shutterbox 3rd Gear March 5, 2022 Share March 5, 2022 (edited) Bottom right. Any shop that can get that water out? Edited March 5, 2022 by shutterbox ↡ Advertisement Link to post Share on other sites More sharing options...
Beregond Supersonic March 5, 2022 Share March 5, 2022 (edited) drill a small hole at the btm😂 ( its impossible to remove those droplets ) or spend some money and replace the whole thing Edited March 5, 2022 by Beregond Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 5, 2022 Share March 5, 2022 Here is what I did for my rear lights in my ex Mazda. Remove the whole light. try to shake out whatever water i could. Hang it under my Aircon in my bedroom. Let the dry air remove the remaining moisture. I did it for 2 days. use black silicone. Dow Corning 791 or 688. I only believe in industrial external wall silicone. To silicone the edges all round. let the silicone dry for 12hrs. Reinstall. Never leaked again. 8 1 1 Link to post Share on other sites More sharing options...
Volvobrick Supersonic March 5, 2022 Share March 5, 2022 Is your car pretending to be a Porsche? It's normal to see Porsche headlights with plenty of condensation inside. OK Mkl22's suggestion is good. For lazy ones maybe try to use a wet vacuum attached to skinny tube to suck out the water without removing the headlights, and silicon at least top and perhaps sides if you can get to it. Bake under sunlight for next few days but you can continue to drive. 5 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic March 5, 2022 Share March 5, 2022 (edited) I see aftermarket light bulbs. Did you remove the dust cover? The dust cover is to prevent the heat from the engine bay from entering into the headlight casing. If the air in the casing is hot meet with outside air which is cool....condensation lo. How to remove the water you have to remove the assembly and drain the water. After that just use a hair dryer and blow the inside dry. Previously my car was using halogen bulb. It produces a lot of heat actually. During cold weather I can see condensation. Then I went to use aftermarket LED bulb, not bright one and install. It produces less heat. No more condensation. The pole light I also use LED. The colour I use is 4200K, a bit yellowish. Keep low profile. Edited March 5, 2022 by Watwheels 6 Link to post Share on other sites More sharing options...
macrosszero Turbocharged March 5, 2022 Share March 5, 2022 2 hours ago, shutterbox said: Bottom right. Any shop that can get that water out? Those headlight restorers like Dr. Glass can probably remove the plastic lens from the bucket as they do painting of the intervals. Might as well give them cataracts (no matter how lightly oxidized) while you’re at it 1 Link to post Share on other sites More sharing options...
shutterbox 3rd Gear March 5, 2022 Author Share March 5, 2022 will try some of the suggestions u guys give. thanks. Link to post Share on other sites More sharing options...
Tohto Hypersonic March 5, 2022 Share March 5, 2022 Common problem for the Allion headlight. Find a workshop that can replace the rubber seal of the headlight. Link to post Share on other sites More sharing options...
Kb27 Supersonic March 5, 2022 Share March 5, 2022 Take it out, bring it home. Try aiming a hairdryer at the holes, after taking out the bulb. 1 Link to post Share on other sites More sharing options...
shutterbox 3rd Gear March 6, 2022 Author Share March 6, 2022 I will use a syringe n a flexible tube to try extract out the water. Then leave the socket open n suntan (when available) for 1 afternoon to evaporate the rest of the water. Link to post Share on other sites More sharing options...
JenniferBarber Neutral Newbie September 13, 2022 Share September 13, 2022 于 2022 年 3 月 5 日下午 3:29 说道: 右下角。 有哪家店能把水拿出来? You follow the steps given below solve the problem: https://cardehumidifiers.com/clean-foggy-headlights/#how-to-clean-foggy-headlights-on-the-inside Link to post Share on other sites More sharing options...
shutterbox 3rd Gear September 14, 2022 Author Share September 14, 2022 16 hours ago, JenniferBarber said: You follow the steps given below solve the problem: https://cardehumidifiers.com/clean-foggy-headlights/#how-to-clean-foggy-headlights-on-the-inside I solved my problem n shared my solution already Link to post Share on other sites More sharing options...
fto80 Neutral Newbie August 6, 2024 Share August 6, 2024 you can try by using a hair dryer and blow dry air into the headlight to dry up the water and air inside the head light. If it's still happening again, i recon you light might be leaking. I bought some lights from this mob www.myparts.com.my they were quite cheap. ↡ Advertisement Link to post Share on other sites More sharing options...
Energy Savings / Non Heat up LED Headlights Technology
Car inspection questions
LED head light
LED head light
Theives Gouged Out This Poor Porsche Taycan's Headlights
Toyota Camry
Toyota Camry
Brighter headlights needed
