Ilmw 1st Gear August 8, 2002 Share August 8, 2002 I'm not sure but the car interior is generally vinyl? Main item in consideration is that black dashboard from front passenger's airbags to the driver's instructments. This is vinyl right? (feels rubbery). Over time, there're some smudges caused by fingerprints, etc but the main thing is dust! I probably need some vinyl cleaner / protectant, with these charactertistics. Any recommendation? * repels dust (anti-static?) * matt finish * new-car smell ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie August 8, 2002 Share August 8, 2002 Best for you is Vinylex, it comes in a light blue bottle. It's matt finish (must buff), has new car scent and slightly anti-static (dust off easily), can be found at ACE Hardware Novena Sq. Link to post Share on other sites More sharing options...
Skoda_Man Neutral Newbie August 10, 2002 Share August 10, 2002 I am a lazy man, I uses a wet cloth spray with some Autoglym Vinyl protector and goes over it. Fast and easy. Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie September 4, 2002 Share September 4, 2002 Just to check with you all whether which kind of Vinyl protectant is better? 1) 3M Vinyl cleaner and protectant 2) Armor All Vinyl cleaner and Protectant 3) Auto Glym Vinyl and rubber care Any comments or recommendations on the above products? Link to post Share on other sites More sharing options...
Ilmw 1st Gear September 4, 2002 Author Share September 4, 2002 TB I got the Vinylex from ACE as you recommended. Since then, I've used it twice, and twice I got the same experience and therefore need to check with you, maybe I'm using it wrongly. The rubbery dash material (see pic) is very dark charcoal/black color (best I can describe). I use 3M microfibre (MF) and Vinylex. Straight away, the dash turn matt black and look moist. After covering the entire dash, the MF cloth is a bit dirty. After it dries, the dash is still the same color - matt black and look moist. On touch, it is very smooth, good feeling! (If didn't dry completely, Vinylex will get onto my hand (from steering wheel) and it gives a plastic-ky feeling .. ) I don't seem to need to buff?! Did I do wrong? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie September 5, 2002 Share September 5, 2002 So U like it matt and with a tad shiny moist looks? The buffing part will get it to a non-reflective satin shine rather than a wet look. So it's up to you, both are correct application methods. Buffing is another alternative to drying if U don't have time to air dry the Vinylex. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear September 5, 2002 Share September 5, 2002 Replying to : Carlover76 Post: Just to check with you all whether which kind of Vinyl protectant is better? 1) 3M Vinyl cleaner and protectant 2) Armor All Vinyl cleaner and Protectant 3) Auto Glym Vinyl and rubber care Any comments or recommendations on the above products? Regards, Benedict **************************** Armor all is a NO-NO for me... Goes off easily if surface have contact with water... Me used the Meiguairs Tyre Shine for: interior: Dashboard, doors. Exterior: Tyres, coolant hoses, and anything/everything that is rubber....... Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 6, 2002 Share September 6, 2002 >>Exterior: Tyres, coolant hoses, and anything/everything that is rubber....... << Exterior: anything that is rubber .... er...... you mean you also use it on, er.... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear September 6, 2002 Share September 6, 2002 hee hee... anything you can think of lor... ↡ Advertisement Link to post Share on other sites More sharing options...
SONAX rim cleaner
SONAX rim cleaner
Any recomendation for Robot cleaner??
Automatic (robotic) vacuum cleaner
DPF Cleaner
DPF Cleaner
Plastic Trim Cleaner and Restorer
STP fuel system cleaner vs HKS DDR
Dust Mite
Dust Mite
Vacuum Cleaner
Vacuum Cleaner
