Eko6 2nd Gear December 15, 2003 Share December 15, 2003 Hi all, May I checked with those who have experienced this before? When my car go over a hump, there is a "clog" sound coming from the front. The car is about 3 yr old and only started this a few months back. I checked the suspension by pressing it down and let go, it is not bouncing. ↡ Advertisement Link to post Share on other sites More sharing options...
Buzz Neutral Newbie December 15, 2003 Share December 15, 2003 It is not bouncing? I would have thought that it would be bouncing too much. I also have this problem and after went back to agent they replace the lower arm for me. What is your car? Mine a Mondy. Link to post Share on other sites More sharing options...
Rs60 Neutral Newbie December 15, 2003 Share December 15, 2003 suspension not bouncing? stock suspension? should be bouncing since manufacturer always tend to make softer suspension unless you changed to performance suspension. prob your suspension gone case liao. go over humps and bumps on the road tyres kena your fenda? Link to post Share on other sites More sharing options...
Eko6 2nd Gear December 15, 2003 Author Share December 15, 2003 How much did you paid for the replacement? Mine a Sunny. Link to post Share on other sites More sharing options...
Eko6 2nd Gear December 15, 2003 Author Share December 15, 2003 I mean when I press and release, it will go back to the original height. It does not bounce up and down a few times, which if it does it means suspension due for replacement. Link to post Share on other sites More sharing options...
Soya Supersonic December 15, 2003 Share December 15, 2003 could be a loose engine mount or anti-roll bar. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 15, 2003 Share December 15, 2003 Most likely spring mounts kaput Link to post Share on other sites More sharing options...
Mondeost220 Neutral Newbie December 15, 2003 Share December 15, 2003 i tink mondeo owners used to have this problem...everitime go over the hump there's the clog sound... and found out frm the SE dat itz actually the lower arm of the suspension dat is creating the noise and had the whole of it changed Link to post Share on other sites More sharing options...
Eko6 2nd Gear December 16, 2003 Author Share December 16, 2003 Possible. So, suspension=spring+damper ? It could be either one. Link to post Share on other sites More sharing options...
Eko6 2nd Gear December 16, 2003 Author Share December 16, 2003 Sound like a QC problem for new Mondeos. Does it still affect the latest batch? Mine not a Mondeo. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 16, 2003 Share December 16, 2003 There are many parts in the suspension that can make a knocking sound. The spring mount is a primary culprit as a broken one will send the rubber spring seat to knock against the chassis. There's also the anti-roll bar link, control arm and sway bar bushing to consider. Link to post Share on other sites More sharing options...
Steven Neutral Newbie December 18, 2003 Share December 18, 2003 Hi, Whenever my car goes over those speeding stripes, there's this loud "thug thug" sound coming from the rear. Check with car agent & they claim that it is normal due to the "harder shocks". It is definitely not tyre related as I've just change to brand new tyres. Any ways to improve this situation? BTW, going over hump is a breeze. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 18, 2003 Share December 18, 2003 What car you have? Harder shocks/springs will create more thumping noises but it shouldn't sound loose or like metal to metal contact. Link to post Share on other sites More sharing options...
Steven Neutral Newbie December 19, 2003 Share December 19, 2003 My ride is Ford Focus with Yoko AVS db (195 60 R15). Tyre pressure at 30psi. Rims, shocks & springs are all stock. Link to post Share on other sites More sharing options...
Seansene 1st Gear December 19, 2003 Share December 19, 2003 Hi Steven, our Focus does have rather firmer suspension than most Jap saloons. Also, sound insulation from road and suspension noise isn't that great, so we will tend to hear some thuds going over speed humps. Mine gets the added rubbing noise of my child's car seat Link to post Share on other sites More sharing options...
Steven Neutral Newbie December 19, 2003 Share December 19, 2003 I'm in for a more comfort ride. Other than SP, does changing of shocks help? Which shocks can gives a comfort ride? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 20, 2003 Share December 20, 2003 What's the recommended tire pressure? You may want to lower 1 or 2 psi and try the ride for a couple of days. I do not recommend running under manufacturer spec tire pressures but lowering the pressure (especially if overpumped) may help. Factory shocks are decent enough, no point spending the extra $$ to get a "softer" shock. The only ride comfort shock I can think of is Monroe Sensa-trac but heard not too positive reviews about it. Link to post Share on other sites More sharing options...
Steven Neutral Newbie December 20, 2003 Share December 20, 2003 Recommended tyre pressure is 34psi & I'm now on 30psi. Not sure any mechanic (other than agents) can do a confirmation test on it because I tend to find that agent is more biased & every problem brought up to their attention is "not a problem" to them. Hmm.......... maybe i got high expection ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
Budget 2025 - February 2025.
Going to Batam. Where to park overnight ?
Fatty Kim going crazy again
Sound Proofing the car
Whole car sound proof
