WPS Neutral Newbie January 30, 2024 Share January 30, 2024 I have a 6.5-year-old Qashqai J11 with a 1.2 DTG engine, and I'm dealing with a persistent DTC code P0597(13) indicating an open circuit in the thermostat heater control system. I've used an OBDII Bluetooth device to scan and manually reset the engine light, but it returns after 3 to 4 days. The car seems to be driving fine, and there's an added benefit of improved cooling from the air conditioning. I have a few questions: Is it safe to continue driving with this issue? How much does Tang Chong charge for replacing the thermostat housing? Can you recommend a workshop for this replacement, and what's the estimated cost? Thank you for your guidance. ↡ Advertisement Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 30, 2024 Share January 30, 2024 How much does Tang Chong charge for replacing the thermostat housing? Ask Tang, I think quote you how much still no charge you one. Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator January 30, 2024 Share January 30, 2024 Thermostat in general is cheap. Is the installation that cost alot. but must change lah, thermostat regulate the temperature by allowing coolant to cool down the engine. is the car still under warranty? If you are thinking of going to tan chong, don't look at the price, cuz there is no tan chong 2 in SG liao. Only one tan chong. Link to post Share on other sites More sharing options...
Ahwhye 5th Gear January 30, 2024 Share January 30, 2024 TS's thermostat heater is for what one huh? 1. Interior aircon/heating? since TS say improve aircon.... or 2. engine coolant, @kobayashiGTsay one.... I admit i noob, ok? Link to post Share on other sites More sharing options...
Ct3833 Supersonic January 30, 2024 Share January 30, 2024 (edited) On 1/30/2024 at 2:02 AM, WPS said: I have a 6.5-year-old Qashqai J11 with a 1.2 DTG engine, and I'm dealing with a persistent DTC code P0597(13) indicating an open circuit in the thermostat heater control system. I've used an OBDII Bluetooth device to scan and manually reset the engine light, but it returns after 3 to 4 days. The car seems to be driving fine, and there's an added benefit of improved cooling from the air conditioning. I have a few questions: Is it safe to continue driving with this issue? How much does Tang Chong charge for replacing the thermostat housing? Can you recommend a workshop for this replacement, and what's the estimated cost? Thank you for your guidance. Expand If the aircon heater is not working, you can continue to drive the car. In the cold weather country might be a problem but not here in a tropical climate. The problem will be you will lose the climate control, your aircon will blow the coldest air without having hot air to mix to provide you with the desire temperature you set. Edited January 30, 2024 by Ct3833 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 30, 2024 Share January 30, 2024 I thot in hot hot SG cold cold Aircon is ok? In cool European summer they just need a bit of cool Aircon and not full blast cold air or they freeze to death? My car radiator thermostat is gone case. So my mechanic just link the fan to my Aircon blower. Aircon off radiator fan not moving. Fan speed 1 slow fan Fan 2 faster, fan 3 super fast. The hotter the day the more Aircon you need right? Radiator is the same. Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 30, 2024 Share January 30, 2024 Don't fix. Air con too cold just open the window. Too hot again just close window! Anyway fan speed working right? Just use lower fan speed and blast the cool air to the back. The kids complaining hot hot will be a thing of the past. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic January 30, 2024 Share January 30, 2024 It is the engine coolant thermostat. Uplorry liao. P0597 Code: Thermostat Heater Control Circuit / Open The thermostat is the valve that helps regulate the engine’s temperature. It ensures the engine gets hot enough to do its job without running the risk of overheating by controlling the flow of coolant fluid to the radiator for waste heat disposal. While older engines use mechanical means to adjust their thermostats, newer designs use electronic thermostats directed by the powertrain control module (PCM) for greater efficiency. If you want to push your luck and wait until CNY when many car workshops will be closed, I mean I cant stop you from feeling lucky. If you scared expensive then search for local Nissan stockist and BYO thermostat. Get ready your e-logcard and show them the engine/chassis number. I dunno, this is what they will ask for to get the correct spare parts for your car. Link to post Share on other sites More sharing options...
chaos22 Neutral Newbie Monday at 11:17 AM Share Monday at 11:17 AM On 1/30/2024 at 2:02 AM, WPS said: I have a 6.5-year-old Qashqai J11 with a 1.2 DTG engine, and I'm dealing with a persistent DTC code P0597(13) indicating an open circuit in the thermostat heater control system. I've used an OBDII Bluetooth device to scan and manually reset the engine light, but it returns after 3 to 4 days. The car seems to be driving fine, and there's an added benefit of improved cooling from the air conditioning. I have a few questions: Is it safe to continue driving with this issue? How much does Tang Chong charge for replacing the thermostat housing? Can you recommend a workshop for this replacement, and what's the estimated cost? Also, has anyone here done a grid heater delete on a 6.7 Cummins? Looking for some insight on that as well. Thank you for your guidance. Expand You should be fine driving for now, but definitely get it fixed soon to avoid bigger issues. Tang Chong can be pricey, so maybe check a few other local shops. A thermostat housing replacement could run you around $150–$300 depending on where you go. ↡ Advertisement Link to post Share on other sites More sharing options...
Change that Thermostat!
Are There Any Benefis of a Low Temp Thermostat?
Need help: Where to get remote oil cooler thermostat?
Where to Find Aftermarket Thermostat?
Anyone Tried Running W/o a water Thermostat?
reco ws in yishun to chg thermostat
Sports Thermostat
Sports Thermostat
