Madarmour Neutral Newbie September 26, 2002 Share September 26, 2002 So far, those I've tried myself, 1) CSC - sports touring tyre with a relatively quiet and comfrotable ride. 2) Toyo R1R - Superb traction but not so good in wet. Soft and sticky compound so will not last. Best for cornering! 3) Kumho 712 (currently using) - traction a shade lower than R1R but should be comparable to AVS Sports. Overall, cheap and good! No regrets. From friend's feedback on similar car, 1) Yoko AVS Sports - very good traction both in wet and dry. 2) Michelin Pilot Sports - very good traction in wet and dry. 3) Toyo Vimode - very similar to AVS Sports in performance. Just my $0.02. ↡ Advertisement Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie September 26, 2002 Share September 26, 2002 Hi Mike, Is that Richard's comment on the Yoko AVS Sports? I personally likes the wet grip. Now always looking for puddle of water to charge thru... The only thing is the noise level..... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie September 26, 2002 Share September 26, 2002 I had 2 close friends who's using or had used that tyre and yes, Richard is one of them. Abt the noise level, well........can't have all the good things right? BTW, high performance tyres cannot be quite and vice versa. Just blast your boom chit chit lor! Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie September 26, 2002 Share September 26, 2002 used that to cover my wife's sound.... now got to use to cover the tyre noise too...... Link to post Share on other sites More sharing options...
Zolidlim Neutral Newbie October 22, 2002 Share October 22, 2002 So which tyre is better in the sense of the below: 1. Noise level low 2. Better grip in wet and dry Link to post Share on other sites More sharing options...
User12343 Clutched October 22, 2002 Share October 22, 2002 speaking of that, what's the max inflation load on the aspec 205/50/16? i dont find the rating on the sidewall of the rubber leh... I think Aspec dB is one of the quietest around. Have never tried it myself but that's the general feeling I get after reading through the few car forums. Not really cheap, though. You can try Leong Seng at Kaki Bukit or Alexandra Road. One of the most competitively priced place. Link to post Share on other sites More sharing options...
Presea 3rd Gear October 22, 2002 Share October 22, 2002 If you don't mind changing when it gets noisy (after approx 20K), Azenis ST115 should suit the bill. esp in the wet! Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie October 23, 2002 Share October 23, 2002 Mitlover, If you are comparing the Yokohama Aspec DB and the AVS Sports, then the answer to your questions are obvious: 1. Noise level low => Aspec DB 2. Better grip in wet and dry => AVS Sports (or rather excellent grip in both conditions) Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie October 23, 2002 Share October 23, 2002 Duh..........I don't really know the inflation load of the aspec 205/50/16 as I've never used the tyres before but I'm sure it's way above the usual pressure we pump for daily use. I'm using 33psi for my daily runs for my 205/55 15" and pump it up to 35psi for my occasional jaunts in Malaysia. Hope it helps. ↡ Advertisement Link to post Share on other sites More sharing options...
What kind of massage you like the most?
The world’s most powerful passports
