Genie47 1st Gear October 17, 2007 Share October 17, 2007 Hearsay. Only chop shops in Malaysia sell recycled Mobil 1. I have no idea why they are cheap. ↡ Advertisement Link to post Share on other sites More sharing options...
Kelpie 2nd Gear October 17, 2007 Share October 17, 2007 In Indonesia you can buy "mixed-grade and mixed brand" engine oil. They mixed all the remaining oil from servicing and sell them cheap. No waste, save green. Regards, Link to post Share on other sites More sharing options...
Alfpoon Clutched October 17, 2007 Share October 17, 2007 hmm..interesting..maybe they use recycled oil to reprocess..BYO oil when servicing in M'sia. Link to post Share on other sites More sharing options...
Kyojin 1st Gear October 17, 2007 Share October 17, 2007 API SG is obsolete now. But anything after SG (SL/SJ/SM) will work. Ok, questions now is... should I do a compression test before going with a thinner oil? Just to make sure that I don't have huge gaps between the rings? as of now, it's sipping a little oil. Hi ! Information taken from toyota starlet, 1992 model Engine oil selection Use engine oil of the following API grade SG or better, if cannot get SG or better, you may use SF grade Recommended viscosity is 15w40 10w30 5w30 20w50 FYI Link to post Share on other sites More sharing options...
Simnon Clutched October 17, 2007 Share October 17, 2007 When I owned the 1992 model starlet, always use 15w40, from Castrol or Idemenitsu However, Idemenitsu is the racing type which towards the 4000 km mark would be downt to 3/4 mark of the oil dipstick and starting is very sluggish and need to hold the ignition key longer by a couple of minutes. However, both oil give very good mileage, average of 13 km/litre on shell 92. Had wanted to switch to 20w50 Castrol GTX, but more problems surface such as suspension, electrical, etc and had to give it up after 6 months, so did not see the effect of thicker oil. Had used 20w50 on my previous daihatsu charade cx and this oil gives good mileage of 13.5 km/litre for a 3 cylinder engine Have not tried 10w30 or 5w30 synthetic which I think is for new type of engine. Currently also using castrol 15w50 GTX on my suzuki swift GTi and mileage is not too good, arould 11 lk/litre, maybe it is due to the higher engine capacity Link to post Share on other sites More sharing options...
Simnon Clutched October 17, 2007 Share October 17, 2007 If you have the tools, you should do it. However, I normally check the dipstick weekly and how fast the engine gets cranked up after the engine oil change. My experience based on 15w40 and 20w50 mineral oil is that the drop in oil level is more for 15w40 and difficulty cranking more significant also for 15w40. 20w50 is more stable from my experience, but have not experience using it on the starlet. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 17, 2007 Share October 17, 2007 I used a 5W30 for an EP70. No leaks. YMMV. 5W30 is not just for new cars. If they old car has good rings, it can take it and will thank you for it. Link to post Share on other sites More sharing options...
Solar Turbocharged November 18, 2007 Share November 18, 2007 read in some of your previous posts about diesel oils contain good cleaning effects. i suppose the end result it'll translate to better fuel economy and restore power? Link to post Share on other sites More sharing options...
Genie47 1st Gear November 18, 2007 Share November 18, 2007 Bad for FC. Most HDEOs are 15W40. Good for COE beaters when you don't know who screwed them up bad in the past. If yours is a new car, just use a nice 30wt. Link to post Share on other sites More sharing options...
Solar Turbocharged November 18, 2007 Share November 18, 2007 okie thanks ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Mini Cooper
Mini Cooper queries
Mini Cooper queries
Renting a Mini bus to go Malaysia
Selling a 2017 Nissan Pulsar to buy a used 2016 Mini
