Panda Neutral Newbie September 17, 2003 Share September 17, 2003 Hi everyone, Dunno if this question has been asked before, but is there a sure way to tell whether it is time for a battery change before the battery completely fails on you? Measure with voltmeter across the terminals? ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie September 17, 2003 Share September 17, 2003 Voltmeter across terminal on a cold battery (overnight rested), should read >11.5V. Once it touches low 11s or 10+ time to shop for a new batt to be safe. Or when the car is slow to crank, then immediately get a new one! Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 17, 2003 Share September 17, 2003 Since we're at this .. wonder if "dead" battery can be re-charged/re-vitalised? I don't think those dead battery are thrown away right ? Link to post Share on other sites More sharing options...
Panda Neutral Newbie September 17, 2003 Author Share September 17, 2003 Thanks TB! So I'll just get me standard multimeter to do the test. seems pretty straightfoward. Link to post Share on other sites More sharing options...
Panda Neutral Newbie September 17, 2003 Author Share September 17, 2003 Hi Andrew, I think Vtim posted something in the HVS thread regarding deep cycle battery. http://www.mycarforum.com/forum/gforum.cgi...t=324425#324425 Following the link to howstuffworks website regarding deep cycle batteries at http://auto.howstuffworks.com/question219.htm I have learnt that standard car batteries once totally discharged, its a very bad thing as it is permanently damaged. Deep cycle batteries can be recharged though... As for being thrown away... not sure... re-con battery? Hmm... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie September 17, 2003 Share September 17, 2003 Depends on "dead" are the batteries. I had my T-bird battery die on me once, went to an autoparts shop and they charged in FOC within an hour Sometimes the battery just got drained and needs a recharge, a battery is truely dead if it doesn't hold charge Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 18, 2003 Share September 18, 2003 The Lead Acid Accumulator (or Battery) have Sulphuric Acid inside so cannot any how throw away It depends on the how 'dead' is 'dead', it could be the battery are almost completely drain, or the acidity level is low, or not enought distill (battery) water.. These type still can be revive Once the plates inside it have start to bend (buckle) & sometimes touches the adjacent plates, most likely the battery is dead (SC) & cannot be recharged or jump start Encounter this case when I try to jump start my friends car & found out the battery have Short-Circuited as the plates have buckle & touches the adjacent plates Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie September 18, 2003 Share September 18, 2003 I saw there's a battery alarm to inform you whether the battery going to 'die'. Or buy a voltmeter just plug on lighter switch will know. Link to post Share on other sites More sharing options...
Panda Neutral Newbie September 19, 2003 Author Share September 19, 2003 I still have my trusty digital multimeter with me! Tested cold 12.62V. Yay! No need to change battery yet! 2 years 3 month old standard battery, still okay! Save money... Link to post Share on other sites More sharing options...
Panda Neutral Newbie September 19, 2003 Author Share September 19, 2003 Tested 12.62 cold. Too bad! No excuses to change to a nice maintenance free battery yet! Eyeing for a Delphi. Thanks! Link to post Share on other sites More sharing options...
Saaber Neutral Newbie September 19, 2003 Share September 19, 2003 or a Varta... Link to post Share on other sites More sharing options...
Rizzzl Neutral Newbie September 20, 2003 Share September 20, 2003 I check the battery voltage using RSM. Good condition battery tested cold 12.5v and 13.8 while driving. However, I experienced battery about to be goner when I heard that it sounded weak during cranking one morning. The voltmeter tested cold showed 12.3v and after that 13.8v while driving right? SO it should be OK right? WRONG - after driving for about an hour or so at 13.8v, it failed to restart again. Needed to jump start. So are voltmeters good indicators? To me it helps showing that battery is charging when driving i.e. alternator working but when the battery is about 2 years old, start relying on your ears. BTW, when the cranking sounds weak, it could be the last few hours of your battery - meaning the next time you start the car - it might not crank. Link to post Share on other sites More sharing options...
Panda Neutral Newbie September 20, 2003 Author Share September 20, 2003 Yo Rizzl, haven't seen you around for such a long while! According to what you say, I better be more alert! Afterall the battery is more than 2 years old I believe. Cranking still looks pretty good, up till now that is. I think... I hope... Link to post Share on other sites More sharing options...
Panda Neutral Newbie September 20, 2003 Author Share September 20, 2003 Wahahaha~! Yeah! Varta! Now the excuse to change battery is reborn... Link to post Share on other sites More sharing options...
Guyver 1st Gear September 25, 2003 Share September 25, 2003 Quote Hi everyone, Dunno if this question has been asked before, but is there a sure way to tell whether it is time for a battery change before the battery completely fails on you? Measure with voltmeter across the terminals? Think as long as your battery is ok... car can start... and u do regular maintenance... your battery doesn't needs to be externally charged... unless.. your battery is old liao.... ↡ Advertisement Link to post Share on other sites More sharing options...
Battery for Honda Vezel
My EV journey to the i4
Who's your favorite lau-chiobu actress ?
Anybody know what happened eventually?
