"Front" mud guard ?
Andrewkb
pickup is slow 1.2 ton lar sweatdrop.gifsweatdrop.gifsweatdrop.gif but torque is better nod.gifnod.gifnod.gif stock suspension setup not bad so will most likely stay like thumbsup.gifthumbsup.gifthumbsup.gif unless PG session prove other wise sly.gifPosted ImagePosted ImagePosted ImagePosted ImagePosted Image
It's not all from the length. Its more space sideways as well. The Bimmer's problem is that the two suspension towers intrude into the boot space so space is very limited, especially sideways
".....two suspension towers intrude into the boot space so space is very limited,......"
  Quote
Wouldn't the vertical piece flap vigorously during high speed if you DIY ?
Sorry for the late reply...
Yes I think it will flap but how much it does depends on how far down it projects. I have mine just 3 inches above the ground. I think it will help if you convex the flap (looking from the front) to give it more rigidity and round the ends so as to reduce turbulence induced flapping.
I do not recommend using double sided tape casue it does not stock well to plastic. So it might drop off. Using metal may also be a problem cause if you go over humps or park at them concrete kerbs... you migh potentially bend the metal and it might rub against the tyre. Know so cause I tried so... [:(]
Hope this helps. [:)]
  Quote
figure that's a trademark of contis... they are heavy, but then you feel that much better driving them because you feel you're more in control [thumbsup]
thinking of changing, huh? [sly]
