Mitsubishi Grandis
Gadgeter
Mitsubishi Grandis
26 members have voted
  1. 1.
    • Good Car
      17
    • Not worth buying
      9
Hi Folks, what are your thougth about the new Mit Grandis?
Grandis
Item
Model Code: Grandis 2.4 liter MIVEC
Drive :2WD
Trim Level : Sport
Dimension & Weight
Overall Length 4,755 mm
Overall Width 1,795 mm
Overall Height 1,655 mm
Wheelbase 2,830 mm
Track Front: 1,550 mm
Rear : 1,555 mm
Ground Clearance 155
Interior length 2,735 mm
Interior width 1,550 mm
Interior height 1,210 mm
Vehicle weight 1,620 kg
Seating capacity 7 persons
Performance
Min Turn Radius 5.8 m
Engine
Type 4G69 MIVEC
No. cylinders/valvetrain SOHC16 valve, 4 cycle, in line 4 cylinder
Bore x store 87 x 100 mm
Displacement 2,378 cc
Compression ratio 9.5
Max output(net) 121(165)/6000 kW(PS)/rpm
Max torque 217(22.1)/4000 Nm(kgm)/rpm
Fuel System
Fuel delivery ECI-Multi
Fuel Tank Capacity 65 litres
Transmission
Type INVECS-II 4-speed A/T with Sports Mode
Suspension
Front McPherson strut coil springs
Rear Semi-trailing arm coil springs
Brakes
Front Ventilated discs
Rear Solid discs
Tyres
215/55R 17
my fren tested it and said it quite disappointing as it was even more underpowered than his old 2.4L chariot. but i never test lah, not into MPVs.
heard frm my fren who is a spacewagon fan and previously owned the spacewagon chariot..currently owning this grandis..and highspeed floating is taken away unlike chariot and more power too [thumbsup][thumbsup]
