Sableorient Neutral Newbie December 21, 2003 Share December 21, 2003 OBDII scanner with Dyno, Datalogging & OBDII Sensor Display functions, error code reset etc For cars after 1996 or newer only. Tested locally with BMW M3 2001 Honda Civic May 2003 Hyundai Matrix Hyundai Etos Mercedes Kompressor 2002 Mazda 6 2003 Mitsubishi Airtrek Turbo 2003(Parallel Import) Mitsubishi Lancer EVO VI 2001 Mitsubishi Lancer EVO VIII 2003 Mitsubishi Lancer GDI 2003 Mitsubishi Galant GDI 2001 Subaru Impreza 2003 Toyota Corolla Toyota Camry Toyota Estima 2002(Parallel Import) Volvo S70 2003 Volvo S40T4 2003 VolksWagen Bora 2003 Works on cars with OBDII connectors, mostly 1996+ cars Works with your Palm OS based PDA eg Sony, IBM, Handspring, Palm etc http://www.auterraweb.com/supportedpalms.html allows error code reset, diagnose faults, datalogging, dyno, mileage traking and many other useful features, error code library in built to explain nature of error. Get instant feedback on sensor readings after fine tuning with user programmable ECM/ECU airflow/ignition timing adjustment tools like Apexi SAFC/SAFC2/ITC,Greddy Emanage,Unichip,buddyclub & other piggyback ECM/ECU etc. check it out here http://www.geocities.com/sableorient/auterra.html Auterra Scan Tools - Dyno & Monitor your OBDII Sensors Most Ferocious Magnetic Filters in The World http://www.geocities.com/sableorient/index.html ↡ Advertisement Link to post Share on other sites More sharing options...
Obdiistore Neutral Newbie November 25, 2010 Share November 25, 2010 that sounds good. we are a online store for obd diagnostic tool http://www.obdiistore.com, have a look. Link to post Share on other sites More sharing options...
ElsaKent 1st Gear July 19, 2017 Share July 19, 2017 I like this obdii scanner dealer website :http://www.obdexpress.co.uk,shipping is fast and they have a good service,They will help you answer the question even if you buy the product is not their Link to post Share on other sites More sharing options...
Soya Supersonic July 19, 2017 Share July 19, 2017 Wah sei....this thread one post every 7 years ↡ Advertisement Link to post Share on other sites More sharing options...
Code of conduct for pedestrians
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
