Octopus 3rd Gear June 29, 2007 Share June 29, 2007 i'm using mineral 5-40W mineral myself now but in the next servicing or the one after that i will be using semi-syn too. Which 5w40 mineral oil you using? I've always thought oil of that viscocity is synthetic... ↡ Advertisement Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie June 29, 2007 Share June 29, 2007 (edited) opphs, it might be 10w40 or 20w40? , Castrol GTX. my bad. am using it with autorx application. hopefully after that, can use semi syn or fully syn. Edited June 29, 2007 by Jonbummer Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 2, 2007 Share July 2, 2007 I see... should be 15w40 for the Castrol GTX... I understand this mineral oil is quite good. Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie July 2, 2007 Share July 2, 2007 yup.... engine is quiet and responsiveness is not too bad too. tho i cannot wait for the engine to have semi syn after the rinsing phrase of the AutoRX driving a R10 too? Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 3, 2007 Share July 3, 2007 Nope, driving a G6.... Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie July 3, 2007 Share July 3, 2007 reliability is never an issue with Toyota Link to post Share on other sites More sharing options...
BlueSi Neutral Newbie July 5, 2007 Share July 5, 2007 Hi! Luckily for me, my mechanic recommended me to replace my clutch oil first and then monitor the situation. It turned out fine since then. Maybe u can try it too ( hopefully not too late liao ) Clutch oil?!? Is your mech joking? There's clutch fluid and transmission fluid. You really don't want to have any kinda lube in your clutch!! If you're going to change your clutch, might as well do the whole thing. Pressure plate, disk, throw out bearing and pilot bearing since all these have to come out either ways when dropping the tranny and doing a clutch job. The job sounds ridiculously cheap in Spore! Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 4, 2008 Share July 4, 2008 Those that have changed clutch, is it necessary to change the clutch master and slave pump also when changing the clutch disc, plate and bearings? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 4, 2008 Share July 4, 2008 if possible change cable at same time also Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 4, 2008 Share July 4, 2008 (edited) Sunny doesn't run on cable. Is it necessary to replace the master and slave pump? Those who replaced clutch before, do you do that? Edited July 4, 2008 by Fcw75 Link to post Share on other sites More sharing options...
Phoenix Neutral Newbie July 4, 2008 Share July 4, 2008 I didn't. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 4, 2008 Share July 4, 2008 Orite, thanks. Guess it's more of a precaution then. Link to post Share on other sites More sharing options...
Snowblind Neutral Newbie March 4, 2012 Share March 4, 2012 Hi all, there seems to an issue with my fathers car, Honda civic 1.6 manual, milage 70k. Yesterday when i used engine braking during 1st and 2nd gear, I felt vibration on the steering wheel. The speed was low, about 10-15km/h in my carpark. I believe the front wheel bearing also needs to be changed soon but that's another issue. Any advice on what might be the problem, clutch? Link to post Share on other sites More sharing options...
Trafficwatch Clutched March 4, 2012 Share March 4, 2012 Try to adjust the clutch free play. Clutch replacement costs around S$ 400 to S$ 500/-. Link to post Share on other sites More sharing options...
Snowblind Neutral Newbie March 4, 2012 Share March 4, 2012 Hi bro, what do you mean by free play? Additional info, The car got no issue during idle, braking, neutral or higher gear/speed. And car no trashed either, uncle driver and me. I drag gear once in awhile but never floor the pedal. Try to Change gear at 2.5k rpm and never play with half clutch. Thanks. Link to post Share on other sites More sharing options...
Snowblind Neutral Newbie March 6, 2012 Share March 6, 2012 Any advice? Link to post Share on other sites More sharing options...
Steve111 Neutral Newbie March 6, 2012 Share March 6, 2012 it's indeed cheaper to change cluster yourself, but it's not only a job of changing. After changing, you also have to adjust the value showed in the new cluster. Good luck. Link to post Share on other sites More sharing options...
Snowblind Neutral Newbie March 9, 2012 Share March 9, 2012 Guys....it's not the clutch problem. It is the engine mount need to be changed. Enquired at fong tat I think, parts cost 500+. Think total cost will be almost 700. Sian. Thanks for your advice. ↡ Advertisement Link to post Share on other sites More sharing options...
Clutch
Clutch
Looking for Job in automotive sector, need advise
