Orangie Neutral Newbie December 17, 2003 Share December 17, 2003 By the time found the coins, soil the pants liao ↡ Advertisement Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 17, 2003 Share December 17, 2003 like that 'chia lat' man, so if he want to 'lau sai' then goto get out of car, open boot lift up the spare wheel cover to look for the coins before he gets to lock the car, the 'sai' already out liao Link to post Share on other sites More sharing options...
Zombie Neutral Newbie December 17, 2003 Author Share December 17, 2003 just rattling sound you all can go this far.... well done Link to post Share on other sites More sharing options...
Orangie Neutral Newbie December 17, 2003 Share December 17, 2003 Still there? I meant rattling sound Link to post Share on other sites More sharing options...
Zombie Neutral Newbie December 17, 2003 Author Share December 17, 2003 haven't take out the stuff.... went home late, woke up late will try and post here again.... Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 17, 2003 Share December 17, 2003 yah! MCF got lots of expert on 'drifting' Link to post Share on other sites More sharing options...
Zombie Neutral Newbie December 18, 2003 Author Share December 18, 2003 still there.... *sian* going for servicing this Sat.... will get KM to troubleshoot.... hopefully they know.... Link to post Share on other sites More sharing options...
Orangie Neutral Newbie December 18, 2003 Share December 18, 2003 Good luck Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 22, 2003 Share December 22, 2003 Zombie, get the mechanics to use a chassis electronic stethscope. This device with 6 sensors can easily detect even very faint noise. Great tool,not sure whether KM has this tool. Link to post Share on other sites More sharing options...
Darkness Neutral Newbie December 27, 2003 Share December 27, 2003 dude is there any mechanic with this "chassis electronic stethscope"? how to check.... as in ref up the car then they listen is it? if so i want to try also lei ....have a lot of "alien" sounds in my car hee hee thanks Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 28, 2003 Share December 28, 2003 You can get this service from : Ubi Automobile Services Pte Ltd Blk 3018A #01-27 Ubi rd 1 Tel : 7483377 Boss : Mr Chong L K Link to post Share on other sites More sharing options...
Darkness Neutral Newbie December 28, 2003 Share December 28, 2003 thanks dude any idea wats the cost? Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie December 30, 2003 Share December 30, 2003 Hi, I got this rattling sound too, but it's located at the front right wheel. It rattles everytime I exceed 2500 rpm. Sounds like a loose screw or dislodged metallic item. Revving on neutral gear does not replicate the sound, only when driving off. My mech removed the wheel and said a loose cotter pin was the problem, but after changing the pin, the rattling sound returned again. Even kicking the right wheel can produce the sound. Guess I need to re-visit the mech again. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 30, 2003 Share December 30, 2003 Get you mech to inspect the wheel stud threads, maybe one of the stub has wore or cross threads. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie December 30, 2003 Share December 30, 2003 hi, is this the nut-like object that screws onto the threaded spindle of the wheel ? Link to post Share on other sites More sharing options...
Armored_Saint Neutral Newbie December 30, 2003 Share December 30, 2003 Hmm, could it be a worn wheel bearing? They make vibrational noises and can even cause rattles. For me, the time I suspected my right worn wheel bearing was when I heard this "wooooonnnng" sound entering the car from 50km onwards. Here's how to check if you're wheel bearings are worn: - Jack up your car (depending on which wheel bearing you think has suffered) - Spin the tyre as fast as you can - Place your hand on the suspension spring. Do you feel a vibration or coarse feeling on the spring? That's a sign of worn wheel bearings; the vibration passes on to the spring which is translated to sounds in the car. If your wheel bearings are good, you should feel nothing at all when your hand is placed on the suspension spring. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie December 30, 2003 Share December 30, 2003 hi, interesting way of checking the wheel bearings. ANy idea how much would it cost to replace them and is it a major replacement ? ie more than 1 day ? Link to post Share on other sites More sharing options...
Armored_Saint Neutral Newbie December 30, 2003 Share December 30, 2003 Hi Ace_T, It's a very simple yet accurate way of checking your wheel bearings. Mine cost me $80.00 for my last change. Kinda a bit expensive IMO. With all the right tools, it can be changed in less than 10 mins. Very simple job of jacking the car, unscrewing wheel parts and a bit of hammering here and there for stubborn areas. ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Right side speakers no sound
Metal grinding sound on civic
