Hcgiv942 Neutral Newbie September 15, 2003 Share September 15, 2003 Hi, anyone use the STP complete fuel treatment(silver bottle) before? any comment? any 'precaution' to look out for? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Flaser Neutral Newbie September 15, 2003 Share September 15, 2003 On a similar note, what about the Redline Oil Complete Fuel System Cleaner? http://www.redlineoil.com/redlineoil/si1ti.htm Link to post Share on other sites More sharing options...
Michel Neutral Newbie September 15, 2003 Share September 15, 2003 Flaser, Are you getting hooked to the Redline products??!! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie September 15, 2003 Share September 15, 2003 You probably won't feel a diff but it's cheap insurance against future injector clogs Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 15, 2003 Share September 15, 2003 Hi Gav, How's life there now ?? :-) Anyway, a few workshops are offering this injector cleaning service. Instead of pouring engine cleaner into petrol, they connect the injector rail to the cleaning device and clean the injectors with PURE engine cleaner (as was told to me by a reputable workshop which I wouldn't mention here). Does the above works ? Wouldn't pure engine cleaner choke the engine ? Link to post Share on other sites More sharing options...
Hcgiv942 Neutral Newbie September 15, 2003 Author Share September 15, 2003 can i know which w/shop offer the fuel injector cleaning service? if not convinence to post here, can pm me. Link to post Share on other sites More sharing options...
Hcgiv942 Neutral Newbie September 15, 2003 Author Share September 15, 2003 so is the cleaner really effective? Link to post Share on other sites More sharing options...
Flaser Neutral Newbie September 16, 2003 Share September 16, 2003 (edited) Flaser, Are you getting hooked to the Redline products??!! To a certain extent!! If this injector cleaner proves effective, I would be considering their engine oil.... Edited September 16, 2003 by Flaser Link to post Share on other sites More sharing options...
King 1st Gear September 16, 2003 Share September 16, 2003 a few of mcf forumer use it every 10,000-20,000 km to clean the fuel line. or use it when brought a 2nd-hand car. i brought it at carrefour offer for 19.90,otherwise too EX. Link to post Share on other sites More sharing options...
Lester Neutral Newbie September 16, 2003 Share September 16, 2003 Hi,anyone use the STP complete fuel treatment(silver bottle) before? any comment? any 'precaution' to look out for? Thanks. Do a search for the subject. It has been discussed extensively before a couple of times. Link to post Share on other sites More sharing options...
Cloverleaf Neutral Newbie September 16, 2003 Share September 16, 2003 i am surprised to know there is such service in singapore, those injector cleaning machines are extremely expensive. i am interested to find out about this injector cleaning service, please PM me. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 16, 2003 Share September 16, 2003 So, for the price of $200+, do you consider it as reasonable ? Link to post Share on other sites More sharing options...
Cloverleaf Neutral Newbie September 16, 2003 Share September 16, 2003 well, can't say much until i go check out exactly what they do ..... Link to post Share on other sites More sharing options...
Mavvy Clutched September 16, 2003 Share September 16, 2003 Flaser, Are you getting hooked to the Redline products??!! To a certain extent!! If this injector cleaner proves effective, I would be considering their engine oil.... Why not? Give a try... Link to post Share on other sites More sharing options...
Flaser Neutral Newbie September 16, 2003 Share September 16, 2003 Plucked this off a previous discussion thread, reproduced below. http://autos.yahoo.com/repair/results/ques076.html According to the article, there may be some benefit in using premium grade petrol afterall? I'm sending my car in for servicing soon, will ask them to check if the injectors are clean. If not, what can I do. Question: My mechanic says my injectors are dirty and need to be cleaned. What does that mean? Answer: "Dirty" is actually a misnomer. Rarely are injectors clogged with dirt. Rather, they are usually clogged or restricted by a buildup of fuel varnish deposits. This reduces the amount of fuel that the injector sprays, which in turn may cause the engine to run lean and misfire, hesitate or stall. A fuel injector is nothing more than spray nozzle. With mechanical injectors, a spring loaded valve allows fuel to squirt out of the nozzle when line pressure overcomes spring tension that holds the valve shut. With electronic injectors, a spring-loaded solenoid pulls open a pintle valve or ball type valve when the injector is energized by the computer. This allows the pressurized fuel in the fuel rail to flow through the injector and squirt out the nozzle. Injectors come in a variety of styles. Early Bosch style injectors have a pintle valve and are the ones most prone to clogging. In 1989, General Motors introduced its new "Multec" style injectors which have a ball valve design and are claimed to be more resistant to clogging. Other injectors have a disc-valve design that is also said to resist clogging. The truth is ANY injector can clog. Nobody's injectors are immune to this kind of problem, but some are obviously better than others. Problems can occur even with a slight buildup of deposits. Because the injector orifice is so small, it doesn't take much crud to restrict the flow of fuel or to disrupt the spray pattern. For good combustion, the injectors must produce a fine cone-shaped mist of fuel vapor. Wear or deposits in the nozzle can create "streamers" of liquid fuel that vaporize and burn poorly. This, in turn, can cause hesitation, emissions and performance problems. INJECTOR CLEANING The cure for a set of clogged injectors is cleaning -- or replacement if they're too badly clogged to respond to cleaning. Injectors are expensive to replace. New domestic injectors sell for $60 to $100 each, with new import injectors fetching $125 to $175 each. Injectors should only be replaced as a last resort. If your injectors are clogged, they can be cleaned with pressurized solvent, or removed for off-car cleaning. There are also fuel tank additives that claim to clean clogged injectors, but the cleaning such products do is usually minimal. So save your money and put it towards a professional cleaning. There are do-it-yourself on-car injector pressure cleaning kits that are similar to the equipment professionals use. But some of these kits can be tricky or even dangerous to use. Our advice is to let a professional do it. On-car injector cleaning involves feeding solvent under pressure into the injector fuel rail or supply line. The concentrated solvent passes through the injectors and loosens and washes away the accumulated varnish deposits. The results are usually good, and make a noticeable difference in idle smoothness, emissions and fuel economy. If your injectors are really clogged and fail to respond well to on-car cleaning, off-car cleaning using special fuel injection cleaning equipment would be the next logical option. Some of this equipment is designed to "reverse" flush the injectors so any debris that's trapped inside the injector or above the inlet screen will also be removed. Off-car cleaning also allows a mechanic to observe the spray pattern of the injectors to make sure there aren't any streamers or problems. Off-car cleaning is more expensive because of the labor involved to remove the injectors, but the results are usually better. KEEPING INJECTORS CLEAN The best way to minimize or eliminate the need for injector cleaning is to use a quality brand of gasoline that contains sufficient detergent to prevent varnish buildup. Most brand name gasolines today have enough detergent to do this. As a rule, premium grades usually contain a somewhat higher concentration of cleaners. You can also use fuel tank additives to keep your injectors clean. Such products really aren't necessary if you're using quality gasoline. But if you're buying the cheapest gas you can find, using an additive might be good insurance. Link to post Share on other sites More sharing options...
Mavvy Clutched September 16, 2003 Share September 16, 2003 i got the premium grade products you want.. Link to post Share on other sites More sharing options...
King 1st Gear September 16, 2003 Share September 16, 2003 i got the premium grade products you want.. which one? Link to post Share on other sites More sharing options...
Mavvy Clutched September 16, 2003 Share September 16, 2003 Which one you want ? ↡ Advertisement Link to post Share on other sites More sharing options...
Fuel Plus Meet Up
Fuel Plus Meet Up
