Vass Neutral Newbie May 26, 2004 Share May 26, 2004 In Japs car the rubber seal normally runs along the door perimeter but for the octy the strip is glued on the car frame. For my almost 3 yr old octy, some part has lost the "sticky-ness" and looks awful. Any one also encounter this problem ? Any special glue or tape that can use to secure it back ? ↡ Advertisement Link to post Share on other sites More sharing options...
Virus 2nd Gear May 26, 2004 Share May 26, 2004 Glue should do the work. But need to find those can tahan heat. May be can call Servo what type of glue they use. Link to post Share on other sites More sharing options...
Fortress Clutched October 27, 2005 Share October 27, 2005 Understand that this happened to you about 1 years ago, it happened to mine now, due to my daughter stepping in and out on the seal. Can you be kind enough to share what kind of glue did you use. Link to post Share on other sites More sharing options...
Skodee Neutral Newbie October 27, 2005 Share October 27, 2005 Yes it happen to mine too...and somemore my roof fabric that supposed to stick sag down now at the rear passenger seats...probably after hundreds of *thuds* when closing our boot... Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie November 16, 2005 Share November 16, 2005 my internal rubber seal peeled off too.....im temporary using the glue tat i use to paste my shoe sole on tat stupid seal but it wont last long... best is to hammer a nail and lock it down permanently Link to post Share on other sites More sharing options...
Fortress Clutched November 17, 2005 Share November 17, 2005 (edited) Tried what you said, but the contact adhesive for shoes cannot take the heat. Solved mine using sealant for engine seal, it is as good as new. Nailing it in will cause rusting from cathodic corrosion, which is even worse. Edited November 17, 2005 by Fortress Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie November 17, 2005 Share November 17, 2005 k i try to use the sealant. thanks Link to post Share on other sites More sharing options...
Skodee Neutral Newbie November 18, 2005 Share November 18, 2005 Where did you get those sealant? Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie November 18, 2005 Share November 18, 2005 i go to my workshop to find... Link to post Share on other sites More sharing options...
Fortress Clutched November 20, 2005 Share November 20, 2005 (edited) Got it from a DIY shop in Bugis (brother's shop), still have quite a lot, if you are around Serangoong North Area,, I can help you. It takes about 10 to 15 mins to fix, but the coffee will cost you. Edited November 20, 2005 by Fortress Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie November 20, 2005 Share November 20, 2005 kk hehee. ask u another thing. i jus got a quote for timing belt, fan belt, remaining belts & water pump change at 600 including labour. is tat ok? Link to post Share on other sites More sharing options...
Fortress Clutched November 20, 2005 Share November 20, 2005 Not too sure, the guys might be better at it, usually do them seperately, to budget my cost and also time. Do the timing belt and water pump first. The rest of the belt can do later. Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie November 20, 2005 Share November 20, 2005 k Link to post Share on other sites More sharing options...
Skodarr Neutral Newbie November 21, 2005 Share November 21, 2005 Well, IMO I think do it together will be best as it's at the same location ... Furthermore, you will save another labour cost and time ... Price is also reasonable dude ... Link to post Share on other sites More sharing options...
Fortress Clutched November 22, 2005 Share November 22, 2005 To each his choice. I was refering to doing it at different stages of maintenance....and also working within my own time(DIY) Link to post Share on other sites More sharing options...
Skodarr Neutral Newbie November 22, 2005 Share November 22, 2005 Link to post Share on other sites More sharing options...
Putter Neutral Newbie November 23, 2005 Share November 23, 2005 (edited) Osp... Edited November 23, 2005 by Superb ↡ Advertisement Link to post Share on other sites More sharing options...
Is Wide Body Kit Illegal??
Income tax Evasion
Income tax Evasion
Disputes between neighbours - A True story
Both BYD and Tesla will now sell you Cat A versions of their popular Seal and Model 3 saloons
Scrap Value for my Integra
Where can I get rubber sheet
