ER-3682 Twincharged January 22 Share January 22 @Mkl22 +RWD... ↡ Advertisement 1 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic January 22 Share January 22 On 1/22/2025 at 12:29 AM, ER-3682 said: @Mkl22 +RWD... Expand Mid engine is RWD. Got mid engine FWD? 😆 4 Link to post Share on other sites More sharing options...
Carbon82 Moderator January 22 Author Share January 22 On 1/20/2025 at 3:55 AM, camrysfe said: Vehicle No. SCV401A Vehicle Make/Model TOYOTA / EMINA AUTO Expand Fun Fact The width of Emina (and Lucida) is 110mm narrower than the first generation Estima so as to qualify for tax benefits of Small Size Passenger Vehicles, more commonly known as "5 number" vehicles in Japan. For "5 number" vehicles, length must be <4.7m (4,695mm max), width <1.7m (1,695mm max) and height<2.0m (1,995mm max). On 1/21/2025 at 10:12 PM, Mkl22 said: That’s nothing. There is a EE plate Jaguar E type V12 on our roads with normal plate. Imagine the amount of road tax paid since the 1970s. and road tax was much higher then than now. Expand The road tax for this E Type V12 is $9,078 (with 50% surcharge), not the highest yet. Tommie Goh has a normal plate 1994 Rolls Royce Silver Spur, which attract an annual road tax of $12,378 as of current. @107fan @inlinesix $6.6K road tax for EV is equivalent to that of a 5.7L gasoline engine. On 1/22/2025 at 12:34 AM, Mkl22 said: Mid engine is RWD. Got mid engine FWD? 😆 Expand Have lah. Mitsubishi FTO is one such example. If I am not wrong, some of the older Citroën also pair front mid engine setup with FWD. If you are referring to rear mid engine, than it should only pair with RWD. 7 Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 22 Share January 22 On 1/22/2025 at 2:03 AM, Carbon82 said: Fun Fact The width of Emina (and Lucida) is 110mm narrower than the first generation Estima so as to qualify for tax benefits of Small Size Passenger Vehicles, more commonly known as "5 number" vehicles in Japan. For "5 number" vehicles, length must be <4.7m (4,695mm max), width <1.7m (1,695mm max) and height<2.0m (1,995mm max). The road tax for this E Type V12 is $9,078 (with 50% surcharge), not the highest yet. Tommie Goh has a normal plate 1994 Rolls Royce Silver Spur, which attract an annual road tax of $12,378 as of current. @107fan @inlinesix $6.6K road tax for EV is equivalent to that of a 5.7L gasoline engine. Have lah. Mitsubishi FTO is one such example. If I am not wrong, some of the older Citroën also pair front mid engine setup with FWD. If you are referring to rear mid engine, than it should only pair with RWD. Expand That's why i said ICE car road tax must align with EV. No need to compare btw ICE and EV. All the lao pok will gain a lot😂 Link to post Share on other sites More sharing options...
Mkl22 Supersonic January 22 Share January 22 On 1/22/2025 at 2:03 AM, Carbon82 said: Fun Fact The width of Emina (and Lucida) is 110mm narrower than the first generation Estima so as to qualify for tax benefits of Small Size Passenger Vehicles, more commonly known as "5 number" vehicles in Japan. For "5 number" vehicles, length must be <4.7m (4,695mm max), width <1.7m (1,695mm max) and height<2.0m (1,995mm max). The road tax for this E Type V12 is $9,078 (with 50% surcharge), not the highest yet. Tommie Goh has a normal plate 1994 Rolls Royce Silver Spur, which attract an annual road tax of $12,378 as of current. @107fan @inlinesix $6.6K road tax for EV is equivalent to that of a 5.7L gasoline engine. Have lah. Mitsubishi FTO is one such example. If I am not wrong, some of the older Citroën also pair front mid engine setup with FWD. If you are referring to rear mid engine, than it should only pair with RWD. Expand But Jaguar has been paying since 1970s a full 20years more. So to me it’s the leader in roadtax. 1 Link to post Share on other sites More sharing options...
107fan 5th Gear January 22 Share January 22 On 1/22/2025 at 2:03 AM, Carbon82 said: Fun Fact The width of Emina (and Lucida) is 110mm narrower than the first generation Estima so as to qualify for tax benefits of Small Size Passenger Vehicles, more commonly known as "5 number" vehicles in Japan. For "5 number" vehicles, length must be <4.7m (4,695mm max), width <1.7m (1,695mm max) and height<2.0m (1,995mm max). The road tax for this E Type V12 is $9,078 (with 50% surcharge), not the highest yet. Tommie Goh has a normal plate 1994 Rolls Royce Silver Spur, which attract an annual road tax of $12,378 as of current. @107fan @inlinesix $6.6K road tax for EV is equivalent to that of a 5.7L gasoline engine. Have lah. Mitsubishi FTO is one such example. If I am not wrong, some of the older Citroën also pair front mid engine setup with FWD. If you are referring to rear mid engine, than it should only pair with RWD. Expand I wonder if his RR Silver Spur is actually daily driven level of road worthiness? More curious also does SG have any true RR/old Crewe-era Bentley specialists? My guess is most of these true specialists are probably in the UK still. What is the point of holding on to the nostalgia of these old regal machines when they are collecting dust in a basement. Link to post Share on other sites More sharing options...
107fan 5th Gear January 22 Share January 22 On 1/21/2025 at 4:26 PM, Gnahp said: I always think the lights look like lup cheong slice got lean meat, a bit of fat and a bit of liver 😁 Expand That's quite a compliment. I would say it looks like one of those bruises that never heal properly when you fell as a kid... 3 Link to post Share on other sites More sharing options...
Gnahp Turbocharged January 22 Share January 22 On 1/22/2025 at 12:34 AM, Mkl22 said: Mid engine is RWD. Got mid engine FWD? 😆 Expand got when you drive a MR car in reverse gear lor rear wheel steering some more 😁 5 Link to post Share on other sites More sharing options...
Mkl22 Supersonic January 22 Share January 22 (edited) On 1/22/2025 at 4:31 PM, 107fan said: I wonder if his RR Silver Spur is actually daily driven level of road worthiness? More curious also does SG have any true RR/old Crewe-era Bentley specialists? My guess is most of these true specialists are probably in the UK still. What is the point of holding on to the nostalgia of these old regal machines when they are collecting dust in a basement. Expand Go see YouTube to see what trash engines they are. Total nightmare to maintain and repair. You really wonder how those English mind think Edited January 22 by Mkl22 1 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged January 23 Share January 23 On 1/22/2025 at 11:32 PM, Mkl22 said: Go see YouTube to see what trash engines they are. Total nightmare to maintain and repair. You really wonder how those English mind think Expand Like old Jaguar V12...worse.🤦♂️ 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 23 Share January 23 On 1/3/2025 at 4:07 AM, Tohto said: Once upon a time this was all over our road. Expand I own one of this once upon a time in 1.6 manual guise.... Green was 3K cheaper and in those times it was a tad stupid to drive when u do a U turn, its took up too much space. Make u look like a noobie... 2 Link to post Share on other sites More sharing options...
Tohto Hypersonic January 23 Share January 23 On 1/23/2025 at 1:38 AM, Sdf4786k said: I own one of this once upon a time in 1.6 manual guise.... Green was 3K cheaper and in those times it was a tad stupid to drive when u do a U turn, its took up too much space. Make u look like a noobie... Expand 1.6L will be a lot better drive than the 1.0L 3 cylinder engine. 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 23 Share January 23 On 1/21/2025 at 4:19 AM, Toeknee_33 said: the front look similar to this Expand 5 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 23 Share January 23 On 1/23/2025 at 1:42 AM, Tohto said: 1.6L will be a lot better drive than the 1.0L 3 cylinder engine. Expand the mass majority was 1.3 but it was a joke... the number is so useless that a minor bump will cause it to split.. nothing to worry when that happens as u only need to lift from the chin of the bumper to clip it back.. 2 Link to post Share on other sites More sharing options...
Carbon82 Moderator January 23 Author Share January 23 I spotted this same Corolla liftback a few year along Beach Road, so seems that the owner has renewed the COE till 2028 (it would be 30 yo by then). The previous gen Corolla (E100) liftback variant look sooooo much better (rather futuristic during it's time). I wonder if there is any survivor on our shore... 7 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged January 24 Share January 24 On 1/23/2025 at 2:46 AM, Carbon82 said: The previous gen Corolla (E100) liftback variant look sooooo much better (rather futuristic during it's time). I wonder if there is any survivor on our shore... Expand Well, at least one i reckon. https://www.sgcarmart.com/used_cars/info.php?ID=1310981&DL=4092 3 Link to post Share on other sites More sharing options...
13177 Hypersonic January 24 Share January 24 On 1/23/2025 at 2:46 AM, Carbon82 said: I spotted this same Corolla liftback a few year along Beach Road, so seems that the owner has renewed the COE till 2028 (it would be 30 yo by then). The previous gen Corolla (E100) liftback variant look sooooo much better (rather futuristic during it's time). I wonder if there is any survivor on our shore... Expand One quick look, this corolla looks like the 2000 hyundai accent model. Lol. Link to post Share on other sites More sharing options...
Carbon82 Moderator January 24 Author Share January 24 On 1/24/2025 at 5:12 AM, Toeknee_33 said: Well, at least one i reckon. https://www.sgcarmart.com/used_cars/info.php?ID=1310981&DL=4092 Expand Thanks for sharing. If the COE expiry date is correct, this one should be able to make it to classic car scheme by end 2027. But why leather front seat with fabric rear seat?! The fabric seat in the rear look reasonably good given the age of the car. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Electric cars
Electric cars
Guess the Cars
Guess the Cars
