Change Speakers?
Egls
When I turn on the bass to the maximum, the speaker sound broken! [thumbsdown] (laohong) Will it help if I change the speakers alone? [gossip] Thanks
get a pair of bigger component speakers.. or maybe if u wan bass...add a basstube or maybe subs to replace wat is given by the speakers
How much will a pair of "basstube" speakers costs? Only wanted to change speakers only. Mine is a Sony system. cheers [:)][:)]
Suggest get a bigger speaker to cope with your "blasts". Change surely must change lah, but this time might as well get a bigger one. Alternatively, get a subwoofer so that your new speakers does not have to thump and thump the bass that you are playing. Thats because the low frequencies willl be transfer to the subs hence leaving the mids and the highs to the speakers (easier on the spkr rubbers)
Also check your amplification power if its underpowered. An underpowered amp trying to do too much will harm your speakers much faster than an overpowered amp trying to "fry" the speakers.
If you like to wack the music loud, suggest get a powerful amp too.
ermm a basstube can range from 70 plus for second hand to 200 plus for first hand.. depending on the size too.. and the type.. active or passive...
for ur info.. the basstubes are add-ons... if u juz wan to leave with normal bass.. den get ur front and back speakers changed to any bigger component speakers.. use the amp to power them up.. should be enuff for normal hearing.. if u wan to tumping..ahbeng bass music.. den muz at least a basstube (add-on) or build a subwoofer box in ur boot(add-on)
FABIAMAN, ALAN22,
Thanks for the advices, what i need is a simple but not "laohong" speakers when turn on the bass. Not going for very loud music, only listen to sentimental songs....hehehe [:p][:p][:p][:p][:p] will source for a cheaper 2nd hand one. just bought my 2nd hand car...no money liao... [sweatdrop][sweatdrop][sweatdrop][sweatdrop][sweatdrop] cheers [:)]
