bnhc86 Neutral Newbie August 16 Share August 16 @Terence2112 On 8/16/2024 at 7:17 AM, Terence2112 said: Mines edrive35. Do you always down the throttle? Your comfort mode is quite low? My average is 6.6km/kwh for both eco and comfort. nope, i drive quite granny...haha.... i did ask my sales guy, he told mi to run in 8000-9000km more. the more i drive the more ranges i get..... kinda craps... did u off any functions?what is your AC setting like? ↡ Advertisement Link to post Share on other sites More sharing options...
Terence2112 2nd Gear August 16 Share August 16 On 8/16/2024 at 9:12 AM, bnhc86 said: @Terence2112 nope, i drive quite granny...haha.... i did ask my sales guy, he told mi to run in 8000-9000km more. the more i drive the more ranges i get..... kinda craps... did u off any functions?what is your AC setting like? You got the car as the same time as me. I’m at the 2nd mth of ownership too. I don’t off any functions. My AC is set at either 22/23 degrees with max 2 speed. Link to post Share on other sites More sharing options...
inlinesix Hypersonic August 16 Share August 16 On 8/16/2024 at 9:12 AM, bnhc86 said: nope, i drive quite granny...haha.... i did ask my sales guy, he told mi to run in 8000-9000km more. the more i drive the more ranges i get..... kinda craps... did u off any functions?what is your AC setting like? Radx uses intelligent regen. For EV, need to drive as fast as possible. After that, it is either cruise or coast. As much as possible, coast to stop. Don't hold brake from far far cause you need to step on accelerator a few hundred meter before the line. Lastly, granny driving doesn't help with energy consumption due to the weight. 4 Link to post Share on other sites More sharing options...
RadX Moderator August 16 Author Share August 16 On 8/16/2024 at 9:22 AM, inlinesix said: Radx uses intelligent regen. For EV, need to drive as fast as possible. After that, it is either cruise or coast. As much as possible, coast to stop. Don't hold brake from far far cause you need to step on accelerator a few hundred meter before the line. Lastly, granny driving doesn't help with energy consumption due to the weight. i5 uses adaptive and it does the job well. shows how much I have gained after a journey 1 Link to post Share on other sites More sharing options...
bnhc86 Neutral Newbie August 17 Share August 17 my SOC @ 80% is always not more then 270km.... Link to post Share on other sites More sharing options...
Terence2112 2nd Gear August 17 Share August 17 On 8/17/2024 at 6:54 PM, bnhc86 said: my SOC @ 80% is always not more then 270km.... What is your air con settings? Link to post Share on other sites More sharing options...
bnhc86 Neutral Newbie August 17 Share August 17 @Terence2112 1 fan at 22degree Link to post Share on other sites More sharing options...
Terence2112 2nd Gear August 17 Share August 17 On 8/17/2024 at 8:15 PM, bnhc86 said: @Terence2112 1 fan at 22degree Strange….. what was you km/kwh before charging to 80%? Link to post Share on other sites More sharing options...
bnhc86 Neutral Newbie August 17 Share August 17 On 8/17/2024 at 8:38 PM, Terence2112 said: Strange….. what was you km/kwh before charging to 80%? eco pro , 6.5km/kwh Link to post Share on other sites More sharing options...
Terence2112 2nd Gear August 17 Share August 17 On 8/17/2024 at 8:39 PM, bnhc86 said: eco pro , 6.5km/kwh Did you upsize your rims? Link to post Share on other sites More sharing options...
bnhc86 Neutral Newbie August 17 Share August 17 On 8/17/2024 at 9:05 PM, Terence2112 said: Did you upsize your rims? no aftermarket mod nor anything. factory 19" Link to post Share on other sites More sharing options...
Terence2112 2nd Gear August 17 Share August 17 On 8/17/2024 at 9:13 PM, bnhc86 said: no aftermarket mod nor anything. factory 19" Hmmmm, that’s strange. Link to post Share on other sites More sharing options...
Kklee 6th Gear August 17 Share August 17 IMHO. Check tyre pressure? Link to post Share on other sites More sharing options...
bnhc86 Neutral Newbie August 20 Share August 20 tyre pressure is normal and above the within range. Link to post Share on other sites More sharing options...
Fat_slayer 4th Gear September 4 Share September 4 @bnhc86 my range wrt to the SOC conditions also similar to your. Maximum is 370km thereabout. No upside of rims. However air con at 20 deg Link to post Share on other sites More sharing options...
RadX Moderator September 4 Author Share September 4 Change to i5 la😂😂 1 Link to post Share on other sites More sharing options...
Terence2112 2nd Gear September 5 Share September 5 @Fat_slayer My air con is set at 22/23, max 2 speed. i get about 6.6 to 7km/kwh. With 80% SOC, the range I can get is about 350km. it might be due to the air conditioning ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Sensha and Ceramic Pro 9H
2025 BMW X3 G45
2025 BMW X3 G45
All BMW owner thread
[Official] 2025 2nd Generation BMW 2 Series Gran Coupé (F74)
