Axela525 4th Gear July 12, 2022 Share July 12, 2022 Any inspection centre more lenient? Like rear reflector with brake lights, can pass? Last time I tape it over with red tape, they only say my front pole lights should not be led, but passed! That was in Vicom Kakit Bukit....planning to go there again....any feedback? Thanks! ↡ Advertisement 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator July 12, 2022 Share July 12, 2022 22 minutes ago, Axela525 said: Any inspection centre more lenient? Like rear reflector with brake lights, can pass? Last time I tape it over with red tape, they only say my front pole lights should not be led, but passed! That was in Vicom Kakit Bukit....planning to go there again....any feedback? Thanks! I don't dare to tell you. I scare I tell you liao, you fail, you come and scold me. Just make sure your car pass then send for inspection? Make your life easy and make thier life easy. Headlight must below 4300K, then 4300K lor. Tinted flim must remove, then must remove lor For rear reflector, if is not come with the car, then it is confirm fail one. no question ask. hahah. 2 7 Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 12, 2022 Share July 12, 2022 40 minutes ago, Axela525 said: Any inspection centre more lenient? Like rear reflector with brake lights, can pass? Last time I tape it over with red tape, they only say my front pole lights should not be led, but passed! That was in Vicom Kakit Bukit....planning to go there again....any feedback? Thanks! tape it first, if fails then go get it removed. Link to post Share on other sites More sharing options...
Axela525 4th Gear July 12, 2022 Author Share July 12, 2022 @Ct3833 planning to...thks... 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic July 12, 2022 Share July 12, 2022 58 minutes ago, Axela525 said: Any inspection centre more lenient? Like rear reflector with brake lights, can pass? Last time I tape it over with red tape, they only say my front pole lights should not be led, but passed! That was in Vicom Kakit Bukit....planning to go there again....any feedback? Thanks! My one broken tail light use scotch tape cover up black smoke 5x higher than allowed 4 Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 12, 2022 Share July 12, 2022 11 minutes ago, Mustank said: My one broken tail light use scotch tape cover up black smoke 5x higher than allowed black smoke can pass? whcih center ? I will complain to LTA 🤣 but you serious? black smoke above limit can pass? 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic July 12, 2022 Share July 12, 2022 4 minutes ago, Ct3833 said: black smoke can pass? whcih center ? I will complain to LTA 🤣 but you serious? black smoke above limit can pass? Depends on how you step. Will tend to fail if you just whack the accelerator. Especially for euro2. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 12, 2022 Share July 12, 2022 25 minutes ago, Mustank said: My one broken tail light use scotch tape cover up black smoke 5x higher than allowed 1 bottle of Diesel Fuel Cleaner + "Proper diesel". That should solve the problem. 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged July 12, 2022 Share July 12, 2022 don't give ideas to LTA leh..... 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic July 12, 2022 Share July 12, 2022 (edited) @Axela525Can disconnect the wire? Last time my rear window tint +5% also failed. When I see some cars and vans on the road with totally dark tint I feel damn damn unfair and fed up. I put two tiny reflectors on the rear number plate screws were also told to remove.😪🤬 Edited July 12, 2022 by Fitvip 3 Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged July 12, 2022 Share July 12, 2022 after so many years we still get this kind of questions? hahaha SAF No.1 rule - Do anything u want but don't get caught. Car modders No.1 rule - Want to mod don't scared, Want to scared don't mod. 2 Link to post Share on other sites More sharing options...
Confusedboi Supercharged July 12, 2022 Share July 12, 2022 You can try STA at sin Ming, might be more lenient. Don’t quote me though😆. Manage to pass inspection just 2 months ago using type r muffler(only) on my non type r Honda Civic. No type r header or mid pipe though, that one still stock. Last time tried using type r mid pipe plus muffler kena failed cos got obvious welding to extend mid pipe to cat converter. Link to post Share on other sites More sharing options...
Vratenza Supersonic July 12, 2022 Share July 12, 2022 2 non-led pole lights only a couple of dollars.... Easy swap. Youtube is your best friend. Rear reflector(modded to brake light) just get some red reflective stickers, cut to shape, paste and be done with it. 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic July 12, 2022 Share July 12, 2022 51 minutes ago, Ct3833 said: black smoke can pass? whcih center ? I will complain to LTA 🤣 but you serious? black smoke above limit can pass? Of course fail lah the tailight already fail Spoiler 2 Link to post Share on other sites More sharing options...
Inlinefour Twincharged July 12, 2022 Share July 12, 2022 my choibu friends all go sin ming with ultra short skirt one time pass liao similar to their driving test 🙊🙉🙈 5 Link to post Share on other sites More sharing options...
Gnahp Turbocharged July 12, 2022 Share July 12, 2022 1 hour ago, Confusedboi said: You can try STA at sin Ming, might be more lenient. Don’t quote me though😆. Manage to pass inspection just 2 months ago using type r muffler(only) on my non type r Honda Civic. No type r header or mid pipe though, that one still stock. Last time tried using type r mid pipe plus muffler kena failed cos got obvious welding to extend mid pipe to cat converter. my experience with STA Sin Ming is the opposite last time they failed me for front window glass > 70% (78%) that car was bone stock with Huper Optik film done by C&C, no problem for 3rd and 5th year inspection the guy said tinted film will get darker if I park under the sun for too long he said if I can peel away a section on the spot to let his equipment read again, I will get my inspection certificate I refused and drove to the Vicom nearby, pay again and passed without drama 1 1 Link to post Share on other sites More sharing options...
Confusedboi Supercharged July 12, 2022 Share July 12, 2022 24 minutes ago, Gnahp said: my experience with STA Sin Ming is the opposite last time they failed me for front window glass > 70% (78%) that car was bone stock with Huper Optik film done by C&C, no problem for 3rd and 5th year inspection the guy said tinted film will get darker if I park under the sun for too long he said if I can peel away a section on the spot to let his equipment read again, I will get my inspection certificate I refused and drove to the Vicom nearby, pay again and passed without drama Oops I forgot to mention mine is annual inspection because COE car. Not 7th year inspection. Not sure about tinting rules but heard lots of stories like yours like factory agent tint end up failing 1 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged July 12, 2022 Share July 12, 2022 57 minutes ago, Inlinefour said: my choibu friends all go sin ming with ultra short skirt one time pass liao similar to their driving test 🙊🙉🙈 mmmmm driving test hoh tester sit inside see liao song song gao jurong.. can geh geh extend route to test her more.. i mean her driving skill lah! whahahahaha inspect car they see wat? chio bu no sit inside de leh! 😁 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
How long does it take to inspect the IU?
Change New Exhaust: When to Inspect?
How long does it take for mechanic to inspect and maintain a car?
