inlinesix Hypersonic August 16 Share August 16 On 8/16/2024 at 12:25 PM, Ct3833 said: It depends but my grape juice are not the loose change type That means you drink Romanee Conti lo ↡ Advertisement 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic August 16 Share August 16 On 8/5/2024 at 9:21 AM, Beehive3783 said: Did you hear of the legend that changed car when he had a flat tyre? Tyres can be quite expensive...might as well change the entire car is understandable...but hearsay it's no longer a valid reason as far as the legend is concerned...he changes car now when the car key battery goes flat...5 dollah also not worth it anymore...just change the rest of the package...😂 3 Link to post Share on other sites More sharing options...
Kklee 6th Gear August 16 Share August 16 On 8/16/2024 at 12:24 PM, Ct3833 said: Mine simple 4 AT. My ignition coil so far ok after 1 piece replacment many years ago. These are cheap stuff anyway. IMHO. My last 4AT is from Aisin. RAV4 also uses similar transmission. No issue at 280k despite always drop "gear". 😆 That said, I monitor the ATF closely and added DIY change because it uses dipstick. I think moving forward, I unlikely will extend COE because my mileage can be close to 300k. While the CVT has been proven by the PH's Prius, not sure on the maintenance duration. Altis IIRC was 80k. 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic August 16 Author Share August 16 On 8/16/2024 at 1:09 PM, Kklee said: IMHO. My last 4AT is from Aisin. RAV4 also uses similar transmission. No issue at 280k despite always drop "gear". 😆 That said, I monitor the ATF closely and added DIY change because it uses dipstick. I think moving forward, I unlikely will extend COE because my mileage can be close to 300k. While the CVT has been proven by the PH's Prius, not sure on the maintenance duration. Altis IIRC was 80k. I will update here, see how long the AT is able to last 2 Link to post Share on other sites More sharing options...
Ct3833 Supersonic August 16 Author Share August 16 On 8/16/2024 at 12:32 PM, inlinesix said: That means you drink Romanee Conti lo Way way way.... below this class. I cannot afford that price but just need the alcohol 😀 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged August 16 Share August 16 On 8/16/2024 at 12:25 PM, Ct3833 said: It depends but my grape juice are not the loose change type Why your grape juice still loading? 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic August 16 Author Share August 16 (edited) On 8/16/2024 at 2:15 PM, Beehive3783 said: Why your grape juice still loading? Bcos i keep drinking and my fridge has ro keep loading 😅 Nah, fully loaded Edited August 16 by Ct3833 5 1 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic August 16 Share August 16 (edited) On 8/16/2024 at 3:35 PM, Ct3833 said: Bcos i keep drinking and my fridge has ro keep loading 😅 Nah, fully loaded This one is not only 久鲜 but 酒仙 😂 Your family doctor must be impressed with your blood flow...😁 Edited August 16 by mersaylee 5 Link to post Share on other sites More sharing options...
Throttle2 Supersonic August 16 Share August 16 On 8/16/2024 at 3:35 PM, Ct3833 said: Bcos i keep drinking and my fridge has ro keep loading 😅 Nah, fully loaded Finally you reveal your high SES lifestyle.. huat ah Link to post Share on other sites More sharing options...
Ct3833 Supersonic August 16 Author Share August 16 On 8/16/2024 at 6:27 PM, Throttle2 said: Finally you reveal your high SES lifestyle.. huat ah Boss cheap wine lah, one whole fridge worth less than your 1 cigar. 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic August 16 Author Share August 16 (edited) On 8/16/2024 at 3:50 PM, mersaylee said: This one is not only 久鲜 but 酒仙 😂 Your family doctor must be impressed with your blood flow...😁 Better go back to serious discussion, COE cars vs new cars. 😄 Edited August 16 by Ct3833 Link to post Share on other sites More sharing options...
inlinesix Hypersonic August 16 Share August 16 On 8/16/2024 at 8:50 PM, Ct3833 said: Better go back to serious discussion, COE cars vs new cars. 😄 Vs Restored Car🤭 1 Link to post Share on other sites More sharing options...
Throttle2 Supersonic August 16 Share August 16 On 8/16/2024 at 8:49 PM, Ct3833 said: Boss cheap wine lah, one whole fridge worth less than your 1 cigar. See lah, 大哥 talk cock again. Whole fridge less than 1 cigar…….🤦🏻♂️ 3 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged August 17 Share August 17 On 8/16/2024 at 1:09 PM, Kklee said: IMHO. My last 4AT is from Aisin. RAV4 also uses similar transmission. No issue at 280k despite always drop "gear". 😆 That said, I monitor the ATF closely and added DIY change because it uses dipstick. I think moving forward, I unlikely will extend COE because my mileage can be close to 300k. While the CVT has been proven by the PH's Prius, not sure on the maintenance duration. Altis IIRC was 80k. IMHO, you need to do homework. Prius is not CVT. The principles are totally different. Just that Toyota conveniently calls it e-CVT. 2 4 Link to post Share on other sites More sharing options...
Mkl22 Twincharged August 17 Share August 17 On 8/17/2024 at 9:28 AM, Toeknee_33 said: IMHO, you need to do homework. Prius is not CVT. The principles are totally different. Just that Toyota conveniently calls it e-CVT. Love your IMHO part! 😂 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic August 17 Share August 17 On 8/17/2024 at 9:28 AM, Toeknee_33 said: IMHO, you need to do homework. Prius is not CVT. The principles are totally different. Just that Toyota conveniently calls it e-CVT. All the hybrids should be e-cvt now. Not That I knew what the earlier gen used. Lot of mechanical ingenuity involved to get to these modern hybrid systems - 5th gen for Toyota, 3rd gen for Honda. 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear August 17 Share August 17 On 8/17/2024 at 9:28 AM, Toeknee_33 said: IMHO, you need to do homework. Prius is not CVT. The principles are totally different. Just that Toyota conveniently calls it e-CVT. IMHO. Yeah, I need to do more home work. 😆 Link to post Share on other sites More sharing options...
kingofxiaomi Neutral Newbie August 17 Share August 17 (edited) I apologise in advance if I'm out of topic, but I'm trying to figure out how to calculate the FULL cost of renewing COE. From what I've read online, it seemed like I have to just pay the PQP amount? So let's say I want to renew a Cat B car with a PQP of 100k, I only have to pay this 100k? Are there additional cost to it? Cos it doesn't make sense that I can get a low Cat B car for the same price as a high Cat B car. Of cos, we are not calculating road tax, insurance etc. Just the car itself. Thank you! edit: I am also assuming the final price of the renewed COE car depends on supply and demand, right? so it's PQP + whatever people wanna sell at. Edited August 17 by kingofxiaomi ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - July 2024
Both BYD and Tesla will now sell you Cat A versions of their popular Seal and Model 3 saloons
'I'm Happy just to get by'
COE Bidding - December 2023
COE Bidding – June 2024
How to Appeal to Extend 5year COE
COE Bidding – May 2024
