Bluepica 4th Gear May 24, 2024 Share May 24, 2024 Hi, Does anyone knows what is the optimised settings for the dash cam esp on the battery protection voltage, and motion detector? My car battery just failed, when I checked back the dash cam SDCARD, i saw there were many motion detection recording at the MSCP until the car battery fails. The recording is like every minute! I think this is the second time the battery drained by the dash cam motion detection. Previously before I change to the current battery, the old dash cam F750 recording also shows a lot of recording triggered by motion at the car park and drained the previous car battery. Being an OPC, the car is park in the MSCP most of the time, so lesser time to start and charge back the battery and keep draining by the dash cam. I have set the dash cam car battery threshold to 12v and the motion detection to LOW. should I just set the motion detection to off? THanks ↡ Advertisement Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged May 24, 2024 Share May 24, 2024 On 5/24/2024 at 2:11 PM, Bluepica said: Hi, Does anyone knows what is the optimised settings for the dash cam esp on the battery protection voltage, and motion detector? My car battery just failed, when I checked back the dash cam SDCARD, i saw there were many motion detection recording at the MSCP until the car battery fails. The recording is like every minute! I think this is the second time the battery drained by the dash cam motion detection. Previously before I change to the current battery, the old dash cam F750 recording also shows a lot of recording triggered by motion at the car park and drained the previous car battery. Being an OPC, the car is park in the MSCP most of the time, so lesser time to start and charge back the battery and keep draining by the dash cam. I have set the dash cam car battery threshold to 12v and the motion detection to LOW. should I just set the motion detection to off? THanks I suggest that you get a large capacity battery pack like Neo Cellink or your dashcam. It has much longer duration for dashcam in standby mode. 1 Link to post Share on other sites More sharing options...
Beregond Supersonic May 24, 2024 Share May 24, 2024 On 5/24/2024 at 2:11 PM, Bluepica said: Hi, Does anyone knows what is the optimised settings for the dash cam esp on the battery protection voltage, and motion detector? My car battery just failed, when I checked back the dash cam SDCARD, i saw there were many motion detection recording at the MSCP until the car battery fails. The recording is like every minute! I think this is the second time the battery drained by the dash cam motion detection. Previously before I change to the current battery, the old dash cam F750 recording also shows a lot of recording triggered by motion at the car park and drained the previous car battery. Being an OPC, the car is park in the MSCP most of the time, so lesser time to start and charge back the battery and keep draining by the dash cam. I have set the dash cam car battery threshold to 12v and the motion detection to LOW. should I just set the motion detection to off? THanks I think can set a min voltage before it will cut off all recording. If your apps u can find that setting set to 12.2 v to be safe. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 24, 2024 Share May 24, 2024 On the voltage protection, what is the current cut-off voltage? Link to post Share on other sites More sharing options...
t0y0ta Supercharged May 24, 2024 Share May 24, 2024 (edited) On 5/24/2024 at 2:11 PM, Bluepica said: Hi, Does anyone knows what is the optimised settings for the dash cam esp on the battery protection voltage, and motion detector? My car battery just failed, when I checked back the dash cam SDCARD, i saw there were many motion detection recording at the MSCP until the car battery fails. The recording is like every minute! I think this is the second time the battery drained by the dash cam motion detection. Previously before I change to the current battery, the old dash cam F750 recording also shows a lot of recording triggered by motion at the car park and drained the previous car battery. Being an OPC, the car is park in the MSCP most of the time, so lesser time to start and charge back the battery and keep draining by the dash cam. I have set the dash cam car battery threshold to 12v and the motion detection to LOW. should I just set the motion detection to off? THanks RTFM bro Edited May 24, 2024 by t0y0ta Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 24, 2024 Author Share May 24, 2024 On 5/24/2024 at 3:07 PM, inlinesix said: On the voltage protection, what is the current cut-off voltage? it was set to 12V Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 24, 2024 Share May 24, 2024 On 5/24/2024 at 4:36 PM, Bluepica said: it was set to 12V Set it to 13v. See whether it will flat or not. 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 25, 2024 Share May 25, 2024 Change cam. Now 70mai A810 is cheap and good. 4K resolution to allow one to capture all offenses. 1 Link to post Share on other sites More sharing options...
Ceecookie 5th Gear May 25, 2024 Share May 25, 2024 (edited) On 5/24/2024 at 2:39 PM, DOBIEMKZ said: I suggest that you get a large capacity battery pack like Neo Cellink or your dashcam. It has much longer duration for dashcam in standby mode. Actually no point. Such external battery require driving at least 1-2 hours a day to fully charge, in which the battery can only last about 24-48 hours of recording. Since OP is driving an OPC, OP is unlikely to clock this amount of driving to recharge fully. In addition, the battery pack will have wear and tear over the years. Some will spoil after 1-2 years, some will not retain their original capacity. I used to have one by Marbella - it spoilt after 13 months plus zzz Edited May 25, 2024 by Ceecookie 1 Link to post Share on other sites More sharing options...
Dafansu Turbocharged May 25, 2024 Share May 25, 2024 (edited) On 5/25/2024 at 10:43 AM, Ceecookie said: Actually no point. Such external battery require driving at least 1-2 hours a day to fully charge, in which the battery can only last about 24-48 hours of recording. Since OP is driving an OPC, OP is unlikely to clock this amount of driving every day. In addition, the battery pack will have wear and tear over the years. Some will spoil after 1-2 years, some will not retain their original capacity. I used to have one by Marbella - it spoilt after 13 months plus zzz actually such battery pack with installation easily cost few hundred dollars and need to do a replacement after few years. I find it no point to have, eventually such amount spent can easily cover the cost of repair even in a hit and run or mischief scenario during parking. Not forgetting the hassle of finding the culprit and the subsequent claim. Edited May 25, 2024 by Dafansu 1 Link to post Share on other sites More sharing options...
Rayleigh 6th Gear May 25, 2024 Share May 25, 2024 On 5/24/2024 at 2:11 PM, Bluepica said: Hi, Does anyone knows what is the optimised settings for the dash cam esp on the battery protection voltage, and motion detector? My car battery just failed, when I checked back the dash cam SDCARD, i saw there were many motion detection recording at the MSCP until the car battery fails. The recording is like every minute! I think this is the second time the battery drained by the dash cam motion detection. Previously before I change to the current battery, the old dash cam F750 recording also shows a lot of recording triggered by motion at the car park and drained the previous car battery. Being an OPC, the car is park in the MSCP most of the time, so lesser time to start and charge back the battery and keep draining by the dash cam. I have set the dash cam car battery threshold to 12v and the motion detection to LOW. should I just set the motion detection to off? THanks If I am at home ground carpark, i will pull out the adaptor from the camera. This is because i know the drivers in my estate are pretty decent. So far no funny behaviors. Once am out of homeground, it is always power on thru celllink. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 25, 2024 Share May 25, 2024 Since it’s a MSCP, get a portable jumpstarter to keep in car. The shop set my i-Drive cam to 12.3V which is the highest. Link to post Share on other sites More sharing options...
badlammy 6th Gear May 26, 2024 Share May 26, 2024 On 5/25/2024 at 10:38 AM, Mkl22 said: Change cam. Now 70mai A810 is cheap and good. 4K resolution to allow one to capture all offenses. +1 I'm using A800S and it's always on (not even parking mode cuz I'm not using the 70mai wiring kit but a previous dashcam voltage regulator). My last car battery last >3.5years before I replaced it this January. 1 Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 29, 2024 Author Share May 29, 2024 On 5/25/2024 at 11:54 PM, Fcw75 said: Since it’s a MSCP, get a portable jumpstarter to keep in car. The shop set my i-Drive cam to 12.3V which is the highest. I got a jump starter cable in my car trunk cos I've been begging a few times from my neighbour in the same car park to jump start my car during the past few battery failure... sui sui that day I parked head in! LL lo... zzZZ 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 29, 2024 Share May 29, 2024 On 5/29/2024 at 9:42 AM, Bluepica said: I got a jump starter cable in my car trunk cos I've been begging a few times from my neighbour in the same car park to jump start my car during the past few battery failure... sui sui that day I parked head in! LL lo... zzZZ I saw a sista post tiktok bideo of calling emergency jumpstart. This is the link: https://swiftbatteryspecialist.sg/ Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 29, 2024 Share May 29, 2024 (edited) On 5/29/2024 at 9:42 AM, Bluepica said: I got a jump starter cable in my car trunk cos I've been begging a few times from my neighbour in the same car park to jump start my car during the past few battery failure... sui sui that day I parked head in! LL lo... zzZZ Don’t trouble others la. Jumpstart cable is so passé. A portable jumpstarter is not ex nowadays like 70mai or Baseus. Edited May 29, 2024 by Fcw75 1 2 Link to post Share on other sites More sharing options...
waimi34 Neutral Newbie July 15, 2024 Share July 15, 2024 Consider setting your dash cam's battery protection voltage higher to 12.2V or above to optimize performance. For motion detection, adjust sensitivity or explore parking mode options like low-power settings to conserve battery, ensuring reliable surveillance with minimal drain, akin to using a Mauricette Calculator. ↡ Advertisement Link to post Share on other sites More sharing options...
Marbella DashCam Users
DIY Dashcam Installation vs Poor Worksmanship from Installation Workshops
Dashcam with GPS
Dashcam with GPS
ThinkWare DashCam group buy
Any recommendations for a good dashcam for new drivers?
THINKWARE / INAVI Users, Come In
Dashcam comparion: BlackVue iRoad and Thinkware
