Saaber Neutral Newbie February 18, 2004 Share February 18, 2004 ok.. ↡ Advertisement Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie February 18, 2004 Share February 18, 2004 actually.... if you do it properly, the K&N will last you at least 100,000km... no need to clean or re-oil often... really.. but if u worried or KS, u can purchase at autobacs... slightly more expensive but they will clean and re-oil for u FOC each time.... Thanks for the info. Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie February 18, 2004 Share February 18, 2004 but will save u some $$ in the long run The hassle is what I am thinking about... Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie February 18, 2004 Share February 18, 2004 u can get ur mechanics to do it Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie February 18, 2004 Share February 18, 2004 Yeah... that is something I will do if I ever get the Green filter. Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie February 18, 2004 Share February 18, 2004 yup looks good Link to post Share on other sites More sharing options...
Waipor Neutral Newbie February 18, 2004 Share February 18, 2004 yeah, its the rim+tyre. they will affect your final drive ratio. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie February 18, 2004 Share February 18, 2004 what's your original tyre/rim size?? Its R15/60/205. i tink i try to come for the meetup this fri, need to show you something for comments. haha... actually quite a number of things Link to post Share on other sites More sharing options...
Xxer Clutched February 18, 2004 Share February 18, 2004 nope very tempted to convert dun have lobang too Hi all I've found out that the local distributor for Green filters is: Red Dot Motorsports Tel: 6726 3280 No address given, tho. According to them, look out for their advertisement in HotStuff mag next mth. FYI Link to post Share on other sites More sharing options...
Phochem Neutral Newbie February 18, 2004 Share February 18, 2004 Will change back to the correct size aft my current set of tyres wear out. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 18, 2004 Share February 18, 2004 ok...c u this friday...and btw what's the new size? Link to post Share on other sites More sharing options...
Phochem Neutral Newbie February 18, 2004 Share February 18, 2004 The new size is 215/55/R16. Chose this size 'cos during then haven lower car but very gian the lowered look, to reduce the gap betw tyre and wheel arch . haha... obviously its a wrong move. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 18, 2004 Share February 18, 2004 with your new size, your speedo reading is abt 2.5% slower correct sizing should be abt 225/50 R16 or 215/50 R16 or 205/55/R16 where errors are less than 1%... Link to post Share on other sites More sharing options...
Yansen Neutral Newbie February 18, 2004 Share February 18, 2004 hmm after putting in the K&N, i find that FC increase by abit leh. engine abit smoother also, power increase at mid range. dun understand the FC part though, as ive not changed my driving style since the K&N.. Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie February 18, 2004 Share February 18, 2004 thanks for info Link to post Share on other sites More sharing options...
Quikfire Neutral Newbie February 19, 2004 Share February 19, 2004 may be sumtin else.... or u need to monitor longer period... Link to post Share on other sites More sharing options...
Akbk Neutral Newbie February 19, 2004 Share February 19, 2004 Mr. Loo has no K&N for RX8 Any other shop to recommend? Maybe I will check out the Green Filters instead Thanks in advance Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie February 19, 2004 Share February 19, 2004 Then try Garage R lor since RX8 ↡ Advertisement Link to post Share on other sites More sharing options...
Container drop on forklift operator
Crash test results
Crash test results
Air Purifier Discussion - tips and info
A level results for University Courses
O level results coming out soon!
DIY engine oil change
Recommendation for water filter
