Ace_t Neutral Newbie March 3, 2004 Share March 3, 2004 done at CAS abt 1 yr ago. funny thing only one side was cracked.... suspect poor quality. can see from underside that it craked in both places. ↡ Advertisement Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie March 3, 2004 Share March 3, 2004 "suspect poor quality." Hi! there, Ace_T, Previously, when I was driving a Honda Civic, I'd apply a bit of grease, on the bellows of the boot, where it touches each other, to prevent too much friction, caused by turning. Rgds Paul Yong Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie March 3, 2004 Share March 3, 2004 did it help ? interesting idea.... thot the boot would only extend or compress while the CV bar was turning. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie March 3, 2004 Share March 3, 2004 Hi! there, Ace_T, The boot turns together with the drive shaft, so the bellows are touching as it roll along, during a turn. Rgds Paul Yong Link to post Share on other sites More sharing options...
Vtim 3rd Gear March 5, 2004 Share March 5, 2004 Noise from the cv-joint happens when the grease has leaked out from the dust-boot, then no more lubrication. also because sand & small particles get stuck inside the joins Link to post Share on other sites More sharing options...
Greddy82 1st Gear March 9, 2004 Share March 9, 2004 if there s is a chirp chirps sound from my left wheel everytime i steeped on and off the accelerator pedal,issit due to the driveshaft as well??? cos my car is making the irritating noise everytime i step on the accelerator.. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie March 9, 2004 Share March 9, 2004 "issit due to the driveshaft as well???" Hi! there, Greddy82, Check the ball-joint at the tie-rod. See also the wear pattern of your brake rotor. Rgds Paul Yong Link to post Share on other sites More sharing options...
Greddy82 1st Gear March 10, 2004 Share March 10, 2004 how to check huh... im an idiot when comes to mechanic but interested to learn... :) Link to post Share on other sites More sharing options...
Quikfire Neutral Newbie March 10, 2004 Share March 10, 2004 I just changed both my front drive shafts for less than $400.. new ones.. not recon... while you are changing yours, i suggest u replace the oil sill too... Recently whenever I do a left or right turn or U-turn there are rattling sounds from my drive shaft. I guess its gone. Need a reliable workshop. Went to CAS n was quoted S$450. Went to Proserv n was quoted S$400. For both drive shaft. My car '89 Honda Civic GL. Any cheaper and reliable workshop??? Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie March 10, 2004 Share March 10, 2004 "but interested to learn..." Hi! there, Greddy82, The first thing you need to know, is the parts of your car, where it's located, how it's assembled & removed. Finally, how to trouble-shoot defective components. A mechanic is more experienced in all this, so send it to your w/shop. If you can re-create the noise just by rocking your car, then it's something that's rubbing, most probably it's the suspension system, things like the anti-roll bars and it's mountings or shock absorbers. Jacking the car up may disengage all contacts. Make sure the parts in the wheel well are secured properly and not touching any suspension & brake components. Check also your engine mounts and exhaust system. Rgds Paul Yong Link to post Share on other sites More sharing options...
Adrianli Hypersonic March 10, 2004 Author Share March 10, 2004 Hi I've already changed it liao at Proserv for $420. $20 for GST. All oil n stuff included. Now at least I have a peace of mind. No more clark clark sound when turning. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie March 10, 2004 Share March 10, 2004 Link to post Share on other sites More sharing options...
Golfer Neutral Newbie March 10, 2004 Share March 10, 2004 Had the same problem with my 5 years old Nissan Sunny SS after I got it from a second hand car dealer. Changed at a Workshop in Tampines --> MotoGard [AAA approved workshop]--> $500 a) Purchased car in July 03 at 40k Km after surrender 2.3 years old Hyundai Trajet due to poor resale value and high fuel consumption [7km/litre] b) Changed drive shafts in Sept 03 after motorised bicycle bang into rear left door & bumper. Kind of repair at the same time. c) Complain rattling noise in Nov 03 on full right turn. Changed FOC. d) Complain rattling noise in 7 Feb 04 on both left and right. Changed FOC-->transmission oil inclusive. Feedback from workshop is that 3 customers had the same problem and workshop claim parts were made in Thialand. Suspect it may be a batch issues. Didn't argue as it is a FOC changed. Don't really know whether it is recon or new but visually, it looks new. Since 7 Feb 04, both drive shafts are doing fine as I try not to do full-lock in Multi storey Carpark or U turn. Advise from experienced driver is not to frequently over stretch the drive shaft. Hope this helps and I am still monitoring. Regards, Link to post Share on other sites More sharing options...
Greddy82 1st Gear March 12, 2004 Share March 12, 2004 is motogard a good workshop??? intend to do servicing over there??? Link to post Share on other sites More sharing options...
Toyo 1st Gear March 13, 2004 Share March 13, 2004 I used to be a regular customer. having sent my car there for servicing and repair. fast turnaround time but i feel a bit costly. Link to post Share on other sites More sharing options...
Golfer Neutral Newbie June 29, 2004 Share June 29, 2004 It coming to 4 months since I changed both drive shafts. Already covered about 13,000km and being to KL and back. No rattling sound during U turn and looks like the drive shafts are doing welll. Maybe it is really a material or shaft worksmanship issue. I think Motorgard is ok as they do honour warranty replacement due to parts premature failure. Do be take note workshop tends to ask you to change tyres etc, etc, etc. I am using their service pkg of using ELF synthetic engine oil at $45 [including flter change] and so far it seems ok i.e. no overheating or abnormal noise. Cheers, Link to post Share on other sites More sharing options...
Toyo 1st Gear June 29, 2004 Share June 29, 2004 Wow! u clocked 13,000km in 4 months!!! Their servicing package using ELF oil is value for money and i have used it many times but they always physcho me change this change that.. thats why very scared to go there. Now every servicing must go back to agent due to warranty and a basic servicing is so ex... Link to post Share on other sites More sharing options...
Krislou80 Neutral Newbie September 28, 2010 Share September 28, 2010 One or both of your cv boot/s is torn or has a hole in it. the cv boot keeps the drive shaft lubricated and dirt/debris out of the gears that turn your wheels. chances are that you might already need a new half shaft. _______________________________________________ AMO Drive Shaft Flange Kit - Direct OE Replacement Part ↡ Advertisement Link to post Share on other sites More sharing options...
Driving in Europe
Driving in Europe
Strange Mural at Holland Drive Food Center
Cars We Don't Get to Drive in Singapore
Malaysia: Drive up to Malacca
