Top Speed (Power) @ 2000 RPM - FLAT SURFACE
Tarmac
58 members have voted
  1. 1.
    • Above 140 km/h
      15
    • 120 to 140 km/h
      1
    • 100 to 110 km/h
      7
    • 90 to 100 km/h
      17
    • Below 80 km/h
      18
This is interesting cause I'm not a technical person.. so we can the reverse-engineer to get the drive ratio for the car concerned? [:)]
Hi Professional Model Driver with 24 Pts CREDIT..
I posted this thinking it would be a measure of your car available power at low rpms - can mean to indicate a more powerful car from a less performing one [:p]
& it was nice meeting you.. hearing you talk about ur Ford Galaxy and all. Cheers [thumbsup]
Hiya... good meeting you too. Dat's what we do at meetups anyway... talk and share. [nod][nod]
Actually, believe car power at low rpms would be more the butt dyno... as well as how easily U pull forward to overtake when U are cruising at 90km/h. I recall last time my Galaxy would do almost 3000rpm at 90+ km/h - but if U wanna overtake, can step but still no go.. until the gear shifts down.
aiya.... performance depends on lots of stuff mah... and also depends on your gearing... U sure you didn't leave overdrive off (if you are driving an auto that is). [rolleyes]
My car has no overdrive and 100kph is at 2900rpm! [sweatdrop] At 2000rpm, really boh lak. Luckily she can go to 7000rpm! [sly] She actually only wakes up at 3000rpm! [sweatdrop]
But you must remember how much load the engine has to carry too for the lousy consumption.
Actually the cruising rpm depends a lot on the engine design and not an indication of power. An engine with a max torque at lower rpm can have a low rpm final ratio (always mix up the high or low final ratio terminology). This has bearing to overall fuel consumption. Obviously if the max torque is reached at higher rpm, you can't put the final ratio's rpm way below this as the car will suffer from lack of pulling power when you need to accelerate.
Yalor.. [nod] too bad i not moderator cannot change the settings.. since u posted we now all know already.. [laugh]
