Kklee 6th Gear July 7, 2024 Share July 7, 2024 IMHO. Any idea where can I go to find out the front and back, or four corners? How much is the cost ? ↡ Advertisement Link to post Share on other sites More sharing options...
Jamesc Hypersonic July 7, 2024 Share July 7, 2024 It cost S$68.67 1 4 Link to post Share on other sites More sharing options...
macrosszero Turbocharged July 7, 2024 Share July 7, 2024 Autokinetics and Cornerweight are two outfits I know offering the service but to me its a bit of a fool's errand doing it to a daily driver unless you suspect something is seriously off with your car's handling which it shouldn't be if it is fairly stock from the factory (having safe and forgiving settings) Even if you get it perfect, all you need is to put stuff in the trunk or take a passenger and your weight distribution is off again... 5 Link to post Share on other sites More sharing options...
Kklee 6th Gear July 7, 2024 Author Share July 7, 2024 On 7/7/2024 at 6:53 AM, Jamesc said: It cost S$68.67 Expand IMHO. My car too early for inspection. I wrote to Vicom, I think either they don't know what I am asking or they think I am crazy. 🤣 2 Link to post Share on other sites More sharing options...
Kklee 6th Gear July 7, 2024 Author Share July 7, 2024 On 7/7/2024 at 8:16 AM, macrosszero said: Autokinetics and Cornerweight are two outfits I know offering the service but to me its a bit of a fool's errand doing it to a daily driver unless you suspect something is seriously off with your car's handling which it shouldn't be if it is fairly stock from the factory (having safe and forgiving settings) Even if you get it perfect, all you need is to put stuff in the trunk or take a passenger and your weight distribution is off again... Expand IMHO. Thanks for the info. Will check them out. Hope it is not to ex. I am doing this for my own learning relating to tyre pressure. Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 7, 2024 Share July 7, 2024 On 7/7/2024 at 8:43 AM, Kklee said: IMHO. Thanks for the info. Will check them out. Hope it is not to ex. I am doing this for my own learning relating to tyre pressure. Expand Tyre's Pressure need to be so Precise.?Then most important,you need an Air Compressor at Home,with a Good Tyre Inflator,also the Weight of yourself. 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 7, 2024 Share July 7, 2024 If you want to be so Precise,the Pressure need to measure when Car is totally cold. Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 7, 2024 Share July 7, 2024 On 7/7/2024 at 1:16 PM, ER-3682 said: Tyre's Pressure need to be so Precise.?Then most important,you need an Air Compressor at Home,with a Good Tyre Inflator,also the Weight of yourself. Expand Just follow Gnahp in getting Milwaukee Tool Tyre inflator. Confirm will not go wrong 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear July 7, 2024 Author Share July 7, 2024 On 7/7/2024 at 1:16 PM, ER-3682 said: Tyre's Pressure need to be so Precise.?Then most important,you need an Air Compressor at Home,with a Good Tyre Inflator,also the Weight of yourself. Expand On 7/7/2024 at 1:34 PM, ER-3682 said: If you want to be so Precise,the Pressure need to measure when Car is totally cold. Expand On 7/7/2024 at 1:45 PM, inlinesix said: Just follow Gnahp in getting Milwaukee Tool Tyre inflator. Confirm will not go wrong Expand IMHO. I got IR temp gun, Milwaukee M12 Inflator and digital tyre gauge. 🤣 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 8, 2024 Share July 8, 2024 On 7/7/2024 at 1:45 PM, inlinesix said: Just follow Gnahp in getting Milwaukee Tool Tyre inflator. Confirm will not go wrong Expand I have these...2. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 8, 2024 Share July 8, 2024 On 7/8/2024 at 12:45 AM, ER-3682 said: I have these...2. Expand Ppl Milwaukee can pump full in seconds. Somemore battery operated Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 8, 2024 Share July 8, 2024 On 7/8/2024 at 12:48 AM, inlinesix said: Ppl Milwaukee can pump full in seconds. Somemore battery operated Expand Milwaukee Made in China,use 2 Years gone case,mine made in Europe,used over 25 Years still working.👍🤣 Link to post Share on other sites More sharing options...
Gnahp Turbocharged July 8, 2024 Share July 8, 2024 want to ignore this thread also cannot.... 4 Link to post Share on other sites More sharing options...
Kklee 6th Gear July 8, 2024 Author Share July 8, 2024 On 7/8/2024 at 12:59 AM, ER-3682 said: Milwaukee Made in China,use 2 Years gone case,mine made in Europe,used over 25 Years still working.👍🤣 Expand IMHO. Battery technology has come a long way to be close if not exceed mains. Tools that run previously using mains or compressors, are gradually being replaced by battery powered. Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 8, 2024 Share July 8, 2024 On 7/8/2024 at 5:38 AM, Kklee said: IMHO. Battery technology has come a long way to be close if not exceed mains. Tools that run previously using mains or compressors, are gradually being replaced by battery powered. Expand Then you should buy a full EV...NOT all Tools are replaceable with Battery Operated. Link to post Share on other sites More sharing options...
Gnahp Turbocharged July 8, 2024 Share July 8, 2024 I bought 4 digital platform weighing scales similar to these then I realised they need to sit on a perfectly flat (relative to the earth) and levelled (relative to each other) platforms to get accurate readings meaning I also need these adjustable platforms haven't do anything yet, there are still in the box 2 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic July 8, 2024 Share July 8, 2024 (edited) On 7/8/2024 at 12:45 AM, ER-3682 said: I have these...2. Expand IMHO got release the water periodically? hahahaha Edited July 8, 2024 by Mkl22 Link to post Share on other sites More sharing options...
Mkl22 Supersonic July 8, 2024 Share July 8, 2024 On 7/8/2024 at 5:50 AM, Gnahp said: I bought 4 digital platform weighing scales similar to these then I realised they need to sit on a perfectly flat (relative to the earth) and levelled (relative to each other) platforms to get accurate readings meaning I also need these adjustable platforms haven't do anything yet, there are still in the box Expand IMHO, do you have adjustable coilovers? IMHO, if not then whats the point? IMHO no need to go about such a convoluted way to get the weight of your wife. .....🤣 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
COE Bidding – Mar 2025
2024 Suzuki Swift
2024 Suzuki Swift
Xiaomi EV is Coming
Xiaomi EV is Coming
Mileage Tampering
Mileage Tampering
COE Bidding – Feb 2025
Servicing car at Shell station
