut bar for ES : 1) front (ver.2.0) - $150 2) rear - $150 3) lower tie - $110 4) rear + lower tie - $250 5) full set - $380 all prices w/install _________________ MotoRex Autowerkz & Trading Tel : (65)6289 4188 / Mobile : 9637 4996 Fax : (65)6289 9226 Email : [email protected] Link to post Share on other sites More sharing options...
Zrun Neutral Newbie June 21, 2004 Share June 21, 2004 (edited) I think you won't feel much difference with strut tower bars unless you take corners VERY aggressively. With regular turns, the car's chasis only twist minimally. But the effect of the roll is much more pronounce and throws off your camber. My recommendation is to get upgraded anti roll bars before getting strut tower bars. However, STB looks good when you expose your engine. You'll experience a huge difference with anti roll bars. Edited June 21, 2004 by Zrun Link to post Share on other sites More sharing options...
Lightspeed Clutched June 21, 2004 Share June 21, 2004 ARBs are the way to go Link to post Share on other sites More sharing options...
Dookie Neutral Newbie June 22, 2004 Author Share June 22, 2004 Installed the front strut bar (ver 2.0). However I noticed that when turning lock to lock, there will be a sound coming from the strut bar, as though it is being twisted or stretched. Any answers or similar problems faced by others? Link to post Share on other sites More sharing options...
Minicooper Neutral Newbie August 22, 2005 Share August 22, 2005 maybe the strutbar is not firmly installed? Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 22, 2005 Share August 22, 2005 bro, you are replying to a thread that's more than 1 yrs old liao Link to post Share on other sites More sharing options...
Minicooper Neutral Newbie August 22, 2005 Share August 22, 2005 haha .. i didn't know leh .. was searching for strut bars thread ... Link to post Share on other sites More sharing options...
Elkh Neutral Newbie August 22, 2005 Share August 22, 2005 I'm also interested to install strut bar on my lancer... but need to hear from those who had done it to know if it will reduce body roll... Maybe can re-open this thread for discussion.... Link to post Share on other sites More sharing options...
Normal_aspirated Clutched August 22, 2005 Share August 22, 2005 can try the "Summit" brand from Fong Kim@Ubi? Link to post Share on other sites More sharing options...
Kax2 Neutral Newbie August 22, 2005 Share August 22, 2005 Just installed the summit brand today. The strut bar is a weird orange color on the sides but looks racy to me. There are some funny sounds when I turn the wheels but I saw the mechanic tightened the nuts really hard. Not sure what the noises are but I can surely feel the different esp during sharp cornering. When turning to the left can feel right side heavier sorta trying to balance the car. However I feel more effect when going over a hump. I can feel the front strut bar reducing the vibration on the front wheel, while the rear wheels have more vibrations. Seems to me that the strut also helps to improve ride comfort when going over humps. ↡ Advertisement Link to post Share on other sites More sharing options...
2014 Honda Odyssey
2014 Honda Odyssey
[Concept] Honda 0 Series EVs
Honda Vezel - Part 3
Any recommended tyre shop
Takata airbag recall
