JZA80 Clutched February 13, 2023 Share February 13, 2023 Just checking. What are the pros and cons of ownself buying Android player and asking workshop to install ? I assume cost will be cheaper than buying from local ICE shop. ↡ Advertisement Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator February 13, 2023 Share February 13, 2023 They provide warranty and aftersales support. Depends on what you want from the android player. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 14, 2023 Share February 14, 2023 (edited) False economy. Any problem installer will say player not working. Claim warranty manufacturer will say installer spoiled it. If going Android get high ram and memory or damn slow. Also phone does everything Android player does and do it better. So really need an Android player? Or can better spent money elsewhere. I have an Android player in my car and a normal one Din player in my van and the van player sounds so much better. Edited February 14, 2023 by Jamesc Link to post Share on other sites More sharing options...
Mancypher 3rd Gear February 14, 2023 Share February 14, 2023 21 hours ago, JZA80 said: Just checking. What are the pros and cons of ownself buying Android player and asking workshop to install ? I assume cost will be cheaper than buying from local ICE shop. Few questions: 1. Your purpose of getting android player? [friend using, i want one too is not counted] 2. Your current drive and current head unit? [to see worth it or not worth it to get one] 3. Your budget? [min for good spec SGD$350 n above for player only. With panel is $400 and above] Link to post Share on other sites More sharing options...
Mancypher 3rd Gear February 14, 2023 Share February 14, 2023 7 hours ago, Jamesc said: False economy. Any problem installer will say player not working. Claim warranty manufacturer will say installer spoiled it. If going Android get high ram and memory or damn slow. Also phone does everything Android player does and do it better. So really need an Android player? Or can better spent money elsewhere. I have an Android player in my car and a normal one Din player in my van and the van player sounds so much better. High RAM and memory is useless if processor lousy. But be 3-in-1. Just like kopi packet. 😁 1 Link to post Share on other sites More sharing options...
Dafansu Turbocharged February 14, 2023 Share February 14, 2023 23 hours ago, JZA80 said: Just checking. What are the pros and cons of ownself buying Android player and asking workshop to install ? I assume cost will be cheaper than buying from local ICE shop. better off get everything from the workshop as some may have compatibility issue. At least u will be assured everything works fine and they usually will provide some form of warranty. ↡ Advertisement Link to post Share on other sites More sharing options...
MINDEF's English Lessons
