Elson84 Neutral Newbie July 5, 2004 Share July 5, 2004 normally if ppl wanna fix sc or tc shld be on NA car rite as those tc or sc car already have le.. eniway some car no tc or sc also can fix BOV ? ↡ Advertisement Link to post Share on other sites More sharing options...
Phochem Neutral Newbie July 5, 2004 Share July 5, 2004 Thats only when u want to fix an electrical BOV (basically a speaker that produce the sound) that mimics the real McCoy. No car will require to fix a BOV if its not T/C. Even a T/C'ed car still can swap for a bigger turbo. Small snail grows big..... Anyway to T/C any car is no means normal liao. Link to post Share on other sites More sharing options...
Elson84 Neutral Newbie July 5, 2004 Share July 5, 2004 fixing tc on na is illegal ritez ? normally how much will it cost to fix tc including everything needed to support it ? Link to post Share on other sites More sharing options...
Blackhatch Neutral Newbie July 10, 2004 Share July 10, 2004 which stage turbo u talking abt and to what extend u wanna strength the engine? how high u wanna boost? i know of people doing it for 3k and i knoe of people who did it for more.. but the bottomline is you gotta ask yourself the above qns 1st Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 10, 2004 Share July 10, 2004 hi, is the electrical BOV available in spore? hahaha can org a group buy for it Link to post Share on other sites More sharing options...
Silver_z 1st Gear July 13, 2004 Share July 13, 2004 Is it possible to install a BOV in an NA car just for the sound effect? What are the components involved in the installation? Why would you wanna do that? So that ROV will pull you over always when you "psstt" pass them? By the way, if you still want it, came across a website where they teach you how to DIY yourself using your car horn speaker. Dun ask me how, i also dun understand. lol! Link to post Share on other sites More sharing options...
Soya Supersonic July 13, 2004 Share July 13, 2004 i know how to DIY! juz pout yr lips and close yr teeth while pushing out air. onli setback is that yr windscreen may get a bit wet..... Link to post Share on other sites More sharing options...
Silver_z 1st Gear July 13, 2004 Share July 13, 2004 Wah kaoz!! Then must install internal wipers liao. Link to post Share on other sites More sharing options...
Dwoon 1st Gear July 13, 2004 Share July 13, 2004 normally if ppl wanna fix sc or tc shld be on NA car rite as those tc or sc car already have le.. eniway some car no tc or sc also can fix BOV ? Aiya....... just go & do a CAI with open pod and you'll get that awful "psssttt" sound liao whenever you let go the throttle after heavy footing it. Not as loud as a true BOV but quite similar. At least you still get some benefit out of the CAI rather than just sound...... Link to post Share on other sites More sharing options...
Luckcent 4th Gear July 13, 2004 Share July 13, 2004 Open pod will not give you the pssst but the vroom sound lah. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 13, 2004 Share July 13, 2004 open pod is ong lai or cone? Link to post Share on other sites More sharing options...
Phochem Neutral Newbie July 13, 2004 Share July 13, 2004 open pod will not give the "pssst" sound leh. Link to post Share on other sites More sharing options...
Dwoon 1st Gear July 14, 2004 Share July 14, 2004 From what I've experienced from friends' cars, doing CAI with stock air filter box gives only a slight pssst sound. However, when the stock box is removed and replaced with a pod (although pod is in the wheel hub & out of the engine comp), the pssst sound is very much louder. The pssst sound occurs when hard throttle is released and is not the sucking sound (CAI) or vroom sound (Pod) when throttle is depressed. Perhaps the characteristic is different for NA cars as the experience I had were on TC cars when exploring what setup I'd prefer should I do CAI. Cheers! Link to post Share on other sites More sharing options...
Dwoon 1st Gear July 14, 2004 Share July 14, 2004 What is ong lai??? Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 14, 2004 Share July 14, 2004 its a kind of air filter.. looks like pineapple (ong lai).. but i dunno if its proper name is open pod or cone or what? ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
Toyota Axio 1.5L 2007 Engine Valve Cover Gasket & Plug Seal
Bridgestone Pink Valve Cap Donation Drive
Tire air pump difficulty
Fumoto Oil Drain Valve
$195 for valve cover gasket and plug seal?
Aircon Blow Hot Air
Aircon Blow Hot Air
