How Could This Have Happened?
Fitvip
Can you repair run flat tires? Or should you replace them?
Nate Risch
October 29, 2015 / 2 minutes read
It’s important to know what kind of tires you have on your car, thus if you are ever faced with an adverse situation, you’ll know what you safely can and cannot do. BMW equips the majority of their cars with run flat tires. They do this because it provides their customers with a few added benefits:
  • You can drive on a flat tire: The main benefit of a run-flat tire is that it allows you to keep driving—up to 50 miles at 50 miles per hour. This means that a person doesn’t have to get out of the car on the side of a busy highway or try to change a tire in the dark.
  • More stable after a blowout: Because a run-flat tire can support the vehicle without any air pressure, steering and handling will remain near normal after a sudden deflation.
  • Lower vehicle weight: With no spare tire and the repair tools removed, vehicle weight is reduced.
How can you identify if you have BMW run flat tires or not? All the information you need is on the sidewall. For BMW vehicles, what you will want to look for is the RSC label.
If you are on run flat tires, most manufacturers recommend replacement when they have been driven in a severely underinflated or zero pressure condition. This is because the integrity of their internal structure cannot be confirmed.
Now if you are on standard tires, and your tire becomes damaged, it may be repaired if it meets the following criteria:
  1. The tire has not been driven on when flat.
  2. The damage is only on the tread section of your tire (sidewall damage ruins a tire immediately).
  3. The puncture is no greater than ¼”.
The proper way to have a flat tire repaired is to fill the puncture hole from the inside, then apply a patch on top of the repair. Do not have your tire plugged. Ever. Plug repairs do not involve taking the tire off the wheel for a proper inspection. A plug is simply inserted into the punctured area, making it unreliable. Insist on a full inspection and have your tire center demount, then inspect the interior and exterior of the tire. Only after a thorough inspection should a tire be repaired.
https://www.bmwblog.com/2015/10/29/can-you-repair-that-flat-tire-or-should-you-replace-it/
  • Praise 3
  On 8/7/2022 at 8:26 AM, Gnahp said:
I wish someone can do an apps
using the camera to point at the car, capturing the number plate
then the apps automatic retrieve the data from onemotoring road tax inquiry to show the details, live on the screen
that is like having bionic eyes, can see what is under the clothes, real time 😁
Expand
Police already have it. You can’t have it because LTA website requires Captcha input to protect their database from being automatically scraped.
  • Praise 2
Expand
Yeah, they didn't use to have CAPTCHA before plus you got more info. Oh well.
