Ahleon Neutral Newbie January 13, 2004 Share January 13, 2004 They are SHITs!!!.... My previous ride kena accident, bring to them...done up everything....sprayed..but never apply rubber sealant on joints of welding...den RUSTED... Anyway..that incident is the catalyst for the luv with my current babe... ↡ Advertisement Link to post Share on other sites More sharing options...
Chromas 1st Gear January 13, 2004 Share January 13, 2004 Sorry to hear that, bro I will check my ride properly when I get it back... thanks for the tip Link to post Share on other sites More sharing options...
Acemundo Supercharged January 13, 2004 Share January 13, 2004 hee......should have guessed. Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 13, 2004 Share January 13, 2004 For safety, the best option it to replace the the caliper, piston and seals. Since the car is already 30 years old.Your chance of getting new or re-cond repalcements is very slim. The best option is to rebuilt the caliper (need honing and polishing process) and get new piston and seals. Once you have settle this problem, remember to flush your brake system as the possible cause for your brake failure is comtaminated brake fluid with high concentrated % of water. Happy searching and good luck Link to post Share on other sites More sharing options...
Super7 Turbocharged January 13, 2004 Author Share January 13, 2004 Well, check the price first as sometimes, servicing cost as much as changing a new caliper...somemore your car so old liao.... hmmm..... yahor, i will get a quote for it... thanks Link to post Share on other sites More sharing options...
Super7 Turbocharged January 13, 2004 Author Share January 13, 2004 need to see the damage to the caliper first, sometime just have to replace the rubber sealant (Caliper Piston repair kit), provided they still have for your model I presume for the Celica, right i think whichever workshop i eventually use, i will watch how they do it and see the damage with my own eyes. ....... thanks Link to post Share on other sites More sharing options...
Super7 Turbocharged January 13, 2004 Author Share January 13, 2004 i know where's that row of workshops, will drop by this week to check .... thanks Link to post Share on other sites More sharing options...
Super7 Turbocharged January 13, 2004 Author Share January 13, 2004 your kakis leh ? my kakis' workshops are beli far, some in eunos, some bukit merah..... Link to post Share on other sites More sharing options...
Super7 Turbocharged January 13, 2004 Author Share January 13, 2004 you might wan to try this , remove the brake pads push the caliper piston out a little by applying (pumping) the brake pedal and observe which side of the piston is jammed or sticky........ than apply some brake fluid over the piston and push it back with a spanner or screw driver do this a few times maybe will help, especially for old car if not try to get hold of set of caliper repair kit and get it service. thanks for the info, i find it very useful for a novice like me , i am sure some 'lau chiaos' here also feel the same, thanks Link to post Share on other sites More sharing options...
Super7 Turbocharged January 13, 2004 Author Share January 13, 2004 (edited) For safety, the best option it to replace the the caliper, piston and seals. Since the car is already 30 years old.Your chance of getting new or re-cond repalcements is very slim. The best option is to rebuilt the caliper (need honing and polishing process) and get new piston and seals. Once you have settle this problem, remember to flush your brake system as the possible cause for your brake failure is comtaminated brake fluid with high concentrated % of water. Happy searching and good luck yup, agree that for safety i should not be counting every cent, what i need is someone who can do a good job but dun over charge me Edited January 13, 2004 by Super7 Link to post Share on other sites More sharing options...
Chromas 1st Gear January 13, 2004 Share January 13, 2004 If you're there tomorrow or Thur, maybe you can get to see my Vios in its black glory before I do... hee hee... SFB plate... Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 13, 2004 Share January 13, 2004 i think whichever workshop i eventually use, i will watch how they do it and see the damage with my own eyes. ....... thanks make it a habit to hang around when they are doing the job unless it's normal oil servicing Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 13, 2004 Share January 13, 2004 never compromise on safety.. Link to post Share on other sites More sharing options...
Super7 Turbocharged January 13, 2004 Author Share January 13, 2004 i will try to be the spy if i go there before you Link to post Share on other sites More sharing options...
Chromas 1st Gear January 13, 2004 Share January 13, 2004 HEY... but dun spoil the fun and tell everyone here ok??? Must still leave the honour of posting it up for me, right? Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie January 14, 2004 Share January 14, 2004 "my kakis' workshops are beli far" Hi! there, Uncle Foo, Do you want to send your ceelica to AMK AutoPoint? Rgds Paul Yong Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 14, 2004 Share January 14, 2004 I think he is in JB now... Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie January 14, 2004 Share January 14, 2004 "he is in JB now..." Hi! there, Saaber, VERY DANGEROUS to drive in JB with jammed brake calipers. Rgds Paul Yong ↡ Advertisement Link to post Share on other sites More sharing options...
Simple home DIY repairs
Brake Pads
Brake Pads
Getting your car refreshed for CNY: paint / polish / ceramic
Brake squeak every morning
