inlinesix Hypersonic November 16, 2023 Share November 16, 2023 On 11/16/2023 at 9:09 AM, ER-3682 said: Cheap...is it Full Synthetic Oil.? Unlikely semi-syn can fulfill its strict requirement. It is likely a blend of Group III and IV oil ↡ Advertisement 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 16, 2023 Share November 16, 2023 On 11/16/2023 at 9:52 AM, Gnahp said: mercedes didn't states that in the spec I use this because 229.51 is a low SAPS (Sulphated Ash, Phosphorus, and Sulphur) oil my car is UK spec that came with gasoline particulate filters (GPF) that call for low SAPS engine oil gasoline particulate filters (GPF) function is same like diesel particulate filter (DPF) that commonly found on diesel engine In general, I think can use ACEA-C3 & C4 oil. Due to HTHS requirement, you can't use thinner oil. 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic November 16, 2023 Share November 16, 2023 On 11/16/2023 at 10:13 AM, Gnahp said: I learnt it the hard way last time after changing aircon filter of my W204, whole body ache for a few days 😁 I still do have aches...only use 2 dollah diaso light to shine...but still have to go by feel becos of the obscure cabin filter slot in all wowo...😅 2 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged November 16, 2023 Author Share November 16, 2023 On 11/16/2023 at 10:34 AM, inlinesix said: In general, I think can use ACEA-C3 & C4 oil. Due to HTHS requirement, you can't use thinner oil. I don't want to know too much about engine oils I'll keep it simple and stupid by following the recommendations 😁 2 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged November 16, 2023 Author Share November 16, 2023 @mersaylee my right side ribcage hurts for a few days for this car because resting my body on the door sill most of the time 🤣 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic November 16, 2023 Share November 16, 2023 On 11/16/2023 at 10:43 AM, Gnahp said: @mersaylee my right side ribcage hurts for a few days for this car because resting my body on the door sill most of the time 🤣 Same...i let both sides of my body to share the brunt...used to be under 10mins job...nowadays no 15-20mins no talk...very soon will have to outsource the job...😅 2 Link to post Share on other sites More sharing options...
t0y0ta Supercharged November 16, 2023 Share November 16, 2023 On 11/16/2023 at 10:37 AM, Gnahp said: I don't want to know too much about engine oils I'll keep it simple and stupid by following the recommendations 😁 If you change often yourselves no need to use super-ex or super-branded oil. Better for engine if you change just-good-enough oil more frequently. 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 16, 2023 Share November 16, 2023 On 11/14/2023 at 12:20 PM, t0y0ta said: bolt also need to change? Actually I noticed that workshops I go don't bother to change the copper washer. But never leak They used brute strength to tighten. Then threads get worn faster. They will tell you it’s ok one. And if a problem happens the typically dunno why ley. grease monkey replies… 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 16, 2023 Share November 16, 2023 (edited) On 11/16/2023 at 10:35 AM, mersaylee said: I still do have aches...only use 2 dollah diaso light to shine...but still have to go by feel becos of the obscure cabin filter slot in all wowo...😅 Wear a decent headlamp. Makes the job so much easier. But the old body still have to contort to change. Japanese design much better. Just open the glove box and be done. Aircon filter is to prevent the coil from clogging. Not so much about filtering the air. Filter what air. Open the door and half the air in the car gets exchanged with outside air. to test air exchange you can fart in the car open the door to exit and then go back in to smell if the “scent” still lingers…. 😂 Edited November 16, 2023 by Mkl22 2 3 Link to post Share on other sites More sharing options...
Gnahp Turbocharged December 24, 2023 Author Share December 24, 2023 I drained the wrong spec oil and replaced it with the correct MB229.51 oil now merc don't give you dipstick anymore last time my W204 can suck the oil out from the dipstick tube, much easier comparing to this car where you need to drain the oil in old fashion way and they cover the entire underside of the engine compartment I spent almost half an hour lying on the floor just to remove the cover hello drain bolt 😘 old drain bolt + old washer vs new drain bolt + new washer you can see the old washer is compressed until it formed a lip around the circumference new washer is flat on both sides torque it to 40Nm fill up the engine, reset the service reminder, start the engine to warm up the oil and check for leaks and oil level I am happy with the oil level 8 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 26, 2023 Share December 26, 2023 On 12/25/2023 at 5:50 AM, Gnahp said: I drained the wrong spec oil and replaced it with the correct MB229.51 oil now merc don't give you dipstick anymore last time my W204 can suck the oil out from the dipstick tube, much easier comparing to this car where you need to drain the oil in old fashion way and they cover the entire underside of the engine compartment I spent almost half an hour lying on the floor just to remove the cover hello drain bolt 😘 old drain bolt + old washer vs new drain bolt + new washer you can see the old washer is compressed until it formed a lip around the circumference new washer is flat on both sides torque it to 40Nm fill up the engine, reset the service reminder, start the engine to warm up the oil and check for leaks and oil level I am happy with the oil level You DIY-ed? 1 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged December 26, 2023 Author Share December 26, 2023 On 12/26/2023 at 9:50 AM, kobayashiGT said: You DIY-ed? yes I asked my wife how much she will pay for all those work she said $20 😭 6 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 26, 2023 Share December 26, 2023 On 12/26/2023 at 3:27 PM, Gnahp said: yes I asked my wife how much she will pay for all those work she said $20 😭 You should retort dye hair black can also just use some of the used engine oil….. FREE!!!!! 1 Link to post Share on other sites More sharing options...
Beregond Supersonic December 26, 2023 Share December 26, 2023 On 12/26/2023 at 3:27 PM, Gnahp said: yes I asked my wife how much she will pay for all those work she said $20 😭 🦾si bei on👍 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged December 26, 2023 Author Share December 26, 2023 On 12/26/2023 at 3:37 PM, Mkl22 said: You should retort dye hair black can also just use some of the used engine oil….. FREE!!!!! oh yes the 5L engine oil that I bought only has 4.7L inside so don't rely on it when you fill your engine oil I always measure the oil capacity using a jug before pouring into the engine 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 26, 2023 Share December 26, 2023 On 12/26/2023 at 3:52 PM, Gnahp said: oh yes the 5L engine oil that I bought only has 4.7L inside so don't rely on it when you fill your engine oil I always measure the oil capacity using a jug before pouring into the engine Go and bang table 😂 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 26, 2023 Share December 26, 2023 On 12/26/2023 at 3:27 PM, Gnahp said: yes I asked my wife how much she will pay for all those work she said $20 😭 You buy EV better. Hhahaha, PLug and play only. 🤣 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged December 26, 2023 Author Share December 26, 2023 On 12/26/2023 at 3:54 PM, inlinesix said: Go and bang table 😂 it's quite normal actually that is why over the years I learnt not to trust the capacity on the label although I never encounter one that has more than 100% maybe I suay 😁 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Where do you do your servicing/repair/tyre change?
