Achtung 6th Gear June 3, 2024 Share June 3, 2024 Driving a car with frameless windows. Cannot use conventional magnetic shades like my other cars. Any solutions? Are you using any for frameless set up? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Heartbreakid 6th Gear June 3, 2024 Share June 3, 2024 Use stick on glass type. 1 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged June 3, 2024 Share June 3, 2024 I also use stick-ons, but ugly. I also looking for solution. 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 3, 2024 Share June 3, 2024 On 6/3/2024 at 2:56 AM, Achtung said: Driving a car with frameless windows. Cannot use conventional magnetic shades like my other cars. Any solutions? Are you using any for frameless set up? Expand Hmmm. I wanna say change car one... 😄 this kind leh? a make shift shade. Still can block some light. 1 3 Link to post Share on other sites More sharing options...
Volvobrick Supersonic June 3, 2024 Share June 3, 2024 On 6/3/2024 at 3:59 AM, kobayashiGT said: Hmmm. I wanna say change car one... 😄 this kind leh? a make shift shade. Still can block some light. Expand Never like frame less car doors. Less solid. Seal is worse. More restrictions. Only look better when the doors are opened to get in and out. Still cam add double sided tape stick-on retractable shakes if die die want to have them. Link to post Share on other sites More sharing options...
Achtung 6th Gear June 3, 2024 Author Share June 3, 2024 On 6/3/2024 at 5:07 AM, Volvobrick said: Never like frame less car doors. Less solid. Seal is worse. More restrictions. Only look better when the doors are opened to get in and out. Still cam add double sided tape stick-on retractable shakes if die die want to have them. Expand using this. after a while, cant retract. du lan 2 Link to post Share on other sites More sharing options...
Volvobrick Supersonic June 3, 2024 Share June 3, 2024 On 6/3/2024 at 5:57 AM, Achtung said: using this. after a while, cant retract. du lan Expand Time to change _____. Link to post Share on other sites More sharing options...
Achtung 6th Gear June 3, 2024 Author Share June 3, 2024 On 6/3/2024 at 5:07 AM, Volvobrick said: Never like frame less car doors. Less solid. Seal is worse. More restrictions. Only look better when the doors are opened to get in and out. Still cam add double sided tape stick-on retractable shakes if die die want to have them. Expand Link to post Share on other sites More sharing options...
Achtung 6th Gear June 3, 2024 Author Share June 3, 2024 On 6/3/2024 at 3:59 AM, kobayashiGT said: Hmmm. I wanna say change car one... 😄 this kind leh? a make shift shade. Still can block some light. Expand Look at the fitment. Kokanathan. Link to post Share on other sites More sharing options...
Inlinefour Twincharged June 3, 2024 Share June 3, 2024 TS can consider photochromic film as well nice and cool Link to post Share on other sites More sharing options...
Soya Supersonic June 4, 2024 Share June 4, 2024 Hate these kind of shades esp riding in a PHV. Get car sick But dunno to blame the shades or bad driving.... Link to post Share on other sites More sharing options...
Achtung 6th Gear June 4, 2024 Author Share June 4, 2024 On 6/4/2024 at 4:07 AM, Soya said: Hate these kind of shades esp riding in a PHV. Get car sick But dunno to blame the shades or bad driving.... Expand Unless you are in a CHR Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged June 6, 2024 Share June 6, 2024 On 6/3/2024 at 2:56 AM, Achtung said: Driving a car with frameless windows. Cannot use conventional magnetic shades like my other cars. Any solutions? Are you using any for frameless set up? Expand I used the magnetic shades before. Found them extremely troublesome to remove when crossing borders so I sold them off. Now using these on my front windows. If you paste them nicely, windows can be lowered and raised, no problem. The only thing is it won't cover as nicely as magnetic shades designed for specific car models. Link to post Share on other sites More sharing options...
Achtung 6th Gear June 6, 2024 Author Share June 6, 2024 On 6/6/2024 at 6:17 AM, Beehive3783 said: I used the magnetic shades before. Found them extremely troublesome to remove when crossing borders so I sold them off. Now using these on my front windows. If you paste them nicely, windows can be lowered and raised, no problem. The only thing is it won't cover as nicely as magnetic shades designed for specific car models. Expand i got some of these lying around. let me try. Thanks bro. Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged June 6, 2024 Share June 6, 2024 (edited) On 6/6/2024 at 6:34 AM, Achtung said: i got some of these lying around. let me try. Thanks bro. Expand Some tips to paste nicely: 1. Have a spray bottle to spray water mist on the film when pasting, allows you to reposition the film till you are satisfied 2. Have a squeegee to squeeze out the water after final positioning. I'm using one with felt edge to reduce scratches to the film 3. Leave a little bit of the film inside the door frame so that the edge of the film doesn't peel from the constant rubbing against the door frame sill. Good luck! I took about 1 hour to paste the front two windows nicely. Edited June 6, 2024 by Beehive3783 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
