Goodspeed Clutched May 6, 2004 Share May 6, 2004 oic, if front brake different braking force. how to adjust it>? i adjusted my rear one... it was better. anyway i hear if buy new tires from the shop they will help you do rotation? when is the recommended mileage for wheel rotation or balancing ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 6, 2004 Share May 6, 2004 If it is a disc brake, try cleaning the pad and disc. The other check is the front bearing. if they have too much free play , replace them. Link to post Share on other sites More sharing options...
Goodspeed Clutched May 6, 2004 Share May 6, 2004 where and what is the front bearings>>?? Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 6, 2004 Author Share May 6, 2004 Hehe, i also using Dunlop LM702 for all four tires... Actually mine drifts left whether braking or not. Low speed not so obvious lah. Think i'll send it for alignment within next few days. Was wondering, each model has different camber and toe settings for the wheels rite, so is it advisable to send the car for alignment at private workshops? Would they know the correct settings? Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 6, 2004 Share May 6, 2004 It is located in the centre of the brake disc. Jack up your car, place one hand on the tyre outer diameter and the other diagonally opposite - move both hand in opposite direction. If you feel there is too much free movement, then it is time to replace the bearing. Link to post Share on other sites More sharing options...
Goodspeed Clutched May 6, 2004 Share May 6, 2004 i think it is the tires problem... i also not sure.. went to riverview kenny and after he aligned it was still the same problem but not so bad already... anyway tell me your result maybe it is only my car riverview PRO one they sure know.. what is ur ride anyway Link to post Share on other sites More sharing options...
Goodspeed Clutched May 7, 2004 Share May 7, 2004 i think that is to check whether my tie rod or steering rack is lossen because that was the same method the mech show me that my tie rod tie is spolit.. correct me if i am wrong anyway the tire is not really linked to the tire right? centre of the brake calliper....i take out and see thanks a lot Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 7, 2004 Share May 7, 2004 Right way to do. Need to have the right feel to know what is not right. Placing hands at 12 and 6 o"clock position and at 3 and 9 will give different feelings. Link to post Share on other sites More sharing options...
Goodspeed Clutched May 10, 2004 Share May 10, 2004 Oic.. the mechanic already done it for me ↡ Advertisement Link to post Share on other sites More sharing options...
Encounters with tyre shop
Suu Kyi detained
Suu Kyi detained
Neighbour from the artic
Renal failure on the rise
