Spider Neutral Newbie December 25, 2003 Share December 25, 2003 hi all, collect my car soon but failed to 'beg' a pair of fog lamp....SA die die also dun want to give. anyway, will it be cheaper if i go to 3rd party workshop and install ? reason is i dun like the 2 lobang there....my car model is as of my avatar.... thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Alan22 Neutral Newbie December 25, 2003 Share December 25, 2003 it will be cheaper to install at third party workshop definetely.. but better make sure its approve.. those ROV loves to catch ppl for unapproved fog lite.. and make sure the workshop is sure tat wat he is selling u is approve too... Link to post Share on other sites More sharing options...
Hitman Neutral Newbie December 25, 2003 Share December 25, 2003 Agree with Alan on the fog lighting. Also not only check LTA compliance but also whether you install outside can affect your agent warranty or not ... cause I know some who ran their agent waranty foul because they installed fog lights outside. Link to post Share on other sites More sharing options...
Alan22 Neutral Newbie December 25, 2003 Share December 25, 2003 ya tatz a main headache... hitman.. ur machine getting more powerful huh.. got the info thru the threads... Link to post Share on other sites More sharing options...
Hitman Neutral Newbie December 25, 2003 Share December 25, 2003 Brudder brudder .... where got more powerful ?? Same lah ... just installed E68 Airmax only Link to post Share on other sites More sharing options...
Alan22 Neutral Newbie December 25, 2003 Share December 25, 2003 wah installing oxygen tank to ur car ah... hahaha okie.. can use on diesel engine bo... Link to post Share on other sites More sharing options...
Hitman Neutral Newbie December 25, 2003 Share December 25, 2003 Can ... as long as ur engine got vacumn , sure can one. Link to post Share on other sites More sharing options...
Alan22 Neutral Newbie December 25, 2003 Share December 25, 2003 wah might gif it a try if it can save petrol/diesel. ahhahaha i broke liao Link to post Share on other sites More sharing options...
Hitman Neutral Newbie December 25, 2003 Share December 25, 2003 Dun think it will save tons of diesel lah S$188 with installation Link to post Share on other sites More sharing options...
Alan22 Neutral Newbie December 25, 2003 Share December 25, 2003 how abt performance for tat.. will increase pickup... or smoother ride? Link to post Share on other sites More sharing options...
Hitman Neutral Newbie December 25, 2003 Share December 25, 2003 Lower end pickup is better .. but higher end suffer a bit , need to force a bit to get to 120 kph from 100 kph ... but tis ok lah cause in Singapore how to run above 120 kph Link to post Share on other sites More sharing options...
Ravinged 5th Gear December 25, 2003 Share December 25, 2003 Quote ... just installed E68 Airmax only ... Tell me more manz ... this is something new to me again. Sorry for poking into this ... Ed Link to post Share on other sites More sharing options...
Hitman Neutral Newbie December 25, 2003 Share December 25, 2003 (edited) I just got mine on Dec 24th and what u say is quite true. It seems to do wonders to your low end and pick-up have improved by a lot. However, best to tune it yourself after a few runs as it seems that its not standard for all cars. High end suffers a bit but not too dramatic , as seldom go beyond 120 kph anyway. For the 1st few hours whilst I was doing DIY tuning, erratic idling was a problem. After finding the ideal setup, its ok thereafter. Its an air suction thingy that sends more air to your combustion chamber via the vacumn line The system takes in air and injects it into your manifold for better combustion. Depending on the amount of air you would requie injected for optimum performance, there is a dial there ... right turns less air , left turns more air. Too much air no good as the engine starts to idle erratically whilst too little ... no point instaling right. So u tune it and find the best optimum air pressure for your ride Cost : S$188 at McWell Edited December 25, 2003 by Hitman Link to post Share on other sites More sharing options...
Alan22 Neutral Newbie December 25, 2003 Share December 25, 2003 arrr ur range beri far.. ahhaha i can onli go until 60km/h ahhhha but tatz for show.. i think average safe speed is 80 for mi...120 is abit out of point liao.. aaaahhaah Link to post Share on other sites More sharing options...
Ravinged 5th Gear December 25, 2003 Share December 25, 2003 Har? Brother, you replying to correct person anot? But then again you gave me the insight. Now, comapre Broquet and this, different thing altogether? Or they could compliment one another? Or is it just either this or that? Ed Link to post Share on other sites More sharing options...
Hitman Neutral Newbie December 25, 2003 Share December 25, 2003 Correct what .... but I cut and paste lah But thought u would get the correct info. Dun know about Broquet so canot comment ↡ Advertisement Link to post Share on other sites More sharing options...
Combo Fog cum DRL LED lamp kit
Fun with Xiaomi Bedside Lamp
ABS warning lamp
ABS warning lamp
Crashing into lamp post
Head Lamp has mist inside. Help !
House light bulb is too hot
Where to purchase fender lamp?
Car dealer blinded by pond uv lamp
