Headlight light beam angle adjustment.
Dptm
i found it... but its very hard to reach. after 30 mins of fiddling with it , i couldnt get it to move at all... cause its obstructed. probably need a very small allen key [sweatdrop]
B very careful when u turn/adjust these screws/nuts.
Most r made of plastic & if it's stiff, u might not realise that u have overtighten it & cause u to strip the threads.
Then u cannot adjust it back.
Spray some lube like WD40 & let it soak for a few minutes b4 u try to adjust the tight screw/nut.
left right is which one ah? [laugh]
your turn to take photo [:p]
Posted Image
if u to look carefully, on the left side where u see the black plastic holding the headlight, there is a hole, the adjustment is just inside that hole and u need a long screw driver to reach that area
Posted Image
its the same for this pix ... just on the right side of ur red circle, plastic holder to hold onto the headlight housing
Edited by Tenminste
come to my carpark ... i help u to adjust ... i think my marking is still @ the MSCP wall [:p]
