Turbobrick Neutral Newbie February 12, 2002 Share February 12, 2002 (edited) Interesting tip (See pic) Edited February 12, 2002 by Turbobrick ↡ Advertisement Link to post Share on other sites More sharing options...
Fabiaman 1st Gear February 12, 2002 Share February 12, 2002 Woah... tks for the pics. I have a stupid question, I am not good at all in all these - so how do we determine when we buy a tyre what is the best tyre width for the rims that we have? I like to have the type of rim/tyre combi in the middle, so that means I shld take the widest tyre my rim can take? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie February 13, 2002 Author Share February 13, 2002 Well it all depends on which rim you choose and whether U have a choice of the rim thickness first. Getting a thick tire may be your preference but do take note of the steering clearance or U may have the thick tire rubbing the inner wheel well Link to post Share on other sites More sharing options...
DoctorDrake Neutral Newbie February 17, 2002 Share February 17, 2002 Yes, but don't forget that you should avoid changing the overall diameter. (Did we cover this before in another thread?) The main reason for not changing the rolling circumferenceis that you speedo- and odo-meters won't need recalibration. Furthermore, the manufacturer chose the specific rolling circumference to match the gearing ratio of your tranny. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie February 17, 2002 Author Share February 17, 2002 There's an interesting overall rolling diameter online calculator link here http://www.mycarforum.com/forum/gforum.cgi?post=573; Link to post Share on other sites More sharing options...
DoctorDrake Neutral Newbie February 17, 2002 Share February 17, 2002 And more information here: http://www.tirerack.com/tires/knowtire.htm Link to post Share on other sites More sharing options...
User12343 Clutched March 1, 2002 Share March 1, 2002 that means choose rims first then get the installer to match the rubbers izzit? will mix-and-match by ownself cause problems? Well it all depends on which rim you choose and whether U have a choice of the rim thickness first. Getting a thick tire may be your preference but do take note of the steering clearance or U may have the thick tire rubbing the inner wheel well Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 1, 2002 Author Share March 1, 2002 Yup! Doesn't have to be the installer's recommendation all the time. I chose my own rubba to match my 17" rims. The shop actually ordered the wrong size (i.e. 17x8 instead of 17x7) and told me that my 215/45R17 rubba can fit but I rejected them. Told them to bring me the right size and waited another two weeks.... ↡ Advertisement Link to post Share on other sites More sharing options...
Do I need to change tire ?
Tire patching types and prices
Spare tire. do u remove or leave in boot?
Continental's New Sustainable Tire Concept Revealed At Munich
Top Quiet Car
Top Quiet Car
Spare Tire - where can I find a replacement?
Valve stem washer?
Valve stem washer?
