Engine oil change - what can go wrong
Gnahp
On 9/26/2023 at 5:43 PM, Fcw75 said:
I find that only SPC got this damn issue with their lousy nozzle. No such issue with Esso.
Yes. Got one that kept dripping. Knn! Almost had to put my hand under to catch the drips. Till I turn the nozzle upside down to extract it
On 9/25/2023 at 4:50 PM, Gnahp said:
this can happen at any workshop
it was not my intention to expose the workshop
just sharing what can go wrong when you send your car for servicing/repair 😁
Hahah you are an AD agent 😂😂
his message is just service your car at AD 😂😂
BTW I still service with my AD because of service credit given when I bought my car 😄
  • Haha! 1
 I replace the aircon filters recently
here are the collateral damages
1 x misaligned outer aircon filter box, it didn't click and sealed in place, so the air didn't go through the filter 100%
1 x missing screw securing the cover under glovebox
1 x torn foam insulation pad around fuse box
my trusty 3M double sided tape
done
  • Praise 3
done
U DIY or ws do?
On 10/20/2023 at 5:15 PM, Beregond said:
U DIY or ws do?
the damages or the rectifications? 😁
  • Haha! 2
bought some consumables for the next oil change
engine oil
oil filter
oil sump bolt
copper sealing washers
  • Praise 6
engine oil
oil filter
oil sump bolt
How much for that engine oil?
engine oil
oil filter
oil sump bolt
bolt also need to change?
Actually I noticed that workshops I go don't bother to change the copper washer. But never leak
  • Haha! 1
@t0y0ta
usually I will buy one extra drain bolt to rotate
the one taken out from car will be covered in oil, I will clean it at home with brake cleaner for the next oil change so that I can have a clean and fresh bolt at every oil change
copper washer can be reused many times provided you don't flatten them too much by over torqueing
it's cheap, I don't replace it every oil change, that 10 pieces can last more than 10 years 😁
  • Praise 4
On 11/14/2023 at 12:32 PM, Gnahp said:
@Beregond
$58 before GST for 5 liters
bought two as my car needs 6.6L
Cheap...is it Full Synthetic Oil.?
Edited by ER-3682
mercedes didn't states that in the spec
I use this because 229.51 is a low SAPS (Sulphated Ash, Phosphorus, and Sulphur) oil
my car is UK spec that came with gasoline particulate filters (GPF) that call for low SAPS engine oil
gasoline particulate filters (GPF) function is same like diesel particulate filter (DPF) that commonly found on diesel engine
  • Praise 3
On 11/16/2023 at 10:08 AM, mersaylee said:
Smart...use a mirror and light...👍
I learnt it the hard way
last time after changing aircon filter of my W204, whole body ache for a few days 😁
  • Haha! 3
