Super7 Turbocharged January 14, 2004 Author Share January 14, 2004 you found any RM4 games ah???..... ↡ Advertisement Link to post Share on other sites More sharing options...
Super7 Turbocharged January 14, 2004 Author Share January 14, 2004 two of you bad lah, always talk about ahlians here.... but i could see your eyes opened big big when JB ahlians are around Link to post Share on other sites More sharing options...
Super7 Turbocharged January 14, 2004 Author Share January 14, 2004 If you're there tomorrow or Thur, maybe you can get to see my Vios in its black glory before I do... hee hee... SFB plate... if i go during thursday lunch time, wil there be anymore for me to spy?? Link to post Share on other sites More sharing options...
Super7 Turbocharged January 14, 2004 Author Share January 14, 2004 "my kakis' workshops are beli far" Hi! there, Uncle Foo, Do you want to send your ceelica to AMK AutoPoint? Rgds Paul Yong AutoPoint is within walking distance from my place (i think about 20mins), so it's convenient!! ... any workshop that i should visit and wont be ripped off?? thanks Link to post Share on other sites More sharing options...
Super7 Turbocharged January 14, 2004 Author Share January 14, 2004 not that car but the ASStrek lah... the effects of the strut bar is quite obvious!! Link to post Share on other sites More sharing options...
Chromas 1st Gear January 14, 2004 Share January 14, 2004 My car will only be in its full glory on Fri lunch time... so spy all you want Link to post Share on other sites More sharing options...
Super7 Turbocharged January 14, 2004 Author Share January 14, 2004 http://www.mycarforum.com/forum/gforum.cgi...t=442275#442275 howz your practice??? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 14, 2004 Share January 14, 2004 sssshhhhh Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 14, 2004 Share January 14, 2004 so good lah Link to post Share on other sites More sharing options...
Mavvy Clutched January 15, 2004 Share January 15, 2004 you found any RM4 games ah???..... hard to find RM4 stuffs.. gotta wait for yours kangtao.. Link to post Share on other sites More sharing options...
Mavvy Clutched January 15, 2004 Share January 15, 2004 erm... taking some sweet time to train up.. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 15, 2004 Share January 15, 2004 of course... Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear December 12, 2011 Share December 12, 2011 http://www.mycarforum.com/forum/gforum.cgi...t=442275#442275 howz your practice??? Re up this thread. My front left caliper also jam. same symptoms as yours. How was your fix? What did the workshop do for you and should i replace calipers? Was thinking go for BBK if replace caliper is ex. normal servicing of piston and change of brake oil is sufficient or does it keep recurring? Dun feel safe driving around if my brakes are not at 100%. Link to post Share on other sites More sharing options...
Munch003 2nd Gear December 12, 2011 Share December 12, 2011 Coincidence, my caliper jammed too. But the piston itself is fine. But instead one of the 2 pins that the caliper slides on has seized. So the braking action is done by the pad thats resting on the piston only. Thus one pad wore down wherelse the other pad was still thick. Tried soaking it in WD40 and knocking the caliper free but it refuses to budge. I didn't realise it until the inboard pad wore down to the metal and started grinding. Braking wise nothing different was felt. Just the grinding noise and the uneven wear of one pad. No choice but to replace the caliper for mine. ↡ Advertisement Link to post Share on other sites More sharing options...
Simple home DIY repairs
Brake Pads
Brake Pads
Getting your car refreshed for CNY: paint / polish / ceramic
Brake squeak every morning
2014 Jetta Brake Servo Failure
