Yishun Happenings
Fcw75
Hypersonic
  On 5/12/2023 at 8:02 AM, SGMCF328 said:
Stay condo next to new BTO also stress...
Condo residents raise a stink over Yishun BTO bin centre, HDB adjusts project
Source: https://www.straitstimes.com/singapore/condo-residents-raise-a-stink-over-yishun-bto-bin-centre-hdb-adjusts-layout-of-bto-project
230512-MAP-Mitonia-Breeze-BTO-bin-jnbin1
Residents of a condominium in Yishun have raised a stink over the bin centre of an adjacent Build-to-Order (BTO) Housing Board (HDB) project that is under construction.
Their feedback prompted the HDB to change the orientation of the bin centre and put in a new access road for the waste removal trucks to divert them away from the Skies Miltonia condo.
In an e-mail thread obtained by The Straits Times, 66 home owners signed a petition and submitted it to HDB representatives and their MP, Mr Derrick Goh (Nee Soon GRC), on March 21 to move the pneumatic waste conveyance system (PWCS) bin centre of the BTO project Miltonia Breeze @ Yishun.
HDB told The Straits Times that it had been working with Mr Goh and grassroots leaders to engage the Miltonia Residents’ Network and residents of Skies Miltonia on their concerns.
The resident’s network comprises residents of the three nearby condominiums: Skies Miltonia, The Shaughnessy and The Miltonia Residences.
To address their concerns, HDB will reorientate the facing of the PWCS bin centre away from Skies Miltonia, and provide an additional access road to the bin centre via Yishun Avenue 1.
It will also extend the PWCS exhaust ducting so that the discharge point is further away from the condominium.
It will roll out more landscaping such as planting dense and layered greenery to screen off the bin centre and service road from Skies Miltonia, and serve as an added acoustic buffer as well as improve the aesthetics of the facility.
This includes providing a green roof and trellis to “soften the visual impact for Skies Miltonia residents living on the higher storeys”.
The BTO project of 1,334 units had its sales launch in November 2022 and is estimated to receive its temporary occupation permit in June 2029.
In the e-mail thread, one resident wrote to HDB and Mr Goh: “Put yourself in our shoes. What would you feel, if the greenery next to your house was to be removed, and construction was to be carried out for a few years, only for that greenery to be replaced by a centralised waste centre.”
One of the residents behind the petition who declined to be named told ST that the changes were not to the residents’ satisfaction as they had called for the centre to be moved to the east, near a site reserved for a park.
He noted that the bin centre is currently set to be built closer to the condo’s blocks than to the HDB blocks.
“They have not exercised the same duty of care to their neighbours as they have for their own blocks,” he said.
The resident also said that the PWCS filters cannot completely remove the odour from the rubbish, and moving the exhaust ducting away from the condo would not address the noise issue arising from the operation of the bin centre.
The bin centre at the BTO project will be 32m from the nearest residential block at Skies Miltonia, with the condominium’s tennis court, planted boundary and a future service road between them, said HDB.
It added that this distance is within planning norms and complies with regulatory requirements.
“In fact, the 32m separation is further than the distance between the existing bin compounds of the other private residential developments in the area, for example, Skies Miltonia, Miltonia Residences and The Shaughnessy, from one another, and also further than the distance between Skies Miltonia’s bin centre and the nearest future HDB block,” it added.
The PWCS is an enclosed system that uses pneumatic suction to transport household refuse through an underground pipe network to a centralised bin centre. The refuse is stored in sealed containers and taken to incineration plants by waste disposal trucks.
No worker is needed to manually collect the refuse from rubbish chutes at individual blocks.
The bin centre is largely enclosed except for the discharge valve, but even that will release only filtered air towards the public road at Yishun Avenue 1, away from residential developments, said HDB.
A resident of Skies Miltonia who wanted to be known only as Mr Tan, 64, told ST that he decided not to sign the petition because he felt it was premature to do so without waiting for HDB’s response.
HDB representatives met residents to listen to their concerns on March 4 and had yet to respond before the residents behind the petition went door to door to get signatures.
“HDB has done what it can do, and it’s more than I thought they would do,” said Mr Tan, a director of a logistics firm.
“There are pros and cons. People are saying the value of their homes will drop because of this BTO, but there are also others who say that with the BTO there, we will have more amenities, which is a plus point,” he noted.
He added that he is glad that the PWCS bin centres at least have the technology to reduce odour and noise.
Mr Goh, the MP, said the residents’ network held three meetings with HDB to address residents’ concerns, the latest on May 6.
He told ST: “I understand the need to build more HDB BTOs in the Miltonia area given the strong housing demand in land-scarce Singapore.
“It will mean that we will live closer together, so I hope our condominium residents will accommodate this new development and I thank them for their patience and understanding.”
So the condo resident are not understanding / accommodating enough? If a bin centre is to be built 32m away from some big shot's / minister's resident, will the response be the same?  Why can't HDB relocate the bin centre to the other side of the building, which is closer to the new access road, as well as in the middle of the new BTO? 🤔
Expand
Should have used the same consultancy company that design and build the bin center for National Gallery mah.
Hear say that bin center sibei hor one
  • Haha! 8
Twincharged
Expand
that bin center will bring up property value hor...
  • Haha! 3
  On 5/17/2023 at 6:07 AM, Tohto said:
Like this also consider as Yishun problem ah.... the other end of 854 is Bedok leh
Expand
i do take bus and whenever I see 85x bus numbers, I think of Yishun. :D
  • Haha! 5
Hypersonic
Man, 73, molests 3 girls at Yishun’s Northpoint City mall, tells judge ‘it’s okay to die in prison’
During investigations, he admitted that he made a conscious decision to touch the victims and stated that these incidents were "trivial" to him since he did not "rape" the victims.
https://www.todayonline.com/singapore/man-73-molests-girls-northpoint-city-mall-yishun-judge-die-prison-2174376?fbclid=IwAR23TNsdhsaxv07oGK_DisfOpTbSFQoJvb1sy3KW6BXgdDOH8Rgy0Ilqumc&mibextid=Zxz2cZ
Edited by Fcw75
  • Angry 3
  • Shocked 7
  • Sad 1
  • Haha! 5
Expand
Purposely want to go jail one is it
  • Praise 2
  • Haha! 6
Hypersonic
Expand
Maybe there is a 黄脸婆 at home he don't want to see.
Imagine 24hrs nagging at home, he want peaceful in the jail.
Edited by Tohto
  • Praise 2
  • Haha! 6
Hypersonic
  On 5/19/2023 at 1:12 AM, Mustank said:
Got people go sin lim steal graphic card
Expand
How you know ah? 😈
Edited by Fcw75
  • Shocked 1
  • Haha! 3
Expand
Alamak...someone was corright to allow canning on those above big five O...there must be a trend oredi...play change cars betterer than change lodging...😂
  • Praise 4
  • Haha! 2
Expand
There are people who committed crime because they want to have free food and lodging, according to social workers I have spoken to.
But in the case of this 73 yo man, I doubt that is his only intention. Probably he was thinking, since I have to do something to check-in Changi chalet, might as well as 顺便爽一下.
Expand
You and didn't get caught? Hahahaha
Edited by SGMCF328
  • Haha! 6
Expand
NBCB. Lock him in and don't let him out lah, since he want to die in prison.
  • Praise 5
