Discoburg Supersonic May 18, 2023 Share May 18, 2023 (edited) Any good recommendations for the HDMI to usb C cable for the above mentioned? Edited May 18, 2023 by Discoburg ↡ Advertisement Link to post Share on other sites More sharing options...
Soya Supersonic May 18, 2023 Share May 18, 2023 Chey....thot watch TV can get MBA 5 Link to post Share on other sites More sharing options...
Inlinefour Twincharged May 18, 2023 Share May 18, 2023 Apple TV airplay very convenient 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic May 18, 2023 Share May 18, 2023 On 5/18/2023 at 8:35 PM, Soya said: Chey....thot watch TV can get MBA Can tell your vision not 20/20...see until MaBoAlready or not? 😁 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator May 19, 2023 Share May 19, 2023 On 5/18/2023 at 8:31 PM, Discoburg said: Any good recommendations for the HDMI to usb C cable for the above mentioned? this dongle is good enough. I have one for my office usage also. https://shopee.sg/UGREEN-USB-C-to-HDMI-Adapter-Cable-4K-60Hz-Thunderbolt-3-Type-C-HDMI-2.0-Converter-i.64922680.5546416180?sp_atk=34874dd9-ba2c-465e-bc25-2765db99ed4b&xptdk=34874dd9-ba2c-465e-bc25-2765db99ed4b 4 Link to post Share on other sites More sharing options...
Discoburg Supersonic May 19, 2023 Author Share May 19, 2023 On 5/19/2023 at 9:08 AM, kobayashiGT said: this dongle is good enough. I have one for my office usage also. https://shopee.sg/UGREEN-USB-C-to-HDMI-Adapter-Cable-4K-60Hz-Thunderbolt-3-Type-C-HDMI-2.0-Converter-i.64922680.5546416180?sp_atk=34874dd9-ba2c-465e-bc25-2765db99ed4b&xptdk=34874dd9-ba2c-465e-bc25-2765db99ed4b Yours is also the 2020 MacBook Air? Been looking around and a lot only works on the 2017 version. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged May 19, 2023 Share May 19, 2023 Cannot airplay? Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 19, 2023 Share May 19, 2023 Not sure if yours is same as mine. Mine is Macbook Air with M1 chip. There is also intel chip versions in 2020. I am using two types. I use it on external monitor and tv. This one is made for macbook and works well, no issues. Only issue is if left plugged in, it will drain the battery. This one that I am using, interchangeable with my ipad air too. No issues too. 4 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged May 19, 2023 Share May 19, 2023 On 5/18/2023 at 8:31 PM, Discoburg said: Any good recommendations for the HDMI to usb C cable for the above mentioned? My friend using Anker brand. He said stable connection thorough. May have to buy online as local outlets may not sell. https://www.amazon.sg/Adapter-MacBook-Samsung-Thunderbolt-Compatible/dp/B08DLK2FD9/ref=sr_1_6?adgrpid=149301282848&hvadid=636214781465&hvdev=c&hvlocphy=9062530&hvnetw=g&hvqmt=e&hvrand=14612555628912424496&hvtargid=kwd-385818346025&hydadcr=11238_330474&keywords=anker+hdmi+to+usb+c&qid=1684479813&sr=8-6 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic May 19, 2023 Author Share May 19, 2023 On 5/19/2023 at 11:21 AM, Adrianli said: Not sure if yours is same as mine. Mine is Macbook Air with M1 chip. There is also intel chip versions in 2020. I am using two types. I use it on external monitor and tv. This one is made for macbook and works well, no issues. Only issue is if left plugged in, it will drain the battery. This one that I am using, interchangeable with my ipad air too. No issues too. Yeah mine is the M1 chip version. 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic May 20, 2023 Author Share May 20, 2023 On 5/19/2023 at 9:08 AM, kobayashiGT said: this dongle is good enough. I have one for my office usage also. https://shopee.sg/UGREEN-USB-C-to-HDMI-Adapter-Cable-4K-60Hz-Thunderbolt-3-Type-C-HDMI-2.0-Converter-i.64922680.5546416180?sp_atk=34874dd9-ba2c-465e-bc25-2765db99ed4b&xptdk=34874dd9-ba2c-465e-bc25-2765db99ed4b Decided to get this. 1 Link to post Share on other sites More sharing options...
Ehtesham Neutral Newbie May 20, 2023 Share May 20, 2023 For HDMI to USB-C cables, it's crucial to find one that supports video and audio transmission with good quality. Recommended options include the Cable Matters USB-C to HDMI Cable, which supports 4K video resolution and works well with the MacBook Air 2020. Another reliable choice is the Anker USB-C to HDMI Cable, known for its durability and 4K resolution at 60Hz. Lastly, the uni USB-C to HDMI Cable supports up to 4K resolution at 60Hz, is compatible with the MacBook Air 2020, and is suitable for most TVs. Remember to check compatibility and specifications of the chosen cable, as well as ensure that your TV has an HDMI input and your MacBook Air 2020 has a USB-C port for proper connection. 2 Link to post Share on other sites More sharing options...
Discoburg Supersonic May 20, 2023 Author Share May 20, 2023 Thanks for the valuable inout@Ehtesham 1 Link to post Share on other sites More sharing options...
D3badge 6th Gear May 21, 2023 Share May 21, 2023 On 5/19/2023 at 3:07 PM, DOBIEMKZ said: My friend using Anker brand. He said stable connection thorough. May have to buy online as local outlets may not sell. https://www.amazon.sg/Adapter-MacBook-Samsung-Thunderbolt-Compatible/dp/B08DLK2FD9/ref=sr_1_6?adgrpid=149301282848&hvadid=636214781465&hvdev=c&hvlocphy=9062530&hvnetw=g&hvqmt=e&hvrand=14612555628912424496&hvtargid=kwd-385818346025&hydadcr=11238_330474&keywords=anker+hdmi+to+usb+c&qid=1684479813&sr=8-6 Anker can buy at a shop in Parkway Parade outside M1 shop in level 2 2 Link to post Share on other sites More sharing options...
Ehtesham Neutral Newbie May 25, 2023 Share May 25, 2023 @Discoburg My pleasure. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Apple Launches Service for Transferring iCloud Photos and Videos to Google Photos
Samsung and Huawei crush Apple's smartphone global share
Apple In the news
Apple In the news
Apple Vision Pro
Apple Vision Pro
Big Tech Companies
Big Tech Companies
The NYPD is handing out free AirTags to combat car theft (and why you should get one too)
Apple already building latest iPhone 14 in India
